Home » Eclipse Projects » Standard Widget Toolkit (SWT) » vex.sourceforge.net - scrolling problem due to ScrolledComposite ?
vex.sourceforge.net - scrolling problem due to ScrolledComposite ? [message #446879] Sat, 04 December 2004 15:48 Go to next message
I have been using the Visual Editor for XML (vex.sourceforge.net) and
have noticed problems scrolling through large documents. The problem
manifests itself in different forms on different platforms.
+ On Linux (gtk) positioning with the mouse in very large
documents causes the insertion point cursor to warp backwards
by fairly large displacements
+ On Windows/XP documents are truncated. Nothing displays after
a certain displacement that looks like there is some artificial
limit to the size of the Canvas area.
+ Haven't tested on Win 98 recently. No access to Mac but I recall
that Vex doesn't run on Mac.
On browsing this newsgroup I have noticed several recommendations from
Veronika Irvine who suggests that we should be using Canvas.scroll
rather than scrolling with getScrolledComposite. AT least one of these
answers was in response to a question about size-sensitivity of a
scrolling operation.
VEX uses getScrolledComposite to gain acces to the scrollbars associated
with the VexWidget class that contains the editor.
I would really appreciate a little help in determining whether the Vex
problem is due to the use of the ScrolledComposite form of scrolling.
I could do this if I had a better explanation than I have seen.
Patient: "Doctor, it hurts when I do this"
Groucho: "Then don't do that."
Vex is an Open Source project that implements a Visual Editor for XML
that works a bit like the XMLMind XML Editor (XXE) in that it uses
CSS for styling but it is an XML plugin that should be an excellent
tool for Eclipse users.
Re: vex.sourceforge.net - scrolling problem due to ScrolledComposite ? [message #446923 is a reply to message #446879] Mon, 06 December 2004 09:25 Go to previous messageGo to next message
I should have stated clearly that VEX is an Eclipse plugin and that
the project is hosted at Sourceforge.
Re: vex.sourceforge.net - scrolling problem due to ScrolledComposite ? [message #447005 is a reply to message #446879] Tue, 07 December 2004 12:26 Go to previous messageGo to next message
In a ScrolledComposite the content is sized to its preferred size which may
be very large even though just part of it is showing. There are limitations
on how large a control can be.
For example, on Windows, if you set the size to be Point (Integer.MAX_VALUE,
Integer.MAX_VALUE) and then query the actual size, you will get Point
(32767, 32767).
If you are writing your own text widget or image viewer widget, you should
use Canvas and manage the scrollbars without having the content be the full
size.
In addition, Canvas.scroll makes use of operating system/graphics card
features to be faster and smoother.
"John Austin" <jwaustin@nl.rogers.com> wrote in message
news:cot7qf$kas$1@www.eclipse.org...
Re: vex.sourceforge.net - scrolling problem due to ScrolledComposite ? [message #447624 is a reply to message #447005] Wed, 15 December 2004 08:12 Go to previous messageGo to next message
I am very pleased to report that I passed your remarks on to the
developer and he checked in a successful fix for this problem
a few days ago. VEX now passes a new level of stress-test and
is useable with documents as large as the Linux Device Drivers
book at oreilly.com
Now we can get on with adding features such as filling out VEX's
CSS support and ease of use.
> (32767, 32767).
> size.
>>manifests itself in different forms on different platforms.>
Re: vex.sourceforge.net - scrolling problem due to ScrolledComposite ? [message #449911 is a reply to message #446879] Sun, 30 January 2005 21:53 Go to previous message
I could be wrong but I don't think Vex can be licensed and distributed the
way it is. It says it's an LGPL program, but the download bundles Eclipse
code which is CPL/EPL. The two licenses are incompatible. I see you're
listed as one of the developers. Would it be possible to release Vex under
CPL/EPL instead, or a compatible license like Apache? These would also
ensure it's always "free to use, modify, and re-distribute" as it says on
the http://vex.sf.net web site but would allow more flexibility in the
environments where it could be used.
Ed Burnette
www.eclipsepowered.org
Previous Topic:[ANN] v1.02 - SWT Calendar Widgets with DatePicker
Next Topic:flexible space between menus
Current Time: Sat Jul 19 02:11:12 EDT 2025
Powered by FUDForum. Page generated in 0.24706 seconds
