Home » Eclipse Projects » Rich Client Platform (RCP) » Problem with Eclipse Product Export Wizard.
Problem with Eclipse Product Export Wizard. [message #443444] Tue, 31 January 2006 00:53 Go to next message
Originally posted by: tnataraj.cisco.com
I have a product called MibFix and it starts fine, if I "Launch the
product".
But if I use the export wizard, the application throws the following error:
Please help me in resolving this error.
Is there anything to do with the classpath settings?
Let me know if you need any further information about the product.
Thanks & Regards,
Thenmozhi.
!SESSION 2006-01-24 17:32:51.106
eclipse.buildId=unknown
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US Command-line
arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2006-01-24 17:33:01.311 !MESSAGE An error occurred
while automatically activating bundle MIBFix (5).
!STACK 0
org.osgi.framework.BundleException: The activator
com.cisco.mibfix.designtool.gui.main.MIBFixPlugin for bundle MIBFix is
invalid
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:149)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:313)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:264)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1248)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:222)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.ClassNotFoundException:
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:405)
at
at
at
at
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:142)
... 27 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 2006-01-24 17:33:01.331 !MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException[1]:
com.cisco.mibfix.designtool.gui.main.MIBFixApplication
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Problem with Eclipse Product Export Wizard. [message #443466 is a reply to message #443444] Tue, 31 January 2006 07:01 Go to previous messageGo to next message
Please post your manifest.mf and build.properties files. Or look in the
newsgroups archive, this question comes up 2 times a week at least. In
short: wrong classpath and/or missing classfiles/jars. Errors in the
export process itself stem usually from the presents of projects with
linked binary content in the workspace.
This post may be used as a template for similar future questions :)
Symptoms:
bla.foo.Plugin for bundle Blubb is invalid
Caused by: java.lang.ClassNotFoundException: some.class.in.plugin
Ricky
Re: Problem with Eclipse Product Export Wizard. [message #443468 is a reply to message #443444] Tue, 31 January 2006 07:50 Go to previous messageGo to next message
This often happens when using 3rd party jars (there's a list I use):
http://dev.eclipse.org/newslists/news.eclipse.platform/msg48 366.html
(note, eclipse does support JAR in JAR).
There's a lot of confusion moving from java projects to plugin projects.
With java projects, you just configure the Build Path. Add external
libraries if you like, build a couple of jars, and away you go.
With plugins, for the most part you should NOT be using the Build Path
(which JDT uses and the launchers use). Instead, you should be updating
the Runtime classpath in the manifest file. Then use project>popup
menu>PDE Tools>Update classpath to update the Build Path.
Later,
PW
Re: Problem with Eclipse Product Export Wizard. [message #443482 is a reply to message #443444] Tue, 31 January 2006 13:50 Go to previous messageGo to next message
i have this behavior when i 'import external plugins with linked contents'
workaround for me : remove this plugin and if i need it then i import
external plugin (binary or source) without linked contents
Thenmozhi Natarajan wrote:
> product".
> error:
> Thanks & Regards,
> Thenmozhi.
> !STACK 0
> invalid
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 27 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Problem with Eclipse Product Export Wizard. [message #443616 is a reply to message #443466] Thu, 02 February 2006 01:04 Go to previous messageGo to next message
Thanks for your reply.
Here is the information requested.
Thenmozhi.
