Home » Eclipse Projects » Rich Client Platform (RCP) » AbstractTextEditor and quickdiff
AbstractTextEditor and quickdiff [message #443913] Tue, 07 February 2006 04:32 Go to next message
We would like to make use of the quick diff functionality in our RCP
application. We have dependencies to the org.eclipse.ui.workbench.texteditor
plugin but not to the org.eclipse.ui.editors plugin.
I have implemented a IQuickDiffReferenceProvider and added it into our
plugin manifest as it is described in the extension point documentation. But
it didn't work. I see that the showChangeInformation(boolean show) method of
the AbstractTextEditor class does nothing. When I look at the source code of
the AbstractDecoratedTextEditor class, I think that I need have some kind of
ChangeRuler but I have no idea to implement such a thing.
So my question is: Is it possible at all to make use of the quick diff
functionality via the workbench.texteditor plugin? If yes, can you please
help me with some example code etc.
Thanks in advance,
Yetkin
Re: AbstractTextEditor and quickdiff [message #444025 is a reply to message #443913] Wed, 08 February 2006 10:39 Go to previous messageGo to next message
Yetkin,
if it is not possible for you to use AbstractDecoratedTextEditor due to
plug-in dependency constraints, you could try copying the relevant
methods to your own editor implementation.
There are two API implementations of IChangeRuler in the
org.eclipse.jface.text plug-in which you may use (and are used by
AbstractDecoratedTextEditor):
org.eclipse.jface.text.source.ChangeRulerColumn
org.eclipse.jface.text.source.LineNumberChangeRulerColumn
HTH, tom
Yetkin Oezkucur wrote:
> Thanks in advance,
> Yetkin Özkucur| Software Engineer
> Yetkin.Oezkucur@asg.com
> ASG | asg.com
> Straßburger Str. 34
> D-09120 Chemnitz, Germany
> Tel: +49 371 52 302-39
> Fax: +49 371 52 302-11
> The premier source for understanding,
> managing, and extending existing systems
Re: AbstractTextEditor and quickdiff [message #444396 is a reply to message #444025] Wed, 15 February 2006 03:42 Go to previous messageGo to next message
Hi Tom,
Thank you for your hint. I have now managed to install a ruler, which shows
the deleted, added, changed lines etc.
But what I still couldn't manage is, I can't bring ruler to have hover
showing changed text. I've already copied the TextChangeHover class from
AbstractDecoratedTextEditor but it seems that I miss something.
Thanks in advance,
Yetkin
"Tom Eicher" <eclipse@tom.eicher.name> wrote in message
news:dsd3bo$447$1@utils.eclipse.org...
> Yetkin,
> HTH, tom
> > Hi,
But
method of
code of
kind of
please
> > Thanks in advance,
> > Yetkin
Re: AbstractTextEditor and quickdiff [message #444548 is a reply to message #444396] Fri, 17 February 2006 06:51 Go to previous message
>Hi Tom,
See AbstractDecoratedTextEditor.createChangeHover(...)
Dani
>Thanks in advance,
>Yetkin
>>Yetkin,
>>HTH, tom
>>>Hi,
>But
>method of
>code of
>kind of
>please
>>>Thanks in advance,
>>>ASG | asg.com
>>>Straßburger Str. 34
Previous Topic:global undo
Next Topic:Repaint Issues in RCP
Current Time: Sun Aug 31 22:44:52 EDT 2025
Powered by FUDForum. Page generated in 0.03936 seconds
