Home » Eclipse Projects » Standard Widget Toolkit (SWT) » initial size of a tableviewer
initial size of a tableviewer [message #446571] |
Fri, 26 November 2004 12:14  |
Originally posted by: tom_edwards.gmx.net
Hi!
How can I set the initial size of a table viewer? I use a scrollable form
and inside this form I added a table viewer. Now I would like to set the
initial height of the table but what happens is that the whole table is
shown and the user has to scroll the whole form instead of the table.
So far I tried to set the size using
table.setSize(..) and table.setBounds(..) but nothing changed.
Does anyone know how the initial size of a table viewer can be set?
TIA, Tom
Re: initial size of a tableviewer [message #446577 is a reply to message #446571] |
Fri, 26 November 2004 12:34   |
You need to create a layout for the parent of the widgets in the scrolled
composite and depending on the type of that layout, you need to constrain
the height of the table. For example, below I have used a GridLayout:
public static void main (String [] args) {
Display display = new Display ();
Shell shell = new Shell (display);
shell.setLayout(new FillLayout());
ScrolledComposite sc = new ScrolledComposite(shell, SWT.H_SCROLL |
SWT.V_SCROLL);
Composite parent = new Composite(sc, SWT.NONE);
parent.setLayout(new GridLayout());
Table table = new Table(parent, SWT.BORDER);
GridData data = new GridData(SWT.FILL, SWT.TOP, true, false);
data.heightHint = 10 * table.getItemHeight();
table.setLayoutData(data);
for (int i = 0; i < 100; i++) {
TableItem item = new TableItem(table, SWT.NONE);
item.setText("item "+i);
for (int i = 0; i < 20; i++) {
Button b = new Button(parent, SWT.PUSH);
b.setText("Button "+i);
sc.setContent(parent);
sc.setExpandHorizontal(true);
sc.setExpandVertical(true);
sc.setMinSize(parent.computeSize(SWT.DEFAULT, SWT.DEFAULT));
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
"Tom Edwards" <tom_edwards@gmx.net> wrote in message
news:co7oac$4f0$1@www.eclipse.org...
> Hi!
> shown and the user has to scroll the whole form instead of the table. So
> TIA, Tom
Re: initial size of a tableviewer [message #446629 is a reply to message #446577] |
Tue, 30 November 2004 01:47   |
Hi Veronika,
Thanks for your answer. It works using the grid layout for the parent. My
table has the expected height. But the problem I have now is that the
table doesn't resize at all. What I would like to have is a table which
has as initial height the value I specify but which resizes while resizing
the scrolled form. How can I achieve this?
TIA, Tom
> SWT.V_SCROLL);
> shell.open ();
> display.dispose ();
>> Hi!
>> TIA, Tom
Re: initial size of a tableviewer [message #446694 is a reply to message #446629] |
Tue, 30 November 2004 13:12   |
Replace:
with:
GridData data = new GridData(SWT.FILL, SWT.FILL, true, true);
news:coh51u$rji$1@www.eclipse.org...
> Hi Veronika,
> TIA, Tom
>> | SWT.V_SCROLL);
>> shell.open ();
>> display.dispose ();
>>> Hi!
>>> form and inside this form I added a table viewer. Now I would like to
>>> set the initial height of the table but what happens is that the whole
>>> table is shown and the user has to scroll the whole form instead of the
>>> table. So far I tried to set the size using
>>> TIA, Tom
Re: resizing problem of table viewer in scrolled form [message #446745 is a reply to message #446694] |
Thu, 02 December 2004 04:40  |
Veronika,
Unfortunately your suggestion does not work im my case. I use a scrolled
form with TableWrapLayout. I could set the initial height but I have no
idea how to render the table viewer resizable. When I resize my form then
the table viewer size stays the same all the time.
I would appreciate it if you or someone else could give me a hint. Below
you can see the code I use:
ScrolledForm form = managedForm.getForm();
FormToolkit toolkit = managedForm.getToolkit();
Composite body = managedForm.getForm().getBody();
//crate layout of the body
TableWrapLayout layout = new TableWrapLayout();
layout.numColumns = 2;
TableWrapData wd = new TableWrapData();
wd.grabVertical = true;
wd.grabHorizontal = true;
body.setLayout(layout);
body.setLayoutData(wd);
//create the sections in the body
managedForm.addPart(createListSection());
in another class -> list section is created
DBEditorSection section = new DBEditorSection(
page, parent, Section.TITLE_BAR|Section.TWISTIE|Section.EXPANDED
section.setText("Collection Extent");
TableWrapData td = new
TableWrapData(TableWrapData.FILL_GRAB,TableWrapData.FILL_GRA B);
section.setLayoutData(td);
//create a composite for client area containing the collection member
table
Composite client = toolkit.createComposite(section);
client.setLayout(new GridLayout());
section.setClient(client);
//create table viewer
TableViewer collectionViewer = new TableViewer(
parent, SWT.FULL_SELECTION | SWT.V_SCROLL | SWT.H_SCROLL);
Table table = collectionViewer.getTable();
//set table layout data
GridData gridData = new GridData(SWT.FILL, SWT.FILL, true, true);
gridData.heightHint = 25 * table.getItemHeight();
gridData.grabExcessVerticalSpace = true;
table.setLayoutData(gridData);
> Replace:
> with:
>> Hi Veronika,
>> TIA, Tom
>>> | SWT.V_SCROLL);
>>> shell.open ();
>>> display.dispose ();
>>>> Hi!
>>>> TIA, Tom
Current Time: Thu Jul 24 22:35:41 EDT 2025
Powered by FUDForum. Page generated in 0.38517 seconds