Manifest.mf:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: MIBFix Plug-in
Bundle-SymbolicName: MIBFix; singleton:=true
Bundle-Version: 1.0.0
Bundle-ClassPath: .,
com.cisco.mibfix.designtool.gui.main/,
lib/axis.jar,
lib/axis-ant.jar,
lib/axis-schema.jar,
lib/commons-discovery-0.2.jar,
lib/commons-logging-1.0.4.jar,
lib/jaxrpc.jar,
lib/jdom.jar,
lib/log4j-1.2.8.jar,
lib/mib-police.jar,
lib/saaj.jar,
lib/wsdl4j-1.5.1.jar
Bundle-Activator: com.cisco.mibfix.designtool.gui.main.MIBFixPlugin
Bundle-Localization: plugin
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.jface.text,
org.eclipse.core.resources,
org.eclipse.ui.editors,
org.eclipse.ui.ide,
org.eclipse.ui.workbench.texteditor,
org.eclipse.ui.forms,
Mibble,
org.eclipse.help,
org.eclipse.help.appserver,
org.eclipse.help.base,
org.eclipse.help.ui,
org.apache.lucene,
org.eclipse.help.webapp,
org.eclipse.tomcat,
MIBFixLibs
Eclipse-AutoStart: true
Build.properties:
bin.includes = book.xml,\
build.properties,\
data/,\
html/,\
icons/,\
lib/,\
META-INF/,\
mibs/,\
plugin.xml,\
src/,\
template/,\
toc.xml,\
toc_BestPractices.xml,\
toc_CLR.xml,\
toc_Cookbook.xml,\
toc_FAQ.xml,\
toc_MIB_Developement_Process.xml
Re: Problem with Eclipse Product Export Wizard. [message #443641 is a reply to message #443616] Thu, 02 February 2006 05:54 Go to previous messageGo to next message
> lib/axis.jar,
> lib/axis-ant.jar,
> lib/jaxrpc.jar,
> lib/jdom.jar,
> lib/mib-police.jar,
> lib/saaj.jar,
The classpath entry com.cisco... seems useless. Is this the location of
your class files? Does below this directory start a normal package
hierarchy like com/cisco/...?
Your build.properties miss information about your actual classes. The
rational is this: On the build tab of your manifest.mf you specify which
files should go into the resulting plugin. The runtime tab and the
classpath box denotes which of these files should make it onto the
classpath. You have "." on your classpath which means that your package
hierarchy starts in the root of the plugin. But the build process does not
put your classes in this location.
On your build tab locate the runtime information box. Add a library with
the name "." (only a dot). Click on the new library. The intuitive UI now
reveals the opportunity to "Include the selected library in the binary
build". Do this. Also add your source folder with "add folder".
hth,
Ricky
Re: Problem with Eclipse Product Export Wizard. [message #443869 is a reply to message #443641] Mon, 06 February 2006 01:46 Go to previous messageGo to next message
Hi Ricky,
Thanks for your mail.
I modified the MANIFEST as follows and followed the steps as you suggested
in setting the runtime information under build tab. But I'm getting many
errors during exporting.
I'm very new to this Eclipse environment and it is very difficult for me
to understand the settings required.
The main plugin is MIBFix and its source files(classes) are under the
src/com/cisco/mibfix/designtool/ directory and the jar files used by this
plugin are under lib/.
This main plugin refers to two other plugins called Mibble and MIBFixLibs
under the same workspace and hence they are included in the main plugin's
dependencies tab. So, all the required plugins are included as a feature
called MibFix-feature. I followed the steps as suggested in the link,
http://www.eclipse.org/articles/Article-RCP-1/tutorial1.html .
After modifying the classpath and buildpath as follows, I'm facing some
new errors while exporting the product. The errors correspond to
unresolved reference of Mibble and MibFixLibs code from MibFix.
Please help me out.
Thenmozhi.
3. ERROR in
D:\Old_D\backup\workspace\MIBFix\src\com\cisco\mibfix\design tool\core\ImportHandler.java
(at line 29)
import net.percederberg.mibble.Mib;
The import net cannot be resolved
4. ERROR in
(at line 30)
import net.percederberg.mibble.MibImport;
5. ERROR in
(at line 31)
import net.percederberg.mibble.MibLoader;
41. ERROR in
(at line 143)
MibLoader loader = MibDirectoryLoader.getInstance().getMibLoader();
The method getMibLoader() is undefined for the type MibDirectoryLoader
Build.properties:
jars.compile.order = .
bin.includes = src/,\
lib/,\
data/,\
html/,\
icons/,\
build.properties,\
mibs/,\
template/,\
toc.xml,\
toc_CLR.xml,\
toc_FAQ.xml,\
toc_Cookbook.xml,\
toc_MIB_Developement_Process.xml,\
mibfix.product,\
plugin.xml
source.. = src/
output.. = bin/
MANIFEST.MF:
lib/,
org.eclipse.ui.ide,
Mibble,
org.eclipse.help,
org.apache.lucene,
org.eclipse.tomcat,
MIBFixLibs
Re: Problem with Eclipse Product Export Wizard. [message #443881 is a reply to message #443869] Mon, 06 February 2006 08:19 Go to previous messageGo to next message
What are the manifests and build properties for Mibble and MibFixLibs?
