Home » Eclipse Projects » Standard Widget Toolkit (SWT) » set cursor to Sash from SashForm
set cursor to Sash from SashForm [message #445333] Tue, 02 November 2004 10:50 Go to next message
Originally posted by: mania.sigma.ispras.ru
Hello.
How can I change cursor to SWT.CURSOR_SIZEN when it is possible to make
resize in SashForm?
Is there any possibility to set cursor to Sash from SashForm?
Maria.
Re: set cursor to Sash from SashForm [message #445370 is a reply to message #445333] Thu, 04 November 2004 09:13 Go to previous messageGo to next message
The Sash changes the cursor as required without programmatic intervention.
Why are you trying to change the cursor yourself?
"Maria Yurchenko" <mania@sigma.ispras.ru> wrote in message
news:cm8anh$h1m$1@eclipse.org...
> Hello.
> resize in SashForm?
> Maria.
Re: set cursor to Sash from SashForm [message #445372 is a reply to message #445370] Thu, 04 November 2004 09:35 Go to previous messageGo to next message
Hi, Veronika.
I have the following code.
SashForm sashForm = new SashForm(shell, SWT.VERTICAL);
sashForm.SASH_WIDTH = 4;
GridData gd2 = new GridData(GridData.FILL_BOTH);
sashForm.setLayoutData(gd2);
final Composite composite = new Composite(sashForm, SWT.NONE |
SWT.BORDER);
textEditor = new TextEditor(this);
textEditor.createContents(composite);
composite.setLayoutData(new GridData(GridData.FILL_BOTH));
TabsFolder tabs = new TabFolder(sashForm, SWT.NONE);
GridData gd = new GridData(GridData.FILL_HORIZONTAL);
gd.heightHint = 150;
tabs.setLayoutData(gd);
//creating tabs here ...
//some other components added here
shell.pack();
shell.open();
I can resize my components but Cursor doesn't change at all.
Maybe I need to do something else to make it change?
Maria.
>>Hello.
>>resize in SashForm?
>>Thanks,
>>Maria.
Re: set cursor to Sash from SashForm [message #445414 is a reply to message #445372] Fri, 05 November 2004 06:55 Go to previous messageGo to next message
Some of the layouts in your code are incorrect. I modified it slightly in
the example below and the example works fine for me (used Text instead of
TextEditor but that should not matter).
public static void main (String [] args) {
Display display = new Display ();
Shell shell = new Shell (display);
shell.setLayout (new GridLayout ());
SashForm sashForm = new SashForm (shell, SWT.VERTICAL);
GridData gd2 = new GridData (GridData.FILL_BOTH);
sashForm.setLayoutData (gd2);
final Composite composite = new Composite (sashForm, SWT.NONE |
SWT.BORDER);
composite.setLayout (new FillLayout ()); // !!!!! REQUIRED
Text textEditor = new Text (composite, SWT.BORDER);
//textEditor = new TextEditor(this);
//textEditor.createContents(composite);
//composite.setLayoutData(new GridData(GridData.FILL_BOTH)); // !!!!
HAS NO EFFECT
TabFolder tabs = new TabFolder (sashForm, SWT.NONE);
for (int i = 0; i < 10; i++) {
TabItem item = new TabItem (tabs, SWT.NONE);
item.setText ("TabItem " + i);
//GridData gd = new GridData(GridData.FILL_HORIZONTAL);
//gd.heightHint = 150;
//tabs.setLayoutData(gd); // !!!! HAS NO EFFECT
shell.pack ();
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
news:cmdf0s$cuk$1@eclipse.org...
> Hi, Veronika.
> SWT.BORDER);
> shell.pack();
> shell.open();
> Maria.
>> intervention. Why are you trying to change the cursor yourself?
>>>Hello.
>>>resize in SashForm?
>>>Thanks,
>>>Maria.
Re: set cursor to Sash from SashForm [message #445792 is a reply to message #445414] Thu, 11 November 2004 08:07 Go to previous messageGo to next message
Hi again.
