MessageBox position [message #444570] |
Thu, 14 October 2004 21:19  |
Originally posted by: claudia_schneider.onlinehome.de
I have a program running as standalone app and in case of errors,
it will use a SWT MessageBox to display the error
How do I set the position of this box - as it seems to come up
in the middle of the screen all the times..
Achim
Re: MessageBox position [message #444592 is a reply to message #444587] |
Fri, 15 October 2004 12:29   |
Originally posted by: kevin.clark.accessbc.com.nospam
Steve,
I have a dual monitor display, and any MessageBox's always appear in the
dead center, between the monitors. i.e, half of the box is on one monitor
the other half is on the other monitor. It's then difficult to read
(without dragging), and easy to miss. Therefore, I think Achim has a valid
question...
Kevin
Steve Northover wrote:
> You don't. MessageBox's come up at the correct location for the platform.
> "Claudia Schneider" <claudia_schneider@onlinehome.de> wrote in message
> news:ckn88e$651$2@eclipse.org...
> > Hi,
> > Regards,
> > Achim
Re: MessageBox position [message #444593 is a reply to message #444592] |
Fri, 15 October 2004 12:49   |
What platform are you running on? I have a dual monitor configuration for
Windows XP, Motif and GTK and on all these platforms, the MessageBox appears
in the center of the monitor containing the parent shell.
"Kevbo" <kevin.clark@accessbc.com.nospam> wrote in message
news:ckotsi$65p$1@eclipse.org...
> Steve,
> question...
> Kevin
>> platform.
>> > Hi,
>> > Regards,
>> > Achim
Re: MessageBox position [message #444640 is a reply to message #444593] |
Mon, 18 October 2004 12:01  |
I'm running WinXP. I don't usually pass the parent Shell to the MessageBox
(usually null). I should also mention that I'm using an older version of
SWT (2.1). Which probably makes this whole discussion a moot point. =)
I noticed the MessageBox throwing errors with SWT 3.0.1. I haven't gotten
around to debugging that issue in my program yet, but I suspect that I
will have to pass the parent Shell.
Kevin
> > Steve,
> > question...
> > Thanks,
> > Kevin
> >> platform.
> >> > Hi,
> >> > Regards,
> >> > Achim
FUDForum. Page generated in 0.06137 seconds
