Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Custom Widget in Drop Down Menu
Custom Widget in Drop Down Menu [message #444142] Thu, 07 October 2004 10:58 Go to next message
Originally posted by: luislobo.evolvenet.pt
Hi!
Is there any way of creating a drop down menu which contains a widget and
not only text, something like a TableViewer (for instance).
It may seem a little strange, but I need it to create a calendar button,
something like the one that pops up in KDE/Windows when you click the
clock.
I am using SWT 3.0.1.
Thanks in advance,
LL
Re: Custom Widget in Drop Down Menu [message #444199 is a reply to message #444142] Fri, 08 October 2004 10:42 Go to previous messageGo to next message
Nope. Menus are not native controls on some operating systems (Windows) and
therefore cannot be treated as such. On Windows, the operating system calls
that resize and position controls for example will not work on menus. This
is the main reason that menus are modeled the way they are in SWT.
"Lu
Re: Custom Widget in Drop Down Menu [message #444213 is a reply to message #444199] Fri, 08 October 2004 13:56 Go to previous messageGo to next message
And presumably there's no way to show a dialog with
the modality of a menu, so that it disappears when
something else gets focus etc.?
Paul Singleton
Re: Custom Widget in Drop Down Menu [message #444236 is a reply to message #444213] Sat, 09 October 2004 17:21 Go to previous messageGo to next message
Sure, just not inside a menu. Just code a focus listener and close your
shell when it loses focus.
-Chris
"Paul Singleton" <paul@jbgb.com> wrote in message
news:ck6k36$fst$1@eclipse.org...
>> and
>> calls
>> This
> Paul Singleton
Re: Custom Widget in Drop Down Menu [message #444457 is a reply to message #444236] Wed, 13 October 2004 07:37 Go to previous message
Many thanks for the encouraging tip; before I have a go,
has anyone else emulated popup menus like this? I'm not
sure about cross platform issues; in Windows, Esc also
cancels a popup, and I don't know about other platforms.
I'd like to do it properly...
Paul Singleton
Previous Topic:Double click event in "Combo"
Next Topic:Table column wrapping
Current Time: Mon Nov 10 05:01:55 EST 2025
Powered by FUDForum. Page generated in 0.04442 seconds
