Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Scrollable Composite for Icons / thumbnails
Scrollable Composite for Icons / thumbnails [message #446738] Wed, 01 December 2004 22:11 Go to next message
Hi all,
Im developing a photo gallery application (SWT / stand alone).
Is there a way of implementing a scrollable composite that contains fixed
sized children (icons / thumbnails).
The children should be layed out in a row/wrap manner just like your usual
file explorer (vertical scrolling only. children are put on the next row
upon reaching the right edge of the composite)
My initial attempt was to use a SrollableComposite and put another composite
with RowLayout. Yet, the RowLayout does not automatically rxpand the
composite, when there is no space available at the bottom. and the lenght of
the vertical scrollbar does not represent the size of the underlying
composite.
I'd be greatful for any ideas
Mani
Re: Scrollable Composite for Icons / thumbnails [message #446755 is a reply to message #446738] Thu, 02 December 2004 08:48 Go to previous messageGo to next message
Hi Mani,
I solved the problem a few days ago. The trick is to manipulate the method
computeSize of the ScrolledComposite and call the method setMinSize if the
size of the application chanded.
See the code below
Bye Stefan
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.ScrolledComposite;
import org.eclipse.swt.events.ControlAdapter;
import org.eclipse.swt.events.ControlEvent;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
public class ThumbnailTest {
private static ScrolledComposite scrollComposite;
private static Composite thumbsComposite;
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
shell.setText("ThumbnailTest");
scrollComposite = new ScrolledComposite(shell, SWT.V_SCROLL | SWT.BORDER);
scrollComposite.setLayout(new FillLayout());
scrollComposite.setExpandVertical(true);
scrollComposite.setExpandHorizontal(true);
scrollComposite.addControlListener(new ControlAdapter() {
public void controlResized(ControlEvent e) {
setSize();
RowLayout layout = new RowLayout(SWT.HORIZONTAL);
layout.wrap = true;
thumbsComposite = new Composite(scrollComposite, SWT.NONE){
public Point computeSize(int wHint, int hHint, boolean changed) {
Rectangle r = getParent().getClientArea();
System.out.println("R="+r.x+"x"+r.y+" "+r.width+"x"+r.height);
return super.computeSize(r.width, SWT.DEFAULT, changed);
thumbsComposite.setLayout(layout);
scrollComposite.setContent(thumbsComposite);
for(int i = 1; i <= 50; i++) {
// use setImage for Thumbnails
new Button(thumbsComposite, SWT.NONE).setText("Test");
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
private static void setSize() {
scrollComposite.setMinSize(thumbsComposite.computeSize(SWT.D EFAULT,
SWT.DEFAULT));
"Mani Ghamari" <mani.ghamari@linkast.com> schrieb im Newsbeitrag
news:com15d$ot6$1@www.eclipse.org...
> Hi all,
composite
of
> composite.
> Thanks
> Mani
Re: Scrollable Composite for Icons / thumbnails [message #446758 is a reply to message #446755] Thu, 02 December 2004 09:05 Go to previous messageGo to next message
Thanks Stefan!
It works perfectly. I really appreciate your help...
Mani
"Stefan Pietsch" <pietsch@multichart.de> wrote in message
news:con6fe$4uv$1@www.eclipse.org...
> Hi Mani,
> See the code below
> Bye Stefan
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> setSize();
> layout.wrap = true;
> shell.open();
> display.sleep();
> display.dispose();
> SWT.DEFAULT));
>> Hi all,
>> usual
> composite
> of
>> composite.
>> Thanks
>> Mani
Re: Scrollable Composite for Icons / thumbnails [message #446799 is a reply to message #446755] Thu, 02 December 2004 09:06 Go to previous messageGo to next message
Stefan has the right idea but you do not actually need to subclass Composite
and override computeSize. Here is a simplified version that does the same
thing.
final ScrolledComposite scrollComposite = new
final Composite thumbsComposite = new Composite(scrollComposite,
SWT.NONE);
// use setImage for Thumbnails -- could use Label here
instead
layout.wrap = true;
Rectangle r = scrollComposite.getClientArea();
scrollComposite.setMinSize(thumbsComposite.computeSize(r.wid th,
SWT.DEFAULT));
shell.open();
display.sleep();
display.dispose();
> Hi Mani,
> See the code below
> Bye Stefan
> setSize();
> layout.wrap = true;
> shell.open();
> display.sleep();
> display.dispose();
> SWT.DEFAULT));
>> Hi all,
>> usual
> composite
> of
>> composite.
>> Thanks
>> Mani
Re: Scrollable Composite for Icons / thumbnails [message #446800 is a reply to message #446799] Thu, 02 December 2004 09:44 Go to previous message
Hi Veronika,
thanks for the idea. I changed my code too.
Bye Stefan
"Veronika Irvine" <veronika_irvine@oti.com> schrieb im Newsbeitrag
news:con7hv$7s5$1@www.eclipse.org...
Composite
> thing.
> SWT.NONE);
> instead
> layout.wrap = true;
> SWT.DEFAULT));
> shell.open();
> display.sleep();
> display.dispose();
> > Hi Mani,
method
the
> > See the code below
> > Bye Stefan
SWT.BORDER);
> > setSize();
> > layout.wrap = true;
> > shell.open();
> > display.sleep();
> > display.dispose();
> > SWT.DEFAULT));
> >> Hi all,
fixed
> >> usual
row
> > composite
lenght
> > of
> >> composite.
> >> Thanks
> >> Mani
Previous Topic:[TreeViewer] Force update
Next Topic:Safari Browser
Current Time: Thu Jul 24 23:42:43 EDT 2025
Powered by FUDForum. Page generated in 0.15873 seconds
