Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Table doesn't stretch to fit window
Table doesn't stretch to fit window [message #446261] Mon, 22 November 2004 17:42 Go to next message
Originally posted by: ukalumni.hotmail.com
I've got a class to define a table. I make the following calls:
FaxListTable flt = new FaxListTable();
flt.addFaxTable(composite);
FaxListTable.addFaxTable(Composite composite) looks like this:
protected Control addFaxTable(Composite parent){
Composite composite = new Composite(parent, SWT.NONE);
composite.setLayout(new GridLayout(1, false));
final TableViewer tv = new TableViewer(composite, SWT.FULL_SELECTION);
tv.setContentProvider(new FaxTableContentProvider());
tv.setLabelProvider(new FaxTableLabelProvider());
tv.setInput(faxes);
Table table = tv.getTable();
table.setLayoutData(new GridData(GridData.FILL_BOTH));
new TableColumn(table, SWT.CENTER).setText(FILE_NAME);
new TableColumn(table, SWT.CENTER).setText(ORDER_DATE);
new TableColumn(table, SWT.CENTER).setText(STATUS);
new TableColumn(table, SWT.CENTER).setText(USER);
for(int i = 0, n = table.getColumnCount(); i < n; i++)
table.getColumn(i).pack();
table.setHeaderVisible(true);
table.setLinesVisible(true);
tv.setColumnProperties(props);
tv.refresh();
composite.pack();
return composite;
I get the table, but it doesn't stretch to the full size of the parent
composite, and it doesn't respond if I resize the parent composite.
Anyone see something I'm missing?
--Michael
Re: Table doesn't stretch to fit window [message #446294 is a reply to message #446261] Tue, 23 November 2004 04:02 Go to previous messageGo to next message
Hi Michael,
check out SwtForms layout manager (http://ffxml.net/swtforms/).
Since I use this one I have no need to use any build-in manager.
SwtForms is derived from a Swing layout manager. If you can't
find the docs, check out JGoodies Forms
(http://www.jgoodies.com/downloads/libraries.html).
Suppose your table's the only component in the view/dialog the
following might accomplish what you want:
import net.ffxml.swtforms.builder.PanelBuilder;
import net.ffxml.swtforms.layout.CellConstraints;
import net.ffxml.swtforms.layout.FormLayout;
public void createPartControl(Composite parent) {
Composite contents = new Composite(parent, SWT.NONE);
final String columnSpec = "fill:pref:grow";
final String rowSpec = "fill:pref:grow";
FormLayout layout = new FormLayout(columnSpec, rowSpec);
CellConstraints cc = new CellConstraints();
PanelBuilder builder = new PanelBuilder(contents, layout);
TableViewer viewer = new TableViewer(contents, SWT.BORDER);
builder.add(viewer.getControl(), cc.xy(1, 1));
Hope this helps,
Horst
"Michael Molloy" <ukalumni@hotmail.com> schrieb im Newsbeitrag
news:cntq8n$d00$1@www.eclipse.org...
> tv.setInput(faxes);
> tv.refresh();
> composite.pack();
> return composite;
> --Michael
Re: Table doesn't stretch to fit window [message #446338 is a reply to message #446294] Tue, 23 November 2004 09:21 Go to previous messageGo to next message
Thanks for the suggestion. I may look into it, but for the time being, I
would really like to get this working without introducing something else
new into my code.
The problem is that I can find no way to successfully call
composite.setLayoutData(new GridData(GridData.FILL_HORIZONTAL)) on the
composite that contains my table.
The table stretches to fill the composite it is sitting in, but that
composite doesn't fill it's parent composite. Whenever I try setting the
layoutData on the table's composite, I get the following error:
Not a button: java.lang.ClassCastException
and a stacktrace.
--Michael
Horst Dehmer wrote:
> Hi Michael,
Re: Table doesn't stretch to fit window [message #446339 is a reply to message #446338] Tue, 23 November 2004 09:30 Go to previous messageGo to next message
One more update. I tried removing the table from it's own composite and
stuck it in the parent composite, but I'm still getting the same
exception listed below.
Any ideas, anyone?
--Michael
> new into my code.
> and a stacktrace.
> --Michael
> Horst Dehmer wrote:
>> Hi Michael,
Re: Table doesn't stretch to fit window--SOLVED [message #446340 is a reply to message #446339] Tue, 23 November 2004 09:44 Go to previous messageGo to next message
Apparently you can't put a Table into a composite that uses a RowLayout
*and* call setLayoutData(new GridData(GridData.FILL_HORIZONTAL)) on one
of the controls in the composite (or a child composite, as it turns out).
If I removed the TableViewer.setLayoutData call, the table appears as
expected, and it doesn't stretch with the window, also as expected.
However, uncommenting the setLayoutData line causes it to crash.
Is this a bug or a limitation of RowLayout somehow?
--Michael
> Any ideas, anyone?
> --Michael
>> I would really like to get this working without introducing something
>> else new into my code.
>> the layoutData on the table's composite, I get the following error:
>> and a stacktrace.
>> Thanks,
>> --Michael
>> Horst Dehmer wrote:
>>> Hi Michael,
Re: Table doesn't stretch to fit window--SOLVED [message #446356 is a reply to message #446340] Tue, 23 November 2004 13:42 Go to previous messageGo to next message
RowLayout uses RowData and GridLayout uses GridData. You can not mix the
two together. The layout on the parent composite must match the layout data
on the immediate children in that composite.
If you change the layout on the parent composite to GridLayout, then you can
use GridData.
If you only have one child in the parent composite and you want the child to
take up all of the room and be stretched you could just use FillLayout which
requires no data.
is equal to:
composite.setLayout(new FillLayout());
"Michael Molloy" <ukalumni@hotmail.com> wrote in message
news:cnvik0$9h5$1@www.eclipse.org...
> *and* call setLayoutData(new GridData(GridData.FILL_HORIZONTAL)) on one of
> --Michael
>> Any ideas, anyone?
>> Thanks,
>> --Michael
>>> new into my code.
>>> and a stacktrace.
>>> Thanks,
>>> --Michael
>>> Horst Dehmer wrote:
>>>> Hi Michael,
Re: Table doesn't stretch to fit window--SOLVED [message #446368 is a reply to message #446356] Tue, 23 November 2004 16:34 Go to previous message
My fault. I suspected it was something I was missing. Thanks very much.
--M
> use GridData.
> requires no data.
> is equal to:
>>Thanks,
>>--Michael
>>>Any ideas, anyone?
>>>Thanks,
>>>--Michael
>>>>new into my code.
>>>>and a stacktrace.
>>>>Thanks,
>>>>--Michael
>>>>Horst Dehmer wrote:
>>>>>Hi Michael,
Previous Topic:StylePad/Wordpad app/plugin
Next Topic:Vertical scroll bar for Text control
Current Time: Sun Jul 27 09:30:18 EDT 2025
Powered by FUDForum. Page generated in 0.04277 seconds
