Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Get the size of a view
Get the size of a view [message #446387] Wed, 24 November 2004 05:27 Go to next message
Hi!
In a view i want to display a content, which might be larger than the
visible area of the view. I use a ScrolledComposite which has the method
setMinSize() where you can set the minimal Size at which Scrollbars
should be shown. The only way i see is to giveMinSize the dimension of
the view.
Is there some way to get the current dimension of a view?
Thanks in advance.
Kai
(I am using Eclipse 3.1 on W2k)
Re: Get the size of a view [message #446403 is a reply to message #446387] Wed, 24 November 2004 10:40 Go to previous messageGo to next message
You should give setMinSize the preferred size of the contents of the
ScrolledComposite not the parent of teh ScrolledComposite. The View is the
parent.
See the example from the class javadoc for ScrolledComposite:
// set the minimum width and height of the scrolled content - method 2
final ScrolledComposite sc2 = new ScrolledComposite(shell, SWT.H_SCROLL |
SWT.V_SCROLL | SWT.BORDER);
sc2.setExpandHorizontal(true);
sc2.setExpandVertical(true);
final Composite c2 = new Composite(sc2, SWT.NONE);
sc2.setContent(c2);
c2.setBackground(blue);
layout = new GridLayout();
layout.numColumns = 4;
c2.setLayout(layout);
Button b2 = new Button (c2, SWT.PUSH);
b2.setText("first button");
sc2.setMinSize(c2.computeSize(SWT.DEFAULT, SWT.DEFAULT));
"Kai" <junkworld@gmx.de> wrote in message
news:co1nm7$3jr$1@www.eclipse.org...
> Hi!
> setMinSize() where you can set the minimal Size at which Scrollbars should
> be shown. The only way i see is to giveMinSize the dimension of the view.
> Thanks in advance.
> Kai
Re: Get the size of a view [message #446405 is a reply to message #446403] Wed, 24 November 2004 11:39 Go to previous messageGo to next message
Thanks for your reply Veronika, but seems it doesn`t work correct in my
case. I am developing an eclipse plugin, my content is created
dymnamicly and after that, i want to decide if scrollbars are needed.
The composite which represents the content, includes other composites.
When i try to use something like
the whole content is displayed, but now scrollbars are shown. I could
see my the content which is to large for the visible area, when resize
the view.
Is it possible that a view has a different behavior in this case then a
normal window?
If i use getClientArea() on a composite in my view, i get the visible
area of the view. I tried to use setSize on my ScrolledComposite and
then use setMinSize(), but i doesen't seems to work, too.
Any idea?
> parent.
> sc2.setContent(c2);
>>Hi!
>>Thanks in advance.
>>Kai
Re: Get the size of a view [message #446414 is a reply to message #446405] Wed, 24 November 2004 13:02 Go to previous messageGo to next message
Views work the same as any other SWT Composite. Please give a code example
showing your problem.
news:co2dff$jv2$1@www.eclipse.org...
> case. I am developing an eclipse plugin, my content is created dymnamicly
> and after that, i want to decide if scrollbars are needed. The composite
> the whole content is displayed, but now scrollbars are shown. I could see
> my the content which is to large for the visible area, when resize the
> view.
> normal window?
> If i use getClientArea() on a composite in my view, i get the visible area
> of the view. I tried to use setSize on my ScrolledComposite and then use
> Any idea?
>> the parent.
>> sc2.setContent(c2);
>>>Hi!
>>>the view.
>>>Thanks in advance.
>>>Kai
Re: Get the size of a view [message #446421 is a reply to message #446414] Wed, 24 November 2004 13:29 Go to previous messageGo to next message
viewComposite = new ScrolledComposite(parent, SWT.V_SCROLL | SWT.H_SCROLL );
viewComposite.setExpandHorizontal(true);
viewComposite.setExpandVertical(true);
commandComposite = new Composite (viewComposite,SWT.NONE);
commandComposite.setLayout(new GridLayout(1, false));
commandComposite.setLayoutData(new GridData());
viewComposite.setContent(commandComposite);
//dynamic add composites to commandComposite
viewComposite.setMinSize(commandComposite.computeSize(SWT.DE FAULT,
SWT.DEFAULT));
// i tried this, but it seems to have no effect
//viewComposite.setSize(viewComposite.getClientArea().width, viewComposite.getClientArea().height);
commandComposite.layout(true);
viewComposite.layout(true);
parent.layout(true);
>>view.
>>normal window?
>>Any idea?
>>>the parent.
>>>sc2.setContent(c2);
>>>>Hi!
>>>>the view.
>>>>Thanks in advance.
>>>>Kai
Re: Get the size of a view [message #446463 is a reply to message #446421] Thu, 25 November 2004 07:17 Go to previous message
OK i figured it out, in my code was missing:
viewComposite.setLayoutData(new GridData(GridData.FILL_VERTICAL));
which seems to be necessary.
> SWT.H_SCROLL );
> SWT.DEFAULT));
>> example showing your problem.
>>> my case. I am developing an eclipse plugin, my content is created
>>> resize the view.
>>> a normal window?
>>> Any idea?
>>>> is the parent.
>>>> SWT.H_SCROLL | SWT.V_SCROLL | SWT.BORDER);
>>>> sc2.setContent(c2);
>>>>> Hi!
>>>>> the visible area of the view. I use a ScrolledComposite which has
>>>>> the method setMinSize() where you can set the minimal Size at which
>>>>> Scrollbars should be shown. The only way i see is to giveMinSize
>>>>> Thanks in advance.
>>>>> Kai
Previous Topic:GCC & MinGW How to compile a user library
Next Topic:how to remove a Combo from a Group
Current Time: Wed Jul 23 20:40:51 EDT 2025
Powered by FUDForum. Page generated in 0.26625 seconds
