problem with JOGL in RCP [message #446505] |
Tue, 21 March 2006 07:52  |
Originally posted by: vze3gfkr.verizon.net
I am trying create a view in my RCP program that can display an opengl
view. I have the tried the code snippet 209 and everything works well.
however I cannot seem to get this to work under my RCP program. within
the view class I have added the following code under the
createPartControl method.
public void createPartControl(Composite parent) {
parent.setLayout(new FillLayout());
GLData data = new GLData ();
data.doubleBuffer = true;
final GLCanvas canvas = new GLCanvas(parent.getShell(), SWT.NONE, data);
canvas.setCurrent();
final GLContext
context=GLDrawableFactory.getFactory().createExternalGLConte xt();
initialize3DWindow(context,canvas); // initialize the 3D window
create3DWindow(context,canvas); // draw the 3D object
The code compiles fine but i don't see anything. Is there any code
examples on how to do this with RCP or any documentation. Any help would
be greatly appreciated.
thanks
Fintan Mac Cormack
Re: problem with JOGL in RCP [message #446654 is a reply to message #446652] |
Wed, 22 March 2006 15:57   |
you seem to be messing around with the Shell of Eclipse. The shell is a
the desktop-window of your eclipse rcp/ide. It's not a good idea to mess
around with it.
Have you tried to remove all these calls to the shell and just do the
following:
final GLCanvas canvas = new GLCanvas(parent, SWT.BORDER, data);
final GLContext
Note that I pass "parent" to the GLCanvas constructor, not
parent.getShell().
parent.getShell() is something you want to leave alone.
Stepan
fintan Mac Cormack wrote:
> Hi Dittmar
> I tried what you suggested but the view still does not display the 3D
> image. I am able to get the program to partially work by changing the
> code to the following.
> Shell shell = parent.getShell();
> shell.setLayout(parent.getLayout());
> final GLCanvas canvas = new GLCanvas(shell, SWT.BORDER, data);
> final GLContext
> shell.open();
> window
> However this messes up the remainder of the gui such as menubar coolbar
> etc. however i am able to see part of the 3D image. Also the code only
> works when i add the line
> shell.open();
> regards
> fintan
> Dittmar Steiner wrote:
>> Hi Finatan,
>> although I don't have experience with JOGL, in my oppinion it could be a
>> problem with the composite hierachy.
>> Please try to simply insert a Composite:
>> Composite top = new Composite(parent, SWT.NONE);
>> top.setLayout(new FillLayout());
>> But I may be totally wrong. I took this code from a project where I
>> create the content for an EditorPart.
>> best regards
>> Dittmar
Re: problem with JOGL in RCP [message #446655 is a reply to message #446654] |
Wed, 22 March 2006 16:34   |
Hi Stephen I tried your example but still no luck.
regards
fintan
Stepan Rutz wrote:
> around with it.
> following:
> final GLContext
> parent.getShell(). parent.getShell() is something you want to leave alone.
> Regards,
> Stepan
>> Hi Dittmar
>> final GLContext
>> shell.open();
>> window
>> coolbar etc. however i am able to see part of the 3D image. Also the
>> code only works when i add the line
>> shell.open();
>> regards
>> fintan
>>> Hi Finatan,
>>> be a problem with the composite hierachy.
>>> best regards
>>> Dittmar
FUDForum. Page generated in 0.06017 seconds
