Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Widget layout
Widget layout [message #446814] |
Thu, 02 December 2004 15:08  |
Hi All,
I have created my own widget that contains a table control. The problem I am
currently having is the widget only takes up 1 horizontal span of the
composite. My example contains one row of a label and text control followed
below by my widget. Directly using a table control instead of my widget
works fine.
I would appreciate any ideas/help.
public MyExample(Composite parent) {
setLayout(parent);
addControls(parent);
private void setLayout(Composite composite) {
// Create a composite to hold the children
composite.setLayoutData(new GridData(GridData.FILL_BOTH));
// Set numColumns for the buttons
int numColumns = 2;
GridLayout layout = new GridLayout(numColumns, false);
layout.marginWidth = 4;
composite.setLayout (layout);
public void addControls(Composite container) {
Label label = new Label(container, SWT.NONE);
label.setText("Testing");
// create text control
Text control = new Text(container, SWT.BORDER | SWT.SINGLE);
final GridData gridData = new GridData(GridData.FILL_HORIZONTAL |
GridData.VERTICAL_ALIGN_END);
gridData.horizontalSpan = 2;
control.setLayoutData(gridData);
// create my widget
int style = SWT.SINGLE | SWT.BORDER | SWT.H_SCROLL | SWT.V_SCROLL |
SWT.FULL_SELECTION | SWT.HIDE_SELECTION;
MyTableWidget widget = new MyTableWidget(parent, style);
public MyTableWidget(Composite parent, int style) {
super(parent, SWT.NONE);
// Set GridLayout
int numColumns = 4; // default;
Layout data = (Layout) parent.getLayout();
if (data instanceof GridLayout) {
numColumns = ((GridLayout) data).numColumns;
setLayout(layout);
// Set composite layout
GridData gridData = new GridData(GridData.FILL_BOTH);
//setLayoutData(gridData);
table = new Table(this, style);
// Set table layout
gridData.horizontalSpan = numColumns;
table.setLayoutData(gridData);
// Show lines and header
table.setLinesVisible(true);
table.setHeaderVisible(true);
Re: Widget layout [message #446836 is a reply to message #446814] |
Fri, 03 December 2004 11:02   |
You need to set the layout data on MyTableWidget
this.setLayoutData(gridData);
"John" <j_cout_nospam@yahoo.com> wrote in message
news:consnu$sg1$1@www.eclipse.org...
> Hi All,
> am
> followed
> works fine.
> setLayout(parent);
> int numColumns = 2;
> // create my widget
> // Set GridLayout
> setLayout(layout);
> // Set table layout
Re: Widget layout [message #446859 is a reply to message #446836] |
Fri, 03 December 2004 11:17   |
Thanks Veronika,
I have another question regarding the layout. In my widget which extends
Composite, I call super(parent, SWT.NONE); When the widget is displayed
there is a certain amount of area (border) that is lost. Hence, the
alignment between controls above the widget and the widget is slightly off
i.e. the widget is narrowed on all sides. How do I reclaim this lost border
space.
thanks.../john
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:coq2nc$ld9$1@www.eclipse.org...
> > Hi All,
I
> > am
> > followed
> > works fine.
> > setLayout(parent);
> > int numColumns = 2;
> > // create my widget
> > // Set GridLayout
> > setLayout(layout);
> > // Set table layout
Re: Widget layout [message #446864 is a reply to message #446859] |
Fri, 03 December 2004 14:18  |
Hi All,
Found the solution, has to do with the margins. Thanks.
layout.marginWidth = 0;
layout.marginHeight = 0;
setLayout(layout);
news:coq3hl$nll$1@www.eclipse.org...
> Thanks Veronika,
border
> space.
> thanks.../john
> > > Hi All,
problem
> I
> > > am
> > > followed
widget
> > > works fine.
> > > setLayout(parent);
> > > int numColumns = 2;
> > > // create my widget
> > > // Set GridLayout
> > > setLayout(layout);
> > > // Set table layout
Current Time: Thu Jul 24 22:19:53 EDT 2025
Powered by FUDForum. Page generated in 0.04956 seconds
