Home » Eclipse Projects » Standard Widget Toolkit (SWT) » setWidth for ToolItem in ToolBar does not function as expected
setWidth for ToolItem in ToolBar does not function as expected [message #445450] Fri, 05 November 2004 17:26 Go to next message
Originally posted by: martin_hulth.hotmail.com
Background:
I have a vertical ToolBar with three items in it. I try to set the width
of all ToolItems equal to the maximum width using two for loops, and
they always revert back to the default minimum width.
Example:
Add an item to a toolbar and set the width, then print the width to test
if it was set...
// composite declared previously
ToolBar toolbar = new ToolBar (composite, SWT.VERTICAL);
ToolItem item = new ToolItem (toolbar , SWT.NONE);
addProtocolItem.setText ("Item");
addProtocolItem.setWidth(60);
System.out.println(addProtocolItem.getWidth());
This outputs "33" instead of "60". setWidth() does not behave as
expected. Any insight is appreciated.
Thank you.
Martin
Re: setWidth for ToolItem in ToolBar (code revised) [message #445451 is a reply to message #445450] Fri, 05 November 2004 17:42 Go to previous messageGo to next message
Martin Hulth wrote:
> Background:
> Example:
> if it was set...
> ToolItem item = new ToolItem (toolbar, SWT.NONE);
> item.setText ("Item");
> item.setWidth(60);
> System.out.println(item.getWidth());
> Thank you.
> Martin
Re: setWidth for ToolItem in ToolBar (code revised) [message #445474 is a reply to message #445451] Fri, 05 November 2004 19:15 Go to previous message
Martin,
ToolItem.setWidth(int) only applies to ToolItems of type SWT.SEPARATOR.
(ToolItem's javadoc was just updated last week to make this more clear).
Grant
"Martin Hulth" <martin_hulth@hotmail.com> wrote in message
news:cmgvk4$5mi$1@eclipse.org...
> Martin Hulth wrote:
> > Background:
> > Example:
> > if it was set...
> > item.setWidth(60);
> > Thank you.
> > Martin
Previous Topic:Color and dispose
Next Topic:Flat Look Design
Current Time: Sat Jul 19 04:03:09 EDT 2025
Powered by FUDForum. Page generated in 0.03715 seconds
