Home » Eclipse Projects » Standard Widget Toolkit (SWT) » sorry, I ask this question again.
sorry, I ask this question again. [message #445264] |
Sun, 31 October 2004 22:48  |
Originally posted by: liankun_mail.21cn.com
Good day all:
I meet control paint trouber while i put a table into sashform control .
When i make the shell maximum , the table control will not refresh
correctly. whether or not i use the sashform correctly?
The source code is as follows, and the table control is added by method
"PPP".
And i write some notation in my source code line 118 .You can test it
according to my notation. Ths!
The new source code is as follows:
* Created on 2004-10-29
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.SashForm;
import org.eclipse.swt.custom.StackLayout;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.widgets.*;
* @author JeffLian.
public class T09 {
//create shell
final Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
Composite parent1 = new Composite(shell, SWT.NONE);
parent1.setLayout(new FillLayout());
Composite parent = new Composite(parent1, SWT.BORDER);
GridLayout layout = new GridLayout();
layout.marginHeight = 0;
layout.marginWidth = 0;
layout.verticalSpacing = 0;
parent.setLayout(layout);
Composite pane = new Composite(parent, SWT.BORDER);
pane.setLayoutData(new GridData(GridData.FILL_BOTH));
pane.setLayout(new FillLayout());
Composite aa = new Composite(pane, SWT.NONE);
createPartControl(aa);
shell.setBounds(20, 30, 500, 500);
shell.open();
while (!shell.isDisposed()){
if (!display.readAndDispatch()) display.sleep();
display.dispose();
public static void createPartControl(Composite parent) {
Composite control = new Composite(parent, SWT.BORDER);
control.setLayoutData(new GridData(GridData.FILL_BOTH));
GridLayout controlLayout = new GridLayout();
controlLayout.horizontalSpacing = 0;
controlLayout.verticalSpacing = 0;
controlLayout.marginHeight = 0;
controlLayout.marginWidth = 0;
control.setLayout(controlLayout);
Composite contentArea = new Composite(control, SWT.NONE);
GridData clientData = new GridData(GridData.FILL_BOTH);
contentArea.setLayoutData(clientData);
contentArea.setLayout(new FillLayout());
Composite ppp = new Composite(contentArea, SWT.NONE);
PPP(ppp);
if (parent != null) return;
public static void PPP(Composite parent) {
Composite pane1 = new Composite(parent, SWT.BORDER);
pane1.setLayoutData(new GridData(GridData.FILL_BOTH));
pane1.setLayout(new GridLayout());
Label label = new Label(pane1, SWT.PUSH);
label.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
label.setText("sdfsdf");
SashForm form = new SashForm(pane1, SWT.VERTICAL);
form.setLayoutData(new GridData(GridData.FILL_BOTH));
form.setLayout(new FillLayout());
Composite child1 = new Composite(form, SWT.NONE);
child1.setLayout(new FillLayout());
//table = new CTable(child1, new CellDisplay(), new Renderer());
new Label(child1, SWT.NONE).setText("Label in pane 1");
Composite child2 = new Composite(form, SWT.NONE);
child2.setLayout(new FillLayout());
new Button(child2, SWT.PUSH).setText("Button in pane2");
Composite child3 = new Composite(form, SWT.NONE);
child3.setLayout(new FillLayout());
Composite ccc = new Composite(child3, SWT.BORDER);
ccc.setLayout(new FillLayout());
Composite ddd = new Composite(ccc, SWT.BORDER);
ddd.setLayout(new FillLayout());
* Here, Whe i use button control to replace table,
* the button control will refresh correctly while the shell
maximum,
* But when i use table control, why the table control will not
* refresh correctly while the shell maximum ?
* [attention please:] Here table's parent composite is
* the composite "ddd" by design.
* whether or not this is the table control 's
bug?
//new Button(ddd, SWT.PUSH).setText("Button in pane3");
Table table = new Table(ddd, SWT.FULL_SELECTION);
table.setHeaderVisible(true);
table.setLinesVisible(true);
TableColumn col1 = new TableColumn(table, SWT.CENTER);
col1.setText(" col1");
col1.setWidth(90);
TableColumn col2 = new TableColumn(table, SWT.CENTER);
col2.setText(" col2");
col2.setWidth(90);
for (int i = 0; i < 10; i++){
TableItem item = new TableItem(table, SWT.NONE);
item.setText(new String[] { "row", "col"});
form.setWeights(new int[] { 30, 40, 30 });
Re: sorry, I ask this question again. [message #445282 is a reply to message #445264] |
Mon, 01 November 2004 11:02   |
Can anyone see the problem? It WORKSFORME on my machine.
"JeffLian" <liankun_mail@21cn.com> wrote in message
news:cm4bo1$3bn$1@eclipse.org...
> Good day all:
> "PPP".
> * @author JeffLian.
> public class T09 {
> public static void main(String[] args) {
> //create shell
> shell.open();
> display.dispose();
> PPP(ppp);
> maximum,
> bug?
> col1.setWidth(90);
> col2.setWidth(90);
Re: sorry, I ask this question again. [message #445284 is a reply to message #445282] |
Mon, 01 November 2004 11:29   |
This works for me too, running on win2000. JeffLian what are you running
on?
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:cm5mma$t4p$1@eclipse.org...
> > Good day all:
> > "PPP".
> > * @author JeffLian.
> > public class T09 {
> > //create shell
> > shell.open();
> > display.dispose();
> > PPP(ppp);
> > maximum,
's
> > bug?
> > col1.setWidth(90);
> > col2.setWidth(90);
Current Time: Sat Jul 26 11:57:01 EDT 2025
Powered by FUDForum. Page generated in 0.04329 seconds