Also, you have this in your manifest:
lib/,
That means you'll pick up any class files under your lib/ directory ...
but not any jars. I'm guessing you didn't follow the instructions for
jars in a plugin in my other post :-)
BTW: sometimes you can have these problems if you've imported binary
projects with linked content.
Re: Problem with Eclipse Product Export Wizard. [message #443905 is a reply to message #443881] Tue, 07 February 2006 00:12 Go to previous messageGo to next message
Hi Paul,
Thanks for your response..
I modified the runtime tab to include the individual jar files under lib/
directory and the new Manifest file is as follows.
Still I'm getting the unresolved errors stated in my previous mail.
Here are the manifest and build.properties for the plugins MIBFix, Mibble
and MIBFixLibs.
Thanks & Regards,
Thenmozhi.
Manifest.mf for MIBFix:
lib/axis.jar,
lib/axis-ant.jar,
lib/jaxrpc.jar,
lib/jdom.jar,
lib/mib-police.jar,
lib/saaj.jar,
lib/wsdl4j-1.5.1.jar,
org.eclipse.ui.ide,
Mibble,
org.eclipse.help,
org.apache.lucene,
org.eclipse.tomcat,
MIBFixLibs
build.properties for MIBFix:
lib/,\
data/,\
html/,\
icons/,\
build.properties,\
mibs/,\
template/,\
toc.xml,\
toc_CLR.xml,\
toc_FAQ.xml,\
toc_Cookbook.xml,\
mibfix.product,\
plugin.xml
source.. = src/
output.. = bin/
Manifest for Mibble:
Bundle-Name: Mibble Plug-in
Bundle-SymbolicName: Mibble
Bundle-ClassPath: .
Export-Package: .,
mibs.iana,
mibs.ietf,
net.percederberg.grammatica.parser,
net.percederberg.grammatica.parser.re,
net.percederberg.mibble,
net.percederberg.mibble.asn1,
net.percederberg.mibble.browser,
net.percederberg.mibble.snmp,
net.percederberg.mibble.type,
net.percederberg.mibble.value,
org.bouncycastle.crypto,
org.bouncycastle.crypto.digests,
org.bouncycastle.crypto.engines,
org.bouncycastle.crypto.generators,
org.bouncycastle.crypto.params,
uk.co.westhawk.snmp.beans,
uk.co.westhawk.snmp.event,
uk.co.westhawk.snmp.net,
uk.co.westhawk.snmp.pdu,
uk.co.westhawk.snmp.stack,
uk.co.westhawk.snmp.util,
uk.co.westhawk.visual
Import-Package: bin
build.properties for Mibble:
bin.includes = LICENSE-GPL.txt,\
LICENSE.txt,\
META-INF/,\
Mibble_1.0.0.jar,\
README.txt,\
mibs/
Manifest for MIBFixLibs:
Bundle-Name: MIBFixLibs Plug-in
Bundle-SymbolicName: MIBFixLibs
Bundle-ClassPath: .
