Home » Eclipse Projects » Standard Widget Toolkit (SWT) » UnsatisfiedLinkError in "Welcome" cheatsheet Standalone SWT app
UnsatisfiedLinkError in "Welcome" cheatsheet Standalone SWT app [message #446168] Thu, 18 November 2004 13:58 Go to next message
Originally posted by: news.lawshouse.org
Eclipse 3.0.0 under Windows XP.
I have (as far as I can see) followed the instructions in the cheat
sheet for "Standalone SWT Application" but I have the following error on
running it:
java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path
I have coded
-Djava.library.path=${system:ECLIPSE_HOME}/plugins/org.eclip se.swt.${system:WS}_3.0.0/os/${system:OS}/${system:ARCH}
in the "arguments" box (and various other variants of it including hard
path names), and verified that
C:\USR\eclipse\plugins\org.eclipse.swt.win32_3.0.0\os\win32\ x86\swt-win32-3062.dll
does actually exist in my system.
I've also Googled for the error and found only the advice to put in the
-D parameter, which I have already.
Can someone suggest somewhere else I might look for an error?
Re: UnsatisfiedLinkError in "Welcome" cheatsheet Standalone SWT app [message #446195 is a reply to message #446168] Fri, 19 November 2004 17:09 Go to previous messageGo to next message
Henry,
At least one of the variables that you're referencing was not defined in the
3.0 release. You should either upgrade to a 3.1 stream build, or hardcode
your java.library.path value.
Grant
"Henry Law" <news@lawshouse.org> wrote in message
news:cnircu$ol6$1@www.eclipse.org...
> running it:
> I have coded
62.dll
Re: UnsatisfiedLinkError in "Welcome" cheatsheet Standalone SWT app [message #446228 is a reply to message #446168] Sat, 20 November 2004 15:38 Go to previous message
Henry Law wrote:
> I have coded
.... but I'd coded it in the wrong place. When I put it in "VM
arguments" rather than "application arguments" everything worked fine.
Previous Topic:SwtFox 3.0beta3 released (FAST swt port)
Next Topic:is there any methods in swt like JComponent.processKeyEvent(KeyEvent e) ?
Current Time: Sat Jul 26 03:21:54 EDT 2025
Powered by FUDForum. Page generated in 0.08194 seconds
