Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Creating own widget
Creating own widget [message #444461] Wed, 13 October 2004 10:48 Go to next message
Originally posted by: roadspeed2002.yahoo.com
Hi All,
I am trying to create a widget that contains other widgets. Hence, as a test
I have created a class TwinButton that extends the Composite class and
contains a button widget. However, the text on the button does not appear.
If I create a simple button widget the text appears. What would I need to do
to make this work ? i.e are there certain methods that I have to overwrite.
thanks in advance.
public class TwinButton extends Composite {
protected Button buttonA;
// protected Button buttonB;
public TwinButton(Composite parent, int style) {
super(parent, SWT.NONE);
buttonA = new Button(this, style);
Display display = new Display();
Shell shell = new Shell(display);
shell.setText(" Hello World ");
shell.setBounds(100, 100, 400, 250);
shell.setLayout(new FillLayout());
TwinButton button = new TwinButton(shell, SWT.CENTER );
//Button button = new Button(shell, SWT.CENTER );
button.setText("Apples");
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
public void setText(String text) {
buttonA.setText(text);
// Methods overriding Composite
public Point computeSize (int wHint, int hHint, boolean changed) {
return buttonA.computeSize (wHint, hHint, changed);
public void setLayout(Layout layout) {
return; // do nothing
Re: Creating own widget [message #444472 is a reply to message #444461] Wed, 13 October 2004 12:05 Go to previous message
You need to lay the button out inside the parent composite:
For example:
class TwinButtonLayout extends Layout {
protected Point computeSize(Composite composite, int
wHint, int hHint, boolean flushCache) {
Button buttonA =
((TwinButton)composite).buttonA;
return buttonA.computeSize(wHint, hHint,
flushCache);
protected void layout(Composite composite, boolean
flushCache) {
Button buttonA =
Rectangle rect = composite.getClientArea();
buttonA.setBounds(rect);
super.setLayout(new TwinButtonLayout());
changed) {
shell.setSize(100, 100);
shell.open();
display.sleep();
display.dispose();
"Roadway" <roadspeed2002@yahoo.com> wrote in message
news:ckjf28$dvb$1@eclipse.org...
> Hi All,
> test
> do
> overwrite.
> thanks in advance.
> public static void main(String[] args) {
> shell.open();
> display.sleep();
> display.dispose();
Previous Topic:SWT for plain COM?
Next Topic:How to capture External Key Press Events outside application window
Current Time: Fri Jul 25 23:35:20 EDT 2025
Powered by FUDForum. Page generated in 0.06990 seconds
