Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How do I remove a TableColumn from a table
How do I remove a TableColumn from a table [message #443922] Mon, 04 October 2004 11:33 Go to next message
Originally posted by: news0reader.hotmail.com
Hi, how do I remove a TableColumn from a table? I tried getting all
columns and then calling TableColumn::dispose()...but it did n't work, in
that when I add more columns to the table the old ones (the ones on which
I called dispose()) still remain.
Thanx
--A
Re: How do I remove a TableColumn from a table [message #443932 is a reply to message #443922] Mon, 04 October 2004 12:40 Go to previous messageGo to next message
Originally posted by: H.Drewes.web.de
you can use table.remove(int index) to remove the TableItem with the
specified index. Unfortunately, I think there isn't a method like
table.remove(TableItem item), so if you don't know the index number of
your TableItem, there's possibly only the way to remove all items
with table.removeAll() and redraw the hole table. I actually did it
like this in a project of mine.
Holger
> Thanx
> --A
Re: How do I remove a TableColumn from a table [message #443935 is a reply to message #443922] Mon, 04 October 2004 13:00 Go to previous messageGo to next message
TableColumn.dispose() should work. What platform are you using? Can you
give a code example that fails?
"news" <news0reader@hotmail.com> wrote in message
news:cjrqgj$s6a$1@eclipse.org...
> Thanx
> --A
Re: How do I remove a TableColumn from a table [message #443937 is a reply to message #443932] Mon, 04 October 2004 13:37 Go to previous messageGo to next message
Holger,
Thanx for the response, but as far as I know a TableItem is a "table row,"
whereas I want to remove a TableColumn, a column.
--A
"Holger Drewes" <H.Drewes@web.de> wrote in message
news:cjru5k$4f2$1@eclipse.org...
> Hello,
> Holger
in
which
> > Thanx
> > --A
Re: How do I remove a TableColumn from a table [message #443945 is a reply to message #443935] Mon, 04 October 2004 17:21 Go to previous message
Veronika,
Yes, it should work...and in a pared-down example I wrote to post here it
*does* work. So my problems must lie elsewhere. Let me investigate some
more.
Thanx
--A
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:cjrv9e$6md$1@eclipse.org...
in
which
> > Thanx
> > --A
Previous Topic:org.eclipse.swt.custom.ViewForm , ToolBar and JFace Action
Next Topic:Unhandled event loop exception.....
Current Time: Sun Jul 20 03:06:48 EDT 2025
Powered by FUDForum. Page generated in 0.05916 seconds
