Home » Eclipse Projects » Rich Client Platform (RCP) » How to register action in EditorActionBarContributor
How to register action in EditorActionBarContributor [message #447437] Wed, 05 April 2006 13:18 Go to next message
It's easy to add and register actions in the ApplicationActionBarAdvisor but I can't figure out how to do it in the editor context when an EditorActionBarContributor is used to contribute editor actions. There doesn't seem to be a register() method and I can't seem to find a way to get a suitable IKeyBindingService.
I need to register the action to activate the key binding.
Thanks!
Peter
Re: How to register action in EditorActionBarContributor [message #447438 is a reply to message #447437] Wed, 05 April 2006 13:24 Go to previous messageGo to next message
You can get the IActionBars from within the EditorActionBarContributor.
There you can get and set global action handlers (which I assume is the
register you are looking for).
Later,
PW
Re: How to register action in EditorActionBarContributor [message #447730 is a reply to message #447438] Thu, 13 April 2006 12:50 Go to previous messageGo to next message
I can't seem to get it to work. In my class which extends EditorActionBarContributor, I have:
private void makeActions() {
filterAction = new FilterColumnsAction(window);
getActionBars().setGlobalActionHandler(filterAction.getId(), filterAction);
getActionBars().updateActionBars();
but this fails and the editor doesn't start up. I just want to register the action, like in ApplicationActionBarAdvisor, so that the specified keybinding extension works for this action.
thanks,
Peter
Re: How to register action in EditorActionBarContributor [message #447732 is a reply to message #447730] Thu, 13 April 2006 13:18 Go to previous message
Your code looks decent. Does your filterAction.getId() return null?
Does your filterAction have an actionDefinitionID defined as well? Is
there a matching command somewhere?
If the editor doesn't start up, what error did it give? Also, you
should probably be doing your setGlobalActionHandler(*) in the
setActiveEditor(*) method. Get the subclasses of
EditorActionBarContributor (F4) and see how they set up actions.
Later,
PW
Previous Topic:problem with JOGL in RCP
Next Topic:Questions about progress service
Current Time: Sat Aug 30 23:09:41 EDT 2025
Powered by FUDForum. Page generated in 0.03762 seconds
