Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Why FileDialog's setFilterExtensions() did not work in Linux gtk?
Why FileDialog's setFilterExtensions() did not work in Linux gtk? [message #446956] Tue, 07 December 2004 05:02 Go to next message
Originally posted by: huac.idsignet.com
FileDialog's setFilterExtensions() works correctly in window OS, but in
Linux gtk it works abnormal.
If the extension is "*.xml", which will appear in the Text widget on the
bottom, but in the files viewer, no filtering is executed.
Thanks.
Re: Why FileDialog's setFilterExtensions() did not work in Linux gtk? [message #446984 is a reply to message #446956] Tue, 07 December 2004 08:29 Go to previous messageGo to next message
This does not work in the original GtkFileSelection widget, but does work in
the newer GtkFileChooser. If you're running with gtk >= 2.4.10 then you
will get the correct GtkFileChooser behaviour through swt, but if you have
an earlier gtk version then file filtering will not work for you. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=46667 .
Grant
"Hua Chao" <huac@idsignet.com> wrote in message
news:cp3uv7$d4j$1@www.eclipse.org...
> Thanks.
Re: Why FileDialog's setFilterExtensions() did not work in Linux gtk? [message #447018 is a reply to message #446984] Tue, 07 December 2004 20:28 Go to previous message
Hi:
Thanks. My gtk version is 2.4.0-1.
> Grant
>>Thanks.
Previous Topic:Default Focus for Wizard Button
Next Topic:flame bait (newbie SWT question)
Current Time: Sun Jul 27 16:20:46 EDT 2025
Powered by FUDForum. Page generated in 0.03001 seconds