And what is the requerement?
Here is code of creating one of tabs.
What is wrong with it? Can I add such tab (with GridData and GridLayout)
into tab?
private Control createLogTab(Composite parent) {
final Composite composite = new Composite(parent, SWT.NONE);
GridData gd = new GridData();
gd.horizontalSpan = 10;
gd.horizontalAlignment = GridData.FILL;
gd.grabExcessHorizontalSpace = true;
gd.verticalAlignment = GridData.FILL;
gd.grabExcessVerticalSpace = true;
composite.setLayoutData(gd);
composite.setLayout(new GridLayout(1, false));
logView = new LogView();
logView.createPartControl(composite);
return composite;
Maria.
> SWT.BORDER);
> HAS NO EFFECT
> shell.pack ();
> shell.open ();
> display.dispose ();
>>Hi, Veronika.
>>SWT.BORDER);
>> shell.pack();
>> shell.open();
>>Maria.
>>>>Hello.
>>>>resize in SashForm?
>>>>Thanks,
>>>>Maria.
Re: set cursor to Sash from SashForm [message #445794 is a reply to message #445414] Thu, 11 November 2004 08:50 Go to previous messageGo to next message
One more thing...
I've set shell's cursor sometimes. I have some kind of runner - while it
is working I need to change cursor of shell to SWT.CURSOR_WAIT. After
runner stops I've set cursor of shell to SWT.CURSOR_ARROW back.
Cursor of Sash stopped to change itself after setting of shell cursor
(to resizable I mean).
So is there any possibility to change cursor of shell with no bad effect
on Sash cursor changing mechanizm?
Maria.
> SWT.BORDER);
> HAS NO EFFECT
> shell.pack ();
> shell.open ();
> display.dispose ();
>>Hi, Veronika.
>>SWT.BORDER);
>> shell.pack();
>> shell.open();
>>Maria.
>>>>Hello.
>>>>resize in SashForm?
>>>>Thanks,
>>>>Maria.
Re: set cursor to Sash from SashForm [message #445900 is a reply to message #445794] Thu, 11 November 2004 12:14 Go to previous messageGo to next message
When you set the cursor back you should call:
shell.setCursor (null)
This resets the cursor to the Operating System's control. Setting the value
to SWT.CURSOR_ARROW still means you are controlling the cursor.
news:cmvqvp$49l$1@eclipse.org...
> One more thing...
> Cursor of Sash stopped to change itself after setting of shell cursor (to
> resizable I mean).
> Maria.
>> in the example below and the example works fine for me (used Text instead
>> of TextEditor but that should not matter).
>> SWT.BORDER);
>> !!!! HAS NO EFFECT
>> shell.pack ();
>> shell.open ();
>> display.dispose ();
>>>Hi, Veronika.
>>> SWT.BORDER);
>>> shell.pack();
>>> shell.open();
>>>Maria.
>>>>>Hello.
>>>>>resize in SashForm?
>>>>>Thanks,
>>>>>Maria.
Re: set cursor to Sash from SashForm [message #445902 is a reply to message #445900] Thu, 11 November 2004 12:40 Go to previous message
It works perfectly.
Thank you.
It was real huge help.
Maria.
>>One more thing...
>>resizable I mean).
>>Thanks,
>>Maria.
>>>SWT.BORDER);
>>>!!!! HAS NO EFFECT
>>> shell.pack ();
>>> shell.open ();
>>> display.dispose ();
>>>>Hi, Veronika.
>>>>SWT.BORDER);
>>>> shell.pack();
>>>> shell.open();
>>>>Maria.
>>>>>>Hello.
>>>>>>resize in SashForm?
>>>>>>Thanks,
>>>>>>Maria.
Previous Topic:how to add image in Eclipse status bar
Next Topic:composite.setVisible(false) taking up space
Current Time: Wed Jul 23 04:06:28 EDT 2025
Powered by FUDForum. Page generated in 0.52188 seconds