Export-Package:
com.cisco.nmtg.mibpolice.api,
com.cisco.nmtg.mibpolice.backend,
com.cisco.nmtg.mibpolice.backend.db,
com.cisco.nmtg.mibpolice.common,
com.cisco.nmtg.mibpolice.middleware,
com.cisco.nmtg.mibpolice.ui,
com.cisco.nmtg.mibpolice.ui.action,
com.cisco.nmtg.mibpolice.ui.actionform,
com.cisco.nmtg.mibpolice.ui.application,
com.cisco.nmtg.mibpolice.ui.security,
com.ibm.wsdl,
com.ibm.wsdl.extensions,
com.ibm.wsdl.extensions.http,
com.ibm.wsdl.extensions.mime,
com.ibm.wsdl.extensions.schema,
com.ibm.wsdl.extensions.soap,
com.ibm.wsdl.factory,
com.ibm.wsdl.util,
com.ibm.wsdl.util.xml,
com.ibm.wsdl.xml,
javax.wsdl,
javax.wsdl.extensions,
javax.wsdl.extensions.http,
javax.wsdl.extensions.mime,
javax.wsdl.extensions.schema,
javax.wsdl.extensions.soap,
javax.wsdl.factory,
javax.wsdl.xml,
javax.xml.messaging,
javax.xml.namespace,
javax.xml.rpc,
javax.xml.rpc.encoding,
javax.xml.rpc.handler,
javax.xml.rpc.handler.soap,
javax.xml.rpc.holders,
javax.xml.rpc.server,
javax.xml.rpc.soap,
javax.xml.soap,
org.apache.axis,
org.apache.axis.attachments,
org.apache.axis.client,
org.apache.axis.client.async,
org.apache.axis.collections,
org.apache.axis.components.compiler,
org.apache.axis.components.encoding,
org.apache.axis.components.image,
org.apache.axis.components.jms,
org.apache.axis.components.logger,
org.apache.axis.components.net,
org.apache.axis.components.script,
org.apache.axis.components.threadpool,
org.apache.axis.components.uuid,
org.apache.axis.configuration,
org.apache.axis.constants,
org.apache.axis.deployment.wsdd,
org.apache.axis.deployment.wsdd.providers,
org.apache.axis.description,
org.apache.axis.encoding,
org.apache.axis.encoding.ser,
org.apache.axis.encoding.ser.castor,
org.apache.axis.encoding.ser.xbeans,
org.apache.axis.enum,
org.apache.axis.handlers,
org.apache.axis.handlers.http,
org.apache.axis.handlers.soap,
org.apache.axis.holders,
org.apache.axis.i18n,
org.apache.axis.management,
org.apache.axis.management.jmx,
org.apache.axis.message,
org.apache.axis.monitor,
org.apache.axis.providers,
org.apache.axis.providers.java,
org.apache.axis.schema,
org.apache.axis.security,
org.apache.axis.security.servlet,
org.apache.axis.security.simple,
org.apache.axis.server,
org.apache.axis.session,
org.apache.axis.soap,
org.apache.axis.strategies,
org.apache.axis.tools.ant.axis,
org.apache.axis.tools.ant.foreach,
org.apache.axis.tools.ant.wsdl,
org.apache.axis.transport.http,
org.apache.axis.transport.java,
org.apache.axis.transport.jms,
org.apache.axis.transport.local,
org.apache.axis.transport.mail,
org.apache.axis.types,
org.apache.axis.utils,
org.apache.axis.utils.bytecode,
org.apache.axis.utils.cache,
org.apache.axis.wsdl,
org.apache.axis.wsdl.fromJava,
org.apache.axis.wsdl.gen,
org.apache.axis.wsdl.symbolTable,
org.apache.axis.wsdl.toJava,
org.apache.commons.discovery,
org.apache.commons.discovery.ant,
org.apache.commons.discovery.jdk,
org.apache.commons.discovery.log,
org.apache.commons.discovery.resource,
org.apache.commons.discovery.resource.classes,
org.apache.commons.discovery.resource.names,
org.apache.commons.discovery.tools,
org.apache.commons.logging,
org.apache.commons.logging.impl,
org.apache.log4j,
org.apache.log4j.chainsaw,
org.apache.log4j.config,
org.apache.log4j.helpers,
org.apache.log4j.jdbc,
org.apache.log4j.jmx,
org.apache.log4j.lf5,
org.apache.log4j.lf5.config,
org.apache.log4j.lf5.util,
