Home » Eclipse Projects » Rich Client Platform (RCP) » PDE Build 3.2 (M5) can't build my RCP app
PDE Build 3.2 (M5) can't build my RCP app [message #447605] Tue, 11 April 2006 13:37 Go to next message
Originally posted by: harward.junkmail.gmail.com
--------------000008030703020502070703
I've got an existing RCP app that I have been building with PDE Build
3.1.2 without an trouble.
I have recently migrated to Eclipse 3.2 (M5). I can run and then build
my RCP within the Eclipse IDE (with the export wizard). However, when I
try to execute my automated build from the command line (-application
org.eclipse.pde.build.Build) the PDE Build application crashes with a
NullPointerException. I have attached the stack trace.
I'm thinking my problem could be the result of one of a couple things:
1) Perhaps a bug in PDE Build 3.2?
2) PDE Build 3.2 requires additional configuration (perhaps in
build.properties, feature.xml, or the .product file?) that was not
required in 3.1.2.
Any insight along these lines will be appreciated.
name="exception.txt"
Content-Disposition: inline;
filename="exception.txt"
at org.eclipse.pde.internal.build.ProductGenerator.getBrandingP lugin(ProductGenerator.java:259)
at org.eclipse.pde.internal.build.ProductGenerator.getSplashLoc ation(ProductGenerator.java:267)
at org.eclipse.pde.internal.build.ProductGenerator.createConfig Ini(ProductGenerator.java:142)
at org.eclipse.pde.internal.build.ProductGenerator.generate(Pro ductGenerator.java:64)
at org.eclipse.pde.internal.build.builder.FeatureBuildScriptGen erator.generateRootFilesAndPermissions(FeatureBuildScriptGen erator.java:544)
at org.eclipse.pde.internal.build.builder.FeatureBuildScriptGen erator.generateGatherBinPartsTarget(FeatureBuildScriptGenera tor.java:523)
at org.eclipse.pde.internal.build.builder.FeatureBuildScriptGen erator.generateBuildScript(FeatureBuildScriptGenerator.java: 317)
at org.eclipse.pde.internal.build.builder.FeatureBuildScriptGen erator.generate(FeatureBuildScriptGenerator.java:247)
at org.eclipse.pde.internal.build.BuildScriptGenerator.generate Features(BuildScriptGenerator.java:168)
at org.eclipse.pde.internal.build.BuildScriptGenerator.generate (BuildScriptGenerator.java:80)
at org.eclipse.pde.internal.build.tasks.BuildScriptGeneratorTas k.run(BuildScriptGeneratorTask.java:80)
at org.eclipse.pde.internal.build.tasks.BuildScriptGeneratorTas k.execute(BuildScriptGeneratorTask.java:72)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:275)
at org.apache.tools.ant.Task.perform(Task.java:364)
at org.apache.tools.ant.Target.execute(Target.java:341)
at org.apache.tools.ant.Target.performTasks(Target.java:369)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1216)
at org.apache.tools.ant.helper.SingleCheckExecutor.executeTarge ts(SingleCheckExecutor.java:37)
at org.eclipse.ant.internal.core.ant.EclipseSingleCheckExecutor .executeTargets(EclipseSingleCheckExecutor.java:30)
at org.apache.tools.ant.Project.executeTargets(Project.java:106 8)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:382)
at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:107)
at org.apache.tools.ant.Project.executeTarget(Project.java:1185 )
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:40)
at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:704)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:582)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:494)
at org.eclipse.pde.internal.build.BuildApplication.run(BuildApp lication.java:13)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:99)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
--------------000008030703020502070703--
Re: PDE Build 3.2 (M5) can't build my RCP app [message #447607 is a reply to message #447605] Tue, 11 April 2006 14:24 Go to previous messageGo to next message
> required in 3.1.2.
You should try to reproduce using 3.2M6.
If you do reproduce it, please open a bug report against PDE/Build.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=PDE
And provide steps to reproduce.
Please do it now if you want to see it fixed for 3.2. We are approaching
3.2RC1 (this week).
Olivier
Re: PDE Build 3.2 (M5) can't build my RCP app [message #447609 is a reply to message #447607] Tue, 11 April 2006 15:57 Go to previous message
Olivier - thanks for the suggestion. I was actually already half way
through setting up M6 when I got your reply. Seems to be an issue with
M5 as things seem to be building now with the M6 milestone release of
PDE Build.
Previous Topic:Cancel job from status line
Next Topic:Use AOP in RCP
Current Time: Sun Aug 31 09:54:36 EDT 2025
Powered by FUDForum. Page generated in 0.03940 seconds
