Home » Eclipse Projects » Rich Client Platform (RCP) » Extension point not found on clean build
Extension point not found on clean build [message #444096] Thu, 09 February 2006 09:51
Originally posted by: kwpeck.mersoft.com
We have an RCP with quite a few plug-ins. When we export the Team
project and then import it on another machine we get errors in all the
plugin.xml files that it can not find the extension point.
So we open each project.xml and add a SPACE and delete a SPACE and do a
save. This makes something in Eclipse trigger to find the extension
point and build.
I really don't feel we should have to do this each time. A Project Clean
/ Build all or even an F5 refresh on the whole project does not fix the
problem, you have to slightly modify the manifest and save it.
Surely someone else has run into this issue and knows a magic secret.
Previous Topic:Eclipse 3.2M4 - Not able to launch Eclipse IDE RunTimeException
Next Topic:Create Rich Client Application from an existing plug in
Current Time: Tue Jul 22 16:19:09 EDT 2025
Powered by FUDForum. Page generated in 0.04260 seconds
