Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Program.findProgram() returns null
Program.findProgram() returns null [message #446262] Mon, 22 November 2004 19:00 Go to next message
Hello everybody
I need to open PDF files from an SWT application, but I also would like
to inform the user that he/she needs a program such as Adobe Reader to
open PDF files if no such program is registered for the extension "pdf".
However, the method Program.findProgram("pdf") often returns null even
if there is a program associated with PDF files. The problem mainly
occurs on Windows 2000 and Linux.
Dani had the same problem with HTML files as mentioned in bug 71228:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=71228
Could anyone please give me a hint on how to solve this problem? Might
this get fixed anytime soon? Are there any alternatives on how to open a
PDF file from within an SWT application? I'd rather not use
java.lang.Runtime#exec.
Thanks in advance for any help on how I could solve this problem.
Christian
Re: Program.findProgram() returns null [message #446264 is a reply to message #446262] Mon, 22 November 2004 22:12 Go to previous messageGo to next message
Originally posted by: wkrain.hotmail.com
"Christian Hauser" <c.hauser@active.ch> wrote in message
news:cntujm$j3q$1@www.eclipse.org...
> Hello everybody
> Christian
Re: Program.findProgram() returns null [message #446265 is a reply to message #446262] Mon, 22 November 2004 22:18 Go to previous messageGo to next message
Hi buddy
I can give mw a hint on how to slov this problem,There are an
alternatives on how to open a PDF file from within
an swt application. I need point this mentod is great way to slove your
problem.
You can integrate Activex into SWT application. For example
public class PDFViewer extends ApplicationWindow
private OleControlSite site;
private OleAutomation auto;
public PDFViewer()
super(null);
this.addMenuBar();
protected Control createContents(Composite parent)
Shell shell = this.getShell();
shell.setText("PDF Viewer");
shell.setSize(500, 450);
OleFrame frame = new OleFrame(shell, SWT.NONE);
try
site = new OleControlSite(frame, SWT.NONE, "PDF.PdfCtrl.5");
auto = new OleAutomation(site);
public void showPdfControl()
site.doVerb(OLE.OLEIVERB_SHOW);
public void loadFile(String file)
showPdfControl();
int[] rgdispid = auto.getIDsOfNames(newString[]{"LoadFile"});
int dispIdMember = rgdispid[0];
Variant[] rgvarg = new Variant[1];
rgvarg[0] = new Variant(file);
Variant pVarResult =auto.invoke(dispIdMember,rgvarg);
I hope so this article will help you slove your problem!
> Hello everybody
> Christian
Re: Program.findProgram() returns null [message #446290 is a reply to message #446265] Tue, 23 November 2004 02:55 Go to previous messageGo to next message
Thanks a lot for your code. I'll try that. However, as this seems to be
a Windows-only solution I'm not sure whether I'll go for it.
Christian
wkrain wrote:
> Hi buddy
> problem.
> public PDFViewer()
> super(null);
> this.addMenuBar();
> try
> showPdfControl();
>>Hello everybody
>>Christian
Re: Program.findProgram() returns null [message #652029 is a reply to message #446290] Wed, 02 February 2011 08:46 Go to previous message
I want to migrate a RCP to eclipse RAP.
I can not find equivalent code for
Program.findProgram, Program.launch
I also fase problem in porting E4(dia inject) part of code
Can some one help.
regards
Parvez Ahmad Hakim
www.abobjects.com
Previous Topic:how to sort ComboBoxCellEditor in a table
Next Topic:migrating RCP to RAP
Current Time: Sat Jul 26 21:26:18 EDT 2025
Powered by FUDForum. Page generated in 0.11773 seconds
