RCP product [message #444825] |
Tue, 21 February 2006 14:11  |
Originally posted by: comouraf-lixo.yahoo.fr
I created an RCP application that works perfectly when launched from
eclipse. I also created a product out of it that runs smoothly inside
eclipse. However, when the same product is run after being exported (using
the product export wizard) it doesn't display one of the views
(java.lang.ClassNotFoundException: wordview.views.MyView). In fact the jar
to which this View belongs added an extra dir to the view path:
bin/wordview/views/MyView
instead of
How to tune the paths of generated jars?
Kaiser
Re: RCP product [message #444872 is a reply to message #444825] |
Wed, 22 February 2006 09:02  |
Kaiser wrote:
> Hello,
Your build.properties isn't right for some reason.
Generate a new plugin (like hello world, it doesn't matter) and compare
it's build.properties to your own.
re: 3rd party jars ... if you just have a dependancy on another plugin,
that's not a problem. I assume you added the dependancies in the
plugin.xml editor>Runtime tab?
If you've added anything to your build path through the Build
Path>Configure Build Path ... popup menu, that won't work.
Later,
PW
FUDForum. Page generated in 0.08268 seconds
