Home » Eclipse Projects » Rich Client Platform (RCP) » RCP product
RCP product [message #444825] Tue, 21 February 2006 14:11 Go to next message
Originally posted by: comouraf-lixo.yahoo.fr
I created an RCP application that works perfectly when launched from
eclipse. I also created a product out of it that runs smoothly inside
eclipse. However, when the same product is run after being exported (using
the product export wizard) it doesn't display one of the views
(java.lang.ClassNotFoundException: wordview.views.MyView). In fact the jar
to which this View belongs added an extra dir to the view path:
bin/wordview/views/MyView
instead of
How to tune the paths of generated jars?
Kaiser
Re: RCP product [message #444827 is a reply to message #444825] Tue, 21 February 2006 14:41 Go to previous messageGo to next message
This problem is well known as far as i know.
Search the mailing list for "third party", "3rd party" or something like
this - you should find plenty of answers.
Stefan
Kaiser schrieb:
> Hello,
> instead of
> Kaiser
Re: RCP product [message #444833 is a reply to message #444827] Tue, 21 February 2006 18:38 Go to previous messageGo to next message
Thanks for your reply Stefan.
I had already heard about this 3rd party jars problems, but I don't know if
it is my case, since the view I'm "importing" is not part from 3rd party
jars, but from another plugin already included in the dependencies. Anyway,
the solutions " turn the jars into plugins " or " include the jars in a
plugin " don't seem to apply to me. Or do they ?
Kaiser
"Stefan Zugal" <csae7511@uibk.ac.at> a
Re: RCP product [message #444872 is a reply to message #444825] Wed, 22 February 2006 09:02 Go to previous message
Kaiser wrote:
> Hello,
Your build.properties isn't right for some reason.
Generate a new plugin (like hello world, it doesn't matter) and compare
it's build.properties to your own.
re: 3rd party jars ... if you just have a dependancy on another plugin,
that's not a problem. I assume you added the dependancies in the
plugin.xml editor>Runtime tab?
If you've added anything to your build path through the Build
Path>Configure Build Path ... popup menu, that won't work.
Later,
PW
Previous Topic:"merging" plugins
Next Topic:Trouble with global action handlers in FormEditor
Current Time: Fri Jul 18 07:23:08 EDT 2025
Powered by FUDForum. Page generated in 0.11216 seconds
