Forcing a table to scroll horizontally [message #446569] |
Fri, 26 November 2004 11:36  |
Originally posted by: olivier.larivain.criltechnology.com
I'm trying to implement a rectangle selection in a Table (just like the one
in the windows file explorer for example, when you drag the mouse with no
items under it), and i was wondering how i could force the table to scroll
horizontally (for when the user drags the mouse out of the client area).
I tried generating an Event (setting all fields to correct values) and
notifying a SelectionEvent to getHorizontalBar(), but that didn't seem to do
anything.
I also tried calling ScrollBar.setSelection(), it moves the scroll bar but
doesn't scroll the table (seems kind of logical though).
I search around, googlized a bit, but didn't find anything about forcing a
composite to scroll.
Since the vertical drag has been performed by using the setTopSelection
method, i'm completely running out of ideas on how i could scroll this
window.
I'd be glad if anyone could give me a clue on how to perform this.
Re: Forcing a table to scroll horizontally [message #446575 is a reply to message #446569] |
Fri, 26 November 2004 12:27   |
Use Table.showColumn(TableColumn);
If you need more control than that, then maybe consider placing the Table in
a ScrolledComposite and use ScrolledComposite.setOrigin(Point)
"Larivain Olivier" <olivier.larivain@criltechnology.com> wrote in message
news:co7m27$vof$1@www.eclipse.org...
> one
> do
> anything.
> window.
FUDForum. Page generated in 0.04193 seconds
