Home » Eclipse Projects » Standard Widget Toolkit (SWT) » [PocketPC] Problem with newer SWT versions + thicker line
[PocketPC] Problem with newer SWT versions + thicker line [message #444242] Sun, 10 October 2004 08:54 Go to next message
I have a problem with newer SWT versions (3.0.1 Thu, 16 Sep 2004 is the last
without problems 'old version.jpg') on Pocket PC.
They show no shell content if not the additional shell.layout(); is set
(please see HelloWorld.java in the attachment).
Does anybody have the same problem?
Then my top shells have independent of the version a thicker line at the
bottom (see picture). This looks not so good. Take notice of that dialogs
have not this thicker line. You can see this better if you zoom in.
Regards, Tobi
Re: [PocketPC] Problem with newer SWT versions + thicker line [message #444429 is a reply to message #444242] Tue, 12 October 2004 11:48 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=71975 ?
"Tobi Wink" <tobi.winkesf@lycos.com> wrote in message
news:ckbba5$fia$1@eclipse.org...
last
> Regards, Tobi
Re: [PocketPC] Problem with newer SWT versions + thicker line [message #444439 is a reply to message #444242] Tue, 12 October 2004 12:51 Go to previous message
opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=76102
thanks
Chris
Previous Topic:SWT/AWT Incompatibility on Mac OS X
Next Topic:can anyone use wizard ?
Current Time: Sat Jul 19 00:58:34 EDT 2025
Powered by FUDForum. Page generated in 0.04283 seconds
