Home » Eclipse Projects » Rich Client Platform (RCP) » How to access view folder (PageLayout) to add view dynamically ?
How to access view folder (PageLayout) to add view dynamically ? [message #444751] Mon, 20 February 2006 09:10 Go to next message
Hi there,
I am having following problem while using Eclipse RCP 3.0 / 3.1.
I have a perspective with three views setup (one view on the upper left
side, one view on the upper right side and one view on the bottom)
into folder containers on start-up of the RCP app.
How can I add a view dynamically (using an Action) to a certain folder
container (e.g. view folder on the upper left side) ?
Or maybe anyone knows how to access the page layout during runtime?
Thanks in advance for your help !
Eric
Re: How to access view folder (PageLayout) to add view dynamically ? [message #444757 is a reply to message #444751] Mon, 20 February 2006 09:51 Go to previous messageGo to next message
You would need to add a view placeholder to the perspective or you
cannot open the view during runtime. Then
try {
getSite().getWorkbenchWindow().getActivePage().showView(view ID,null,3);
} catch (PartInitException e) {
e.printStackTrace();
Eric Bredtmann wrote:
> Hi there,
> Cheers,
> Eric
Re: How to access view folder (PageLayout) to add view dynamically ? [message #444760 is a reply to message #444757] Mon, 20 February 2006 10:25 Go to previous messageGo to next message
Great!
Thanks, that worked out just fine.
Eric
> try {
>> Hi there,
>> left side, one view on the upper right side and one view on the bottom)
>> folder container (e.g. view folder on the upper left side) ?
>> Cheers,
>> Eric
Re: How to access view folder (PageLayout) to add view dynamically ? [message #444780 is a reply to message #444757] Mon, 20 February 2006 15:45 Go to previous message
It's better to access the page directly. And for most cases you can use
the single-arg variant of showView:
getSite().getPage().showView(viewID);
> try {
>> Hi there,
>> Cheers,
>> Eric
Previous Topic:Dont know whether it is the right place to ask...
Next Topic:JNI cannot find Java Routines with RCP
Current Time: Thu Sep 18 15:57:52 EDT 2025
Powered by FUDForum. Page generated in 0.33128 seconds
