Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Focus problem on Mac
Focus problem on Mac [message #444670] Wed, 20 October 2004 05:45 Go to next message
I have a problem with FocusListener behaviour on Mac (OS X 10.3.5 and
Eclipse 3.1).
See my problem in the example below.
I use a FocusListener on Text widget text1 and I display a message in the
focusLost method.
If the focus is currently on text1 and I click on the button, this message
does not appear, whereas it works fine with Linux.
Any suggestion ?
Helene
Re: Focus problem on Mac [message #445093 is a reply to message #444670] Mon, 25 October 2004 15:33 Go to previous messageGo to next message
Buttons don't take focus when clicked on the Mac?
"H.ORTIZ" <xxx@xxx.com> wrote in message news:cl5c3a$u2o$1@eclipse.org...
> Eclipse 3.1).
> focusLost method.
> Any suggestion ?
> Thanks
> Helene
Re: Focus problem on Mac [message #445323 is a reply to message #444670] Tue, 02 November 2004 07:28 Go to previous messageGo to next message
On 20.10.2004 11:45 Uhr, in article cl5c3a$u2o$1@eclipse.org, "H.ORTIZ"
<xxx@xxx.com> wrote:
> Eclipse 3.1).
> focusLost method.
> Any suggestion ?
This seems to be the correct behavior on MacOS X (but I couldn't verify it
with Apple's HI Guidelines).
If you "turn on full keyboard access" on the "Keyboard Shortcuts" page of
the "Keyboard & Mouse" preference panel, you can better see the control that
has focus.
Now in any Apple application (e.g. Finder) open a dialog that has both a
text field and a button (e.g. "Connect to Server" in Go menu), click into
text field. Then click onto "+" button. Observe that focus isn't removed
from text field.
If you use the Tab key, you can assign focus to buttons too (and focus is
removed correctly from the text field).
--andre
Re: Focus problem on Mac [message #445378 is a reply to message #445093] Thu, 04 November 2004 11:35 Go to previous messageGo to next message
Hi Steve,
Sorry for my late answer (and my english too !) but I've just found it.
My problem is that I need to capture focus lost events on each of my Text
controls, howeover, on Mac, this event isn't triggered if I click on a
button, without leaving the Text control with TAB.
>> Hi,
>> Eclipse 3.1).
>> focusLost method.
>> Any suggestion ?
>> Thanks
>> Helene
Re: Focus problem on Mac [message #445383 is a reply to message #445378] Thu, 04 November 2004 13:04 Go to previous messageGo to next message
.... because focus doesn't actually leave the Text control. Is the blinking
i-beam still in the text control after the button is clicked? If so, the
Text control still has focus.
"H.ORTIZ" <hortiz@objetdirect.com> wrote in message
news:cmdlp2$ufa$1@eclipse.org...
> Hi Steve,
> >> Hi,
> >> Eclipse 3.1).
the
> >> focusLost method.
message
> >> Any suggestion ?
> >> Thanks
> >> Helene
Re: Focus problem on Mac [message #1798477 is a reply to message #445383] Mon, 19 November 2018 11:21 Go to previous messageGo to next message
Did you ever found a solution to this? I'm having the same issue.
Re: Focus problem on Mac [message #1798479 is a reply to message #445383] Mon, 19 November 2018 11:29 Go to previous message
Previous Topic:SWT in Java WebStart App stopped working on OSX after upgrading to Java 7
Next Topic:Eclipse crashes with ACCESS VIOLATION exception
Current Time: Tue Jul 29 01:34:46 EDT 2025
Powered by FUDForum. Page generated in 0.26313 seconds
