Program.findProgram() returns null [message #446262] |
Mon, 22 November 2004 19:00  |
Hello everybody
I need to open PDF files from an SWT application, but I also would like
to inform the user that he/she needs a program such as Adobe Reader to
open PDF files if no such program is registered for the extension "pdf".
However, the method Program.findProgram("pdf") often returns null even
if there is a program associated with PDF files. The problem mainly
occurs on Windows 2000 and Linux.
Dani had the same problem with HTML files as mentioned in bug 71228:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=71228
Could anyone please give me a hint on how to solve this problem? Might
this get fixed anytime soon? Are there any alternatives on how to open a
PDF file from within an SWT application? I'd rather not use
java.lang.Runtime#exec.
Thanks in advance for any help on how I could solve this problem.
Christian
Re: Program.findProgram() returns null [message #446290 is a reply to message #446265] |
Tue, 23 November 2004 02:55   |
Thanks a lot for your code. I'll try that. However, as this seems to be
a Windows-only solution I'm not sure whether I'll go for it.
Christian
wkrain wrote:
> Hi buddy
> I can give mw a hint on how to slov this problem,There are an
> alternatives on how to open a PDF file from within
> an swt application. I need point this mentod is great way to slove your
> problem.
> You can integrate Activex into SWT application. For example
> public class PDFViewer extends ApplicationWindow
> private OleControlSite site;
> private OleAutomation auto;
> public PDFViewer()
> super(null);
> this.addMenuBar();
> protected Control createContents(Composite parent)
> Shell shell = this.getShell();
> shell.setText("PDF Viewer");
> shell.setSize(500, 450);
> OleFrame frame = new OleFrame(shell, SWT.NONE);
> try
> site = new OleControlSite(frame, SWT.NONE, "PDF.PdfCtrl.5");
> auto = new OleAutomation(site);
> public void showPdfControl()
> site.doVerb(OLE.OLEIVERB_SHOW);
> public void loadFile(String file)
> showPdfControl();
> int[] rgdispid = auto.getIDsOfNames(newString[]{"LoadFile"});
> int dispIdMember = rgdispid[0];
> Variant[] rgvarg = new Variant[1];
> rgvarg[0] = new Variant(file);
> Variant pVarResult =auto.invoke(dispIdMember,rgvarg);
> I hope so this article will help you slove your problem!
> "Christian Hauser" <c.hauser@active.ch> wrote in message
> news:cntujm$j3q$1@www.eclipse.org...
>>Hello everybody
>>Christian
Re: Program.findProgram() returns null [message #652029 is a reply to message #446290] |
Wed, 02 February 2011 08:46  |
I want to migrate a RCP to eclipse RAP.
I can not find equivalent code for
Program.findProgram, Program.launch
I also fase problem in porting E4(dia inject) part of code
Can some one help.
regards
Parvez Ahmad Hakim
www.abobjects.com
FUDForum. Page generated in 0.47848 seconds