org.apache.log4j.lf5.viewer,
org.apache.log4j.lf5.viewer.categoryexplorer,
org.apache.log4j.lf5.viewer.configure,
org.apache.log4j.lf5.viewer.images,
org.apache.log4j.net,
org.apache.log4j.nt,
org.apache.log4j.or,
org.apache.log4j.or.jms,
org.apache.log4j.or.sax,
org.apache.log4j.spi,
org.apache.log4j.varia,
org.apache.log4j.xml,
org.apache.xml.xml_soap,
org.globus.test.bigType,
org.globus.test.otherTypes,
org.jdom,
org.jdom.adapters,
org.jdom.filter,
org.jdom.input,
org.jdom.output,
org.jdom.transform,
org.jdom.xpath,
org.soapinterop,
org.xmlsoap.schemas.wsdl,
org.xmlsoap.schemas.wsdl.impl,
org.xmlsoap.schemas.wsdl.soap,
org.xmlsoap.schemas.wsdl.soap.impl,
schemaorg_apache_xmlbeans.attribute.http_3A_2F_2Fschemas_2Ex mlsoap_2Eorg_2Fwsdl_2F,
schemaorg_apache_xmlbeans.attributegroup.http_3A_2F_2Fschema s_2Exmlsoap_2Eorg_2Fwsdl_2Fsoap_2F,
schemaorg_apache_xmlbeans.element.http_3A_2F_2Fschemas_2Exml soap_2Eorg_2Fwsdl_2F,
schemaorg_apache_xmlbeans.element.http_3A_2F_2Fschemas_2Exml soap_2Eorg_2Fwsdl_2Fsoap_2F,
schemaorg_apache_xmlbeans.identityconstraint.http_3A_2F_2Fsc hemas_2Exmlsoap_2Eorg_2Fwsdl_2F,
schemaorg_apache_xmlbeans.javaname.org.xmlsoap.schemas.wsdl,
schemaorg_apache_xmlbeans.javaname.org.xmlsoap.schemas.wsdl. soap,
schemaorg_apache_xmlbeans.modelgroup.http_3A_2F_2Fschemas_2E xmlsoap_2Eorg_2Fwsdl_2F,
schemaorg_apache_xmlbeans.namespace.http_3A_2F_2Fschemas_2Ex mlsoap_2Eorg_2Fwsdl_2F,
schemaorg_apache_xmlbeans.namespace.http_3A_2F_2Fschemas_2Ex mlsoap_2Eorg_2Fwsdl_2Fsoap_2F,
schemaorg_apache_xmlbeans.src,
schemaorg_apache_xmlbeans.system.sD37E2E9B26AED81157CFCDE7D9 DCB755,
schemaorg_apache_xmlbeans.type.http_3A_2F_2Fschemas_2Exmlsoa p_2Eorg_2Fwsdl_2F,
schemaorg_apache_xmlbeans.type.http_3A_2F_2Fschemas_2Exmlsoa p_2Eorg_2Fwsdl_2Fsoap_2F
build.properties for MibFixLibs:
bin.includes = JDOMAbout$Author.class,\
JDOMAbout$Info.class,\
JDOMAbout.class,\
META-INF/,\
axis-tasks.properties,\
axis-test-tasks.properties,\
log4j.properties,\
simplelog.properties
Re: Problem with Eclipse Product Export Wizard. [message #443921 is a reply to message #443905] Tue, 07 February 2006 06:43 Go to previous messageGo to next message
Are you absolutely sure that you have not a single project in your
workspace which is imported as a binary project with linked content? Try
the following. Check in your projects into CVS. Export your preferences to
a file. Switch to a new workspace by choosing the menu item and specifiy a
workspace name which is really new. In the new workspace import your
preferences and then import your projects from CVS. Now try your exports
again.
Also look directly into some of your source files. There are types of
problems which do not show up with error markers in the project explorer
but only directly in the source files. This is pretty annoying as you
thing everything is ok but there are still errors present. This happen
often if classpath issues are present.
Only to rule another thing out, look into the build path tab in your
project properties. Are any errors/warnings present?
Ricky
Re: Problem with Eclipse Product Export Wizard. [message #443950 is a reply to message #443905] Tue, 07 February 2006 08:07 Go to previous messageGo to next message
MIBFix and it's build properties seem OK. Except why do you have all of
those libraries in here if they also appear to be listed in MIBFixLibs?
