Home » Eclipse Projects » Standard Widget Toolkit (SWT) » swt.lib ??
swt.lib ?? [message #446636] Tue, 30 November 2004 08:48 Go to next message
Originally posted by: camilla.orlandi.gmail.com
hi everybody
I have Eclipse 3.0, gcj & gcc 3.4 on windows 2K.
I tried to compile my swt class with gcj and works, but I can't manage to
link the file so I have not an exe at the end of the compilation. I have
<classname>.o, obviously.
the fact is that I need a swt.lib file to get the linking, I suppose, but
I can't find the way to get it.
I tried to compile the swt.jar from the prompt but had no success.
any idea??
Re: swt.lib ?? [message #446704 is a reply to message #446636] Tue, 30 November 2004 21:26 Go to previous messageGo to next message
I've never used gcj, but I'll take a guess about the problem. Since SWT
has native code, you will need to link your executable with the library
that contains the native code. This is usually done by passing a .lib
file to the compiler. This file can be generated when the swt dll is
built (swt-win32-XXXX.dll). However, it is probably not distributed by
the SWT team, because normal users have no use for it.
That being said, I think you will have to try to rebuild the swt dll
yourself. The build might already generate a .lib for you. If not, you
will have to modify the linker options yourself to generate it.
Charlie
Camilla wrote:
> hi everybody
> to link the file so I have not an exe at the end of the compilation. I
> have <classname>.o, obviously.
> but I can't find the way to get it.
> any idea??
Re: swt.lib ?? [message #446705 is a reply to message #446704] Tue, 30 November 2004 22:20 Go to previous messageGo to next message
After poking around the gcj site a bit, I think my comment may have been
incorrect. It looks like you can place the JNI library on the command
line for linking. You were probably asking about how to compile all of
the SWT java files. Can't help you there.
Sorry for any confusion :)
Charlie
> Charlie
> Camilla wrote:
>> hi everybody
>> any idea??
Re: swt.lib ?? [message #446709 is a reply to message #446705] Wed, 01 December 2004 04:34 Go to previous messageGo to next message
Originally posted by: melko.gmx.at
try this:
make an build.bat with the following code and then it should make an exe
out of your java files easily.
@echo off
SETLOCAL
echo Name of the Main-Class...
set MAIN=Main
echo set the evironment-paths...
PATH C:\gcc\bin;C:\gcc\i686-pc-mingw32\bin;%PATH%
set SWT_DIR=C:\gcc\swt
>>>in this SWT_DIR you have the *.dll of SWT and the swt.jar
echo making dir...
if exist bin rmdir /S /Q bin
if exist obj rmdir /S /Q obj
if exist include rmdir /S /Q include
mkdir bin
cd bin
mkdir resources
cd ..
mkdir obj
mkdir include
echo Compiling to JAVA-Bytecode...
gcj -C -fCLASSPATH=bin;src -g0 -Os -d bin src\com\test\gui\*.java
gcj -C -fCLASSPATH=bin;src -g0 -Os -d bin src\com\test\gui\dialog\*.java
gcj -C -fCLASSPATH=bin;src -g0 -Os -d bin src\com\test\gui\functions\*.java
>>> here you set the path of your java files?! So it is your workspace!
echo make an *.jar archive...
xcopy /Q src\resources\*.* .\bin\resources >>>copy the ressources, if you
have
cd bin
jar cf %MAIN%.jar .\com\test\gui\*.class .\com\test\gui\dialog\*.class
\com\test\gui\functions\*.class .\resources\*.*
move %MAIN%.jar ..\include
cd ..
echo make an object...
gcj --classpath=obj;bin;%SWT_DIR%\swt.jar -fjni -g0 -Os -c
include\%MAIN%.jar -o obj\%MAIN%.o
>>> here you set the swt.jar into the exe plus the now generated main.jar
echo makes library...
cd obj
ar -crs lib%MAIN%.a *.o
move lib%MAIN%.a ..\include
cd ..
echo compiling the EXE-File...
gcj -mwindows --main=com.test.gui.%MAIN% -fjni -g0 -Os -s -o %MAIN%.exe
obj\*.o include\*.a -L%SWT_DIR% -lswt
echo give a name to the EXE...
if exist Test.exe del Test.exe
ren %MAIN%.exe Test.exe
echo.
echo Finished!
ENDLOCAL
pause
I hope I could help!
nice greatings from austria.
PS: You should delete in the source code the text that I have added with
>>> starting!!! Thanks
Re: swt.lib ?? [message #446710 is a reply to message #446709] Wed, 01 December 2004 04:57 Go to previous messageGo to next message
melko <melko@gmx.at> wrote:
BTW, do you know, how to link SWT DLL directly in EXE ?
I need to have single EXE, without additional DLL's.
And I am afraid that this is impossible. :-(
> try this:
> @echo off
> SETLOCAL
> set MAIN=Main
> echo making dir...
> mkdir bin
> cd bin
> mkdir resources
> cd ..
> mkdir obj
> mkdir include
> have
> cd bin
> cd ..
> cd obj
> cd ..
> echo.
> echo Finished!
> ENDLOCAL
> pause
>>>> starting!!! Thanks
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: swt.lib ?? [message #446712 is a reply to message #446710] Wed, 01 December 2004 05:16 Go to previous messageGo to next message
I dont understand what you mean, but if you make an EXE out of your JAVA
files with this gcj-compiler you need no extra DLLs or JAVA runtime
installed or something else. What you need is only one DLL that should be
with the EXE together and it is the "swt-win32-3063.dll" !! So your
Program consists only of an EXE-File and a single DLL?!?
