Home » Eclipse Projects » Rich Client Platform (RCP) » rcp application, how to I get rid of the search menu
rcp application, how to I get rid of the search menu [message #444536] Fri, 17 February 2006 03:15 Go to next message
I use the search plugin for my Eclipse RCP Application but It will
be an application specific search. I use the search results page but
not the official search dialog - we have a own search view..
I want to get rid of the search menu (in the menubar) and the search
entries in the toolbar..
Is there some way to do this ???
Re: rcp application, how to I get rid of the search menu [message #444542 is a reply to message #444536] Fri, 17 February 2006 05:05 Go to previous messageGo to next message
I got it !
The method hideActionSet from IWorkbenchPage is doing the job ...
For a short hack to disable the actions for my hole RCP Appliction I
hooked in an org.eclipse.ui.startup class and there I define a
Perspective Listener ... Well I know it is doing the hide call for
every perspective change (even if it is already hidden).. but until now
it is all I wanted.
The action ids I got from browsing through my dependent eclipse
plugins.. searching for ActionSets
package ch.post.pf.gui.prototyp.sesam.pstonline;
import org.eclipse.ui.IPerspectiveDescriptor;
import org.eclipse.ui.IPerspectiveListener;
import org.eclipse.ui.IStartup;
import org.eclipse.ui.IWorkbenchPage;
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.ui.PlatformUI;
public class ActionWiper implements IStartup, IPerspectiveListener {
private static final String[] ACTIONS_2_WIPE = new String[] {
"org.eclipse.search.searchActionSet",
"org.eclipse.ui.edit.text.actionSet.presentation",
"org.eclipse.ui.edit.text.actionSet.openExternalFile",
"org.eclipse.ui.edit.text.actionSet.annotationNavigation",
"org.eclipse.ui.edit.text.actionSet.navigation",
"org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo",
"org.eclipse.update.ui.softwareUpdates" };
public void earlyStartup() {
IWorkbenchWindow[] windows = PlatformUI.getWorkbench()
.getWorkbenchWindows();
for (int i = 0; i < windows.length; i++) {
IWorkbenchPage page = windows[i].getActivePage();
if (page != null) {
wipeActions(page);
windows[i].addPerspectiveListener(this);
private void wipeActions(IWorkbenchPage page) {
for (int i = 0; i < ACTIONS_2_WIPE.length; i++) {
wipeAction(page, ACTIONS_2_WIPE[i]);
private void wipeAction(final IWorkbenchPage page, final String
actionsetId) {
Display.getDefault().syncExec(new Runnable() {
public void run() {
page.hideActionSet(actionsetId);
public void perspectiveActivated(IWorkbenchPage page,
IPerspectiveDescriptor perspective) {
wipeActions(page);
public void perspectiveChanged(IWorkbenchPage page,
IPerspectiveDescriptor perspective, String changeId) {
Re: rcp application, how to I get rid of the search menu [message #444544 is a reply to message #444542] Fri, 17 February 2006 05:32 Go to previous message
With the PreferenceManager I got even rid of the unwanted Preferences..:)
Where the PREFERENCES_2_WIPE Strings have to be the IDs of the main
categories you want to get rid off. Like the
"org.eclipse.ui.preferencePages.Workbench" -> shows up as General
PreferenceManager pm = PlatformUI.getWorkbench().getPreferenceManager();
for (int i = 0; i < PREFERENCES_2_WIPE.length; i++) {
pm.remove(PREFERENCES_2_WIPE[i]);
> I got it !
> it is all I wanted.
> import org.eclipse.swt.widgets.Display;
> if (page != null) {
> wipeActions(page);
> actionsetId) {
> public void run() {
> wipeActions(page);
Previous Topic:Creating standalone help RCP
Next Topic:Plugin In Editor and Squiggles
Current Time: Sat Jul 19 01:57:08 EDT 2025
Powered by FUDForum. Page generated in 0.23025 seconds