You have no src.. and bin.. in this plugin, I can only assume it doesn't
have any source in it. But even so, your bin.includes include a jar ...
but your Bundle-ClassPath doesn't ... You don't need anything out of the
jar?
> Bundle-ClassPath: .
> Export-Package: .,
> mibs.iana,
> mibs.ietf,
> Import-Package: bin
> LICENSE.txt,\
> META-INF/,\
> Mibble_1.0.0.jar,\
> README.txt,\
> mibs/
This one also doesn't have a src.. ... I assume you've taken a couple of
jars and imported them as plugin from jar archives, so the .class files
are right off of the . directory. This might be OK, but I'm not sure.
When I create a new plugin from some of my existing java jars, I get a
manifest/build.properties:
Bundle-Name: Logging Plug-in
Bundle-SymbolicName: com.ex.logging
Bundle-ClassPath: .
Export-Package: com.example.log
source.. = .
output.. = .
bin.includes = META-INF/,\
com/
> Bundle-ClassPath: .
> Export-Package: com.cisco.nmtg.mibpolice.api,
> com.ibm.wsdl,
> com.ibm.wsdl.util,
> com.ibm.wsdl.xml,
> javax.wsdl,
> javax.wsdl.factory,
> javax.wsdl.xml,
> javax.xml.rpc,
> javax.xml.rpc.soap,
> javax.xml.soap,
> org.apache.axis,
> org.apache.log4j,
> org.jdom,
> org.jdom.adapters,
> org.jdom.filter,
> org.jdom.input,
> org.jdom.output,
> org.jdom.transform,
> org.jdom.xpath,
> org.soapinterop,
> JDOMAbout.class,\
> META-INF/,\
> log4j.properties,\
Re: Problem with Eclipse Product Export Wizard. [message #444347 is a reply to message #443921] Tue, 14 February 2006 07:02 Go to previous messageGo to next message
As you suggested, I imported freshly all the plugins without marking
"binary project with linked content" check box. But while exporting I see
a new type of error.
Also, I verified the build tab properties and all the project files and
couldnt find any errors.
Please note that launching the product internally works fine. Only problem
is faced when exporting the product.
The error message prints that org.eclipse.core.runtime could not find the
product MIBFix.product.
Thenmozhi.
!SESSION 2006-02-14 17:26:22.593
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.runtime 2006-02-14 17:26:24.416
!MESSAGE Product MIBFix.product could not be found.
!ENTRY org.eclipse.osgi 2006-02-14 17:26:24.426
!STACK 1
java.lang.RuntimeException: No application id has been found.
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:204)
at
at
Manifest:
Require-Bundle: org.eclipse.rcp,
org.eclipse.ui,
org.eclipse.ui.ide,
Mibble,
org.eclipse.help,
org.apache.lucene,
org.eclipse.tomcat,
MIBFixLibs,
org.eclipse.ui.views,
org.eclipse.update.configurator,
org.eclipse.osgi.util,
org.apache.ant,
org.eclipse.core.runtime.compatibility,
org.eclipse.core.expressions,
org.eclipse.core.variables,
org.eclipse.ant.core,
org.eclipse.update.core,
org.eclipse.update.ui,
org.eclipse.ant.ui,
org.eclipse.compare,
org.eclipse.core.boot,
org.eclipse.debug.core,
org.eclipse.debug.ui,
org.eclipse.jdt,
org.eclipse.jdt.core,
org.eclipse.jdt.debug,
org.eclipse.jdt.debug.ui,
org.eclipse.jdt.doc.isv,
org.eclipse.jdt.doc.user,
org.eclipse.jdt.junit,
org.eclipse.jdt.junit.runtime,
org.eclipse.jdt.launching,
org.eclipse.jdt.source,
org.eclipse.jdt.ui,
org.eclipse.ltk.core.refactoring,
org.eclipse.ltk.ui.refactoring,
org.eclipse.osgi.services,
org.eclipse.pde,
org.eclipse.pde.build,
org.eclipse.pde.core,
org.eclipse.pde.doc.user,
org.eclipse.pde.junit.runtime,
org.eclipse.pde.runtime,
org.eclipse.pde.source,
org.eclipse.pde.ui,
org.eclipse.platform,
org.eclipse.platform.doc.isv,
org.eclipse.platform.doc.user,
org.eclipse.platform.source,
org.eclipse.rcp.source,
org.eclipse.sdk,
org.eclipse.search,
org.eclipse.team.core,
org.eclipse.team.cvs.core,
org.eclipse.team.cvs.ssh,
