Home » Eclipse Projects » Standard Widget Toolkit (SWT) » UnsatisfiedLinkError
UnsatisfiedLinkError [message #447414] Tue, 14 December 2004 11:02 Go to next message
Hello!
Guess what? I'm having sooooooo much fun with this little message in the
console:
java.lang.UnsatisfiedLinkError: no swt-win32-3063 in java.library.path
bla...
bla...
bla...
Before you start hitting me with a baseball bat for posting such a newbie
question, let me just say that:
YES, I have the swt.jar on my build path;
YES, I put "-Djava.library.path={path to the SWT DLLs};
YES, the application I was developing was WORKING JUST FINE, and now, for
an obscure reason, I have this sweeeeeeet little message in the console;
YES, I'm using Eclipse Platform
Version: 3.0.1
Build id: 200409161125
O.K. now, enlighten me please, it's kind of driving me crazy (and believe
me, I'm close enough to the edge already...)
Thanks again folks,
Rushman
UnsatisfiedLinkError Aaaaargh! [message #447415 is a reply to message #447414] Tue, 14 December 2004 11:13 Go to previous messageGo to next message
"Rushman" <rochefort@irosoft.com> wrote in message
news:cpn2r2$r8l$1@www.eclipse.org...
> Hello!
> console:
> bla...
> bla...
> bla...
> YES, I'm using Eclipse Platform Version: 3.0.1
> Thanks again folks,
> Rushman
Re: UnsatisfiedLinkError Aaaaargh! [message #447421 is a reply to message #447415] Tue, 14 December 2004 14:24 Go to previous messageGo to next message
The VM is apparently unable to find the right dll (swt-win32-3063.dll).
The only possible reason I can think of is a bad syntax or a wrong path in
your "{path to the SWT DLLs};"
You can also try copying the dll to your application folder or to
Windows\system32.
Can you post the complete command that you use to start the application?
regards,
Mani
news:cpn3ga$tgk$1@www.eclipse.org...
>> Hello!
>> console:
>> bla...
>> bla...
>> bla...
>> Thanks again folks,
>> Rushman
Re: UnsatisfiedLinkError Aaaaargh! [message #447647 is a reply to message #447421] Wed, 15 December 2004 16:24 Go to previous message
> Windows\system32.
> regards,
>>> Hello!
>>> console:
>>> bla...
>>> bla...
>>> bla...
>>> newbie question, let me just say that:
>>> for an obscure reason, I have this sweeeeeeet little message in the
>>> console; YES, I'm using Eclipse Platform Version: 3.0.1
I had the same problem, and it was because swt.jar and -Djava.library.path
pointed to different swt directories (I have two swt installations, the
eclipse's and another "alone" in my home dir).
For example, -Djava.library.path=/home/marcelo/swt and the swt.jar in the
classpath was at /home/marcelo/eclipse/plugins/..../swt/
If you change the build path to "/home/marcelo/swt/swt.jar" (where
-Djava.library.path is configured) maybe should resolve it.
Cheers!
Marcelo
Previous Topic:Open an file when clicking a TableTreeViewer
Next Topic:Purpose of Display.setAppName
Current Time: Wed Jul 23 14:16:45 EDT 2025
Powered by FUDForum. Page generated in 0.04408 seconds
