Home » Archived » Test and Performance Tools Platform (TPTP) » Need help in Agent Contrller Configuration
Need help in Agent Contrller Configuration [message #41863] Wed, 23 November 2005 04:49 Go to next message
Originally posted by: vinaykumarkv.gmail.com
I'm new to TPTP. i downloaded TPTP 4.1.0 (ALL) and Agent Controller V4.0
(Win). I configured the setConfig.bat file and created the servicename and
when i am running RAServer.exe im getting following message in the command
prompt
java.lang.NoClassDefFoundError:
org/eclipse/hyades/internal/collection/framework
/FileServerParametersImpl
But the profiling is done in the eclipse.with out any problems.
i dont have any pulgins called
org.eclipse.hyades.internal.collection.framework.FileServerP aramereslmpl
in my eclipse plugins or Agent Controller plugins
is there any thing to download for hyades.
Please reply to these queries.
Thanks in advance.
regards,
Vinay
Re: Need help in Agent Contrller Configuration [message #42050 is a reply to message #41863] Wed, 23 November 2005 10:42 Go to previous messageGo to next message
The file that you have referenced here is located in the following jar file:
<AGENT-CONTROLLER-HOME>\plugins\org.eclipse.tptp.platform.collection.framewo
rk_4.0.0\hcframe.jar
The agent controller is able to find this file by the classpath entries that
are registered under:
rk_4.0.0\config\pluginconfig.xml
Please make sure that these files are present. You can also check under
<AGENT-CONTROLLER-HOME>\config\servicelog.log to see if it has logged any
errors. This log file is in CBE format so you can import it in your 4.1
workbench as a log file.
I was able to successfully use AC 4.0 with TPTP4.1.
Please attach your servicelog.log file to this report.
"Vinay" <vinaykumarkv@gmail.com> wrote in message
news:e340ead352d6d05ffbdcb00f4cd06a91$1@www.eclipse.org...
> prompt
> Thanks in advance.
> regards,
> Vinay
Re: Need help in Agent Contrller Configuration [message #43889 is a reply to message #42050] Wed, 30 November 2005 08:02 Go to previous messageGo to next message
Hi Ali,
Regret for the delay, Thanks for ur suggestion. i checked all the things
what u suggested every thing is fine. still im getting that message in the
RAServer.exe console
Here im attaching the Servicelog file of mine.
<CommonBaseEvent creationTime="2005-11-30T12:55:38.172000Z"
globalInstanceId="AC8E17402AF94778938A450410FBED6B" msg="Service starting"
severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine"
componentIdType="Application" location="10.152.11.130" locationType="IPV4"
processId="996"
subComponent="..\RAServerConfig\RAServerConfigBinding2.cpp"
componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-11-30T12:55:38.328000Z"
globalInstanceId="ABB828BD153143138612D7A727392395" msg="Start processing
plugin: org.apache.jakarta_commons_logging_1.0.3" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-11-30T12:55:38.344000Z"
globalInstanceId="A46612CF4BAB4221957B0ECCA2887C13" msg="Plugin loader:
Config file for plugin: org.apache.jakarta_commons_logging_1.0.3 not
found" severity="30" version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AEAE44ACCD0441408FF5BE5BD3A77D21" msg="Finished
processing plugin: org.apache.jakarta_commons_logging_1.0.3" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AAE835EFE7424B0A838AA5C11ABAEB6D" msg="Start processing
plugin: org.eclipse.hyades.execution_4.1.0" severity="10" version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A775D5ABA80D484097BD7D15A0512DFB" msg="Plugin loader:
Config file for plugin: org.eclipse.hyades.execution_4.1.0 loaded
successfully" severity="10" version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A1890F80F3EC4996847A7DABFED063C0" msg="Finished
processing plugin: org.eclipse.hyades.execution_4.1.0" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AFB1B6FDBDF742CDABFF5F97626BEFDB" msg="Start processing
plugin: org.eclipse.hyades.logging.adapter_4.1.0" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A8F3BFB588E1456983C7E3930684EDFE" msg="Plugin loader:
Config file for plugin: org.eclipse.hyades.logging.adapter_4.1.0 loaded
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AA9D67606C1D4CEE9A9F47C6FFC379CB" msg="Finished
processing plugin: org.eclipse.hyades.logging.adapter_4.1.0" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AE5A2A406010447DB3D083C9427831A8" msg="Start processing
plugin: org.eclipse.hyades.logging.core_4.1.0" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A278C4F1274E492AA0FDFAA08C41598D" msg="This plugin is
dependent on org.eclipse.hyades.execution" severity="10" version="1.0.1">
processId="996"
subComponent="..\RAServerConfig\RAServerConfigHandler2.cpp"
</situation>
</CommonBaseEvent>
globalInstanceId="ACE6B531114341E58EB42E1F39DDA2BC" msg="Plugin loader:
Plugin: org.eclipse.hyades.execution not found" severity="30"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A3CFF18CC69F4012B50C7331FB6F7876" msg="Recovery: since
