Eclipse 3.2M4 - Not able to launch Eclipse IDE RunTimeException [message #444093] |
Thu, 09 February 2006 08:53 |
Originally posted by: dgladson.gmail.com
I have a test plugin and that is packaged the way Eclipse -> Export does
through an Ant scirpt. The jar is copied at eclipse\plugins folder.
But Eclipse IDE does not launch and the log file in the configuration
folder has this error message.
Any thought is appreciated. Thank you
!SESSION 2006-02-09 08:36:35.624
eclipse.buildId=I20051215-1506
java.version=1.4.2_08
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.391
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench"
could not be found in the registry. The applications available are:
org.eclipse.ant.core.antRunner,
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.pde.build.Build,
org.eclipse.pde.junit.runtime.uitestapplication,
org.eclipse.pde.junit.runtime.coretestapplication,
org.eclipse.pde.junit.runtime.legacyUItestapplication,
org.eclipse.pde.junit.runtime.legacyCoretestapplication,
org.eclipse.update.core.standaloneUpdate,
org.eclipsercp.hyperbola.application.
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:99)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.411
!MESSAGE Bundle update@plugins/org.eclipse.core.expressions_3.1.0.jar
[112] was not resolved.
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.451
!MESSAGE Bundle update@plugins/org.eclipse.core.runtime_3.1.0.jar [114]
was not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.help.appserver_3.1.0.jar [119]
was not resolved.
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.481
!MESSAGE Bundle update@plugins/org.eclipse.help.base_3.1.0.jar [120] was
not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.help.ui_3.1.0.jar [121] was not
resolved.
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.491
!MESSAGE Bundle update@plugins/org.eclipse.help.webapp_3.1.0/ [122] was
not resolved.
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.501
!MESSAGE Bundle update@plugins/org.eclipse.help_3.1.0.jar [123] was not
resolved.
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.511
!MESSAGE Bundle update@plugins/org.eclipse.osgi_3.1.0.jar [125] was not
resolved.
!MESSAGE Bundle update@plugins/org.eclipse.rcp_3.1.0.jar [127] was not
resolved.
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.521
!MESSAGE Bundle update@plugins/org.eclipse.swt.win32.win32.x86_3.1.0.jar
[128] was not resolved.
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.531
!MESSAGE Bundle update@plugins/org.eclipse.swt_3.1.0.jar [129] was not
resolved.
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.541
!MESSAGE Bundle update@plugins/org.eclipse.tomcat_4.1.30.1/ [130] was not
resolved.
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.551
!MESSAGE Bundle update@plugins/org.eclipse.ui.workbench_3.1.0.jar [132]
was not resolved.
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.561
!MESSAGE Bundle update@plugins/org.eclipse.ui_3.1.0.jar [133] was not
resolved.
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.571
!MESSAGE Bundle update@plugins/org.eclipse.update.configurator_3.1.0.jar
[134] was not resolved.
!ENTRY org.eclipse.osgi 2006-02-09 08:36:40.581
!MESSAGE Bundle update@plugins/org.eclipse.update.core_3.1.0.jar [136] was
not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.update.ui_3.1.0.jar [137] was
not resolved.
FUDForum. Page generated in 0.04870 seconds