org.eclipse.team.cvs.ssh2,
org.eclipse.team.cvs.ui,
org.eclipse.team.ui,
org.eclipse.ui.browser,
org.eclipse.ui.cheatsheets,
org.eclipse.ui.console,
org.eclipse.ui.externaltools,
org.eclipse.ui.intro,
org.eclipse.ui.presentations.r21,
org.eclipse.update.scheduler,
org.junit
build.properties:
build.properties,\
data/,\
html/,\
icons/,\
lib/,\
META-INF/,\
mibs/,\
plugin.xml,\
src/,\
template/,\
toc.xml,\
toc_CLR.xml,\
toc_Cookbook.xml,\
toc_FAQ.xml,\
Re: Problem with Eclipse Product Export Wizard. [message #444397 is a reply to message #444347] Wed, 15 February 2006 05:29 Go to previous messageGo to next message
> the product MIBFix.product.
How is your product setup? In which plugin is your .product file, how does
the product file looks like and where is the application definied? One
glitch in applications and products is the naming scheme. In plugin A you
define an application extension with id "appid". In plugin P you define a
product extension with id "prodid" and reference the application with
"A.appid". Finally in your .product file you refernce the product with
"P.prodid". Please check your spelling of the ids and there concatenation.
hth,
Ricky
Re: Problem with Eclipse Product Export Wizard. [message #444486 is a reply to message #444397] Thu, 16 February 2006 08:01 Go to previous messageGo to next message
Hi Ricky,
I have resolved this "no application id" error. Actually I missed to
include the required plugins in the feature project and that is the reason
for product not found.
But, I'm getting the original error (" org.osgi.framework.BundleException:
The activator com.cisco.mibfix.designtool.gui.main.MIBFixPlugin for bundle
MIBFix is invalid).
I'm sure that this error is due to missing correct classpath settings.
But I tried all possible classpath settings..
From net, I have downloaded the classpath helper s/w. In what way this can
be used to find out classnotFoundException? Any idea about classpathhelper?
Thenmozhi
My Error logs:
!SESSION 2006-02-16 18:24:18.493
!ENTRY org.eclipse.osgi 2006-02-16 18:24:27.25
!MESSAGE An error occurred while automatically activating bundle MIBFix
(5).
!STACK 0
invalid
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 27 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 2006-02-16 18:24:27.35
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
Manifest.mf:
org.eclipse.ui.ide,
Mibble,
org.eclipse.help,
org.apache.lucene,
org.eclipse.tomcat,
MIBFixLibs,
Bundle-ClassPath: com.cisco.mibfix.designtool
build.properties:
build.properties,\
data/,\
html/,\
icons/,\
lib/,\
META-INF/,\
mibs/,\
plugin.xml,\
src/,\
template/,\
toc.xml,\
toc_CLR.xml,\
toc_Cookbook.xml,\
toc_FAQ.xml,\
mibfix.product
Re: Problem with Eclipse Product Export Wizard. [message #444494 is a reply to message #444486] Thu, 16 February 2006 09:54 Go to previous message
> can be used to find out classnotFoundException? Any idea about
> classpathhelper?
From a brief look at the description of the project I do not see the
advantage of classpathhelper to a normal classloader.
Do you get the exception when exporting or when running the application? I
got it while running and when some dependend plugins are missing or an
exception was thrown in the constructors of dependend plugins. My only
problems in the process of exporting stem from "binary projects with
linked content" I think.
If you encounter these exceptions while exporting I do not know why. If it
is at runtime there are some things we could check.
Ricky
Previous Topic:An other dumb question
Next Topic:How to get absolute plugin path programmatically
Current Time: Sat Jul 26 05:18:09 EDT 2025
Powered by FUDForum. Page generated in 0.28631 seconds