Nice day.
>> try this:
>> @echo off
>> SETLOCAL
>> set MAIN=Main
>> PATH C:gccbin;C:gcci686-pc-mingw32bin;%PATH%
>> set SWT_DIR=C:gccswt
>> echo making dir...
>> mkdir bin
>> cd bin
>> mkdir resources
>> cd ..
>> mkdir obj
>> mkdir include
>> gcj -C -fCLASSPATH=bin;src -g0 -Os -d bin srccomtestgui*.java
>> gcj -C -fCLASSPATH=bin;src -g0 -Os -d bin srccomtestguidialog*.java
>> gcj -C -fCLASSPATH=bin;src -g0 -Os -d bin srccomtestguifunctions*.java
>> xcopy /Q srcresources*.* .binresources >>>copy the ressources, if you
>> have
>> cd bin
>> jar cf %MAIN%.jar .comtestgui*.class .comtestguidialog*.class
>> comtestguifunctions*.class .resources*.*
>> move %MAIN%.jar ..include
>> cd ..
>> gcj --classpath=obj;bin;%SWT_DIR%swt.jar -fjni -g0 -Os -c
>> include%MAIN%.jar -o obj%MAIN%.o
>> cd obj
>> move lib%MAIN%.a ..include
>> cd ..
>> obj*.o include*.a -L%SWT_DIR% -lswt
>> echo.
>> echo Finished!
>> ENDLOCAL
>> pause
>>>>> starting!!! Thanks
Re: swt.lib ?? [message #446714 is a reply to message #446712] Wed, 01 December 2004 08:20 Go to previous messageGo to next message
melko writes:
> be with the EXE together and it is the "swt-win32-3063.dll" !! So your
> Nice day.
What I need - just EXE-file, without even this single DLL.
When user clicks on application via Intranet, I can not pass two
files, only one (EXE).
I know about GCJ can use it to create EXE, but it still requires SWT DLL.
>>> try this:
>>> exe out of your java files easily.
>>> @echo off
>>> SETLOCAL
>>> set MAIN=Main
>>> echo making dir...
>>> mkdir bin
>>> cd bin
>>> mkdir resources
>>> cd ..
>>> mkdir obj
>>> mkdir include
>>> have
>>> cd bin
>>> cd ..
>>> cd obj
>>> cd ..
>>> %MAIN%.exe obj*.o include*.a -L%SWT_DIR% -lswt
>>> echo.
>>> echo Finished!
>>> ENDLOCAL
>>> pause
>>>>>> starting!!! Thanks
Re: swt.lib ?? [message #446715 is a reply to message #446714] Wed, 01 December 2004 08:50 Go to previous messageGo to next message
Yes thats right. You need this second file. I hope you can find the
solution for your problem.
I have an other prolem: I also work with gcj and I can make an EXE file
but my aplication needs a connection to a database so i search for the
database-driver dynamically like "Class.forName(klass).newInstance();" and
in eclipse it works fine but when I make the EXE file I cannot insolve the
driver jar so I cannot make a connection?!? Do you have an idea, if yes
could you post the source code. THANKS!!
Re: swt.lib ?? [message #446726 is a reply to message #446714] Wed, 01 December 2004 12:20 Go to previous messageGo to next message
Konstantin,
Have you considered using Java Web Start to deploy your application over the
internet?
Peter
Re: swt.lib ?? [message #446741 is a reply to message #446726] Thu, 02 December 2004 01:00 Go to previous messageGo to next message
Peter Skopek writes:
>> DLL.
> Konstantin,
> the internet?
Yes, but my users don't have Java installed.
In reality this application has goal to install other applications on
user's computer. Not only Java, it will install/update any application
on our enterprise.
SY, Konstantin.
Re: swt.lib ?? [message #446742 is a reply to message #446715] Thu, 02 December 2004 01:02 Go to previous messageGo to next message
melko writes:
>> SWT DLL.
> solution for your problem. I have an other prolem: I also work with gcj
> and I can make an EXE file but my aplication needs a connection to a
> database so i search for the database-driver dynamically like
> "Class.forName(klass).newInstance();" and in eclipse it works fine but
> when I make the EXE file I cannot insolve the driver jar so I cannot
> make a connection?!? Do you have an idea, if yes could you post the
You can try to have direct import of this class, i.e.
import com.provider.DriverClass;
SY, Konstantin.
Re: swt.lib ?? [message #446749 is a reply to message #446636] Thu, 02 December 2004 05:47 Go to previous messageGo to next message
check this out
http://www.molebox.com/
it should do what you need.
cheers,
radu
Camilla wrote:
> hi everybody
> any idea??
Re: swt.lib ?? [message #446805 is a reply to message #446749] Thu, 02 December 2004 10:37 Go to previous message
Way back in the bad old DOS days, all you needed was a single .EXE. Then we
advanced to .DLL's, .INI's etc. Now we are back to a single .EXE. That's
funny.
"Radu Racariu" <rracaru@k.ro> wrote in message
news:comrmu$b0h$1@www.eclipse.org...
> check this out
> cheers,
> radu
> Camilla wrote:
> > hi everybody
> > any idea??
Previous Topic:Using PNG with Alpha channel in SWT Widgets
Next Topic:cannot resolve ViewPart
Current Time: Thu Jul 24 23:28:23 EDT 2025
Powered by FUDForum. Page generated in 0.07280 seconds