there is no version requirement, trying to load plugin instead:
org.eclipse.hyades.execution_4.1.0" severity="30" version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A3466A75B44849C48C6A78607C9E10C6" msg="Plugin
org.eclipse.hyades.execution_4.1.0 already loaded" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A59E24F3702A4DFF93C85A41B00C6D55" msg="Plugin loader:
Config file for plugin: org.eclipse.hyades.logging.core_4.1.0 loaded
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A203720D4E1945E282A4336AA9A10A54" msg="Finished
processing plugin: org.eclipse.hyades.logging.core_4.1.0" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AFB543F63A8046BB83974664B8AB3945" msg="Start processing
plugin: org.eclipse.hyades.logging.parsers_4.1.0" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A81428361E6B47048C36E9FC0AFB3AD7" msg="This plugin is
dependent on org.eclipse.hyades.logging.core" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="ACF1651339494B688DE53B6A85F7C5FD" msg="Plugin loader:
Plugin: org.eclipse.hyades.logging.core not found" severity="30"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A5892738AB914A4196B19121C41EF502" msg="Recovery: since
org.eclipse.hyades.logging.core_4.1.0" severity="30" version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A0C4758F5FAA47908655F827113C5044" msg="Plugin
org.eclipse.hyades.logging.core_4.1.0 already loaded" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A815C9E4BC5241AC95D2BD595BA4BCF4" msg="This plugin is
dependent on org.eclipse.hyades.logging.adapter" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AE74D2D7FE0649D3B8031C8898C8E367" msg="Plugin loader:
Plugin: org.eclipse.hyades.logging.adapter not found" severity="30"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AC3A21C56D054EA4A61DA310097F970F" msg="Recovery: since
org.eclipse.hyades.logging.adapter_4.1.0" severity="30" version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A78EF753908042229C043C83FEB0E36D" msg="Plugin
org.eclipse.hyades.logging.adapter_4.1.0 already loaded" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-11-30T12:55:38.359000Z"
globalInstanceId="AC2A503D7C074C7FB206E6D7A494E893" msg="Plugin loader:
Config file for plugin: org.eclipse.hyades.logging.parsers_4.1.0 loaded
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="ADD8942B703A4B709358CA1633C20CCA" msg="Finished
processing plugin: org.eclipse.hyades.logging.parsers_4.1.0" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A350FF9177974FA79305FB76E4259AC8" msg="Start processing
plugin: org.eclipse.hyades.perfmon.agents_4.0.0" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="ACC3E8A8A5F34721A4CAD481BC65EEC3" msg="This plugin is
dependent on org.eclipse.tptp.platform.collection.framework" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AE32C60243384AA285B146AF6697BC19" msg="Plugin loader:
Plugin: org.eclipse.tptp.platform.collection.framework not found"
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A9864CA17994441AB2379D87CB112780" msg="Recovery: since
org.eclipse.tptp.platform.collection.framework_4.0.0" severity="30"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A9D93EB5AB7B405DA646D5C3D54FF976" msg="This plugin is
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A8DF6E1EFA5844D4A2C0683378A6B119" msg="Plugin loader:
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AD4CEEA2796D4E23B770AC5422627FF7" msg="Recovery: since
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A937E24F8D464CD1A30EF99A8DF272B2" msg="Plugin
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A748A3C56F484AAB85324746062B7E01" msg="This plugin is
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AE0C5151C6824C72879B6B97084F4B1F" msg="Plugin loader:
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AFC164CC1B9A44FC98825972A5611856" msg="Recovery: since
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AECF1C94ADAD45D39FCE217FCEE1FB0C" msg="Plugin
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-11-30T12:55:38.375000Z"
globalInstanceId="A736447BDDAC45468374855E81A483A9" msg="Severe error
while parsing
file=D:\AgentCtrl\plugins\org.eclipse.tptp.platform.collecti on.framework_4.0.0\config\pluginconfig.xml
line=4 column=58 message=Expected whitespace" severity="55"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-11-30T12:55:38.391000Z"
globalInstanceId="ABB8E4A782DD48688E0A4FF2056C1BBD" msg="Failure parsing
config file" severity="55" version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A7DD5507F1364581AA0A81E3628E85F8" msg="Plugin loader:
org.eclipse.tptp.platform.collection.framework_4.0.0 not valid"
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A77FDEBC72F0450CAEAA1B57DB4729AF" msg="Recovery: failed"
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AD044DA1BA2E405D9F48BEA086F978A7" msg="Failure parsing
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A6D5A0672702487B80CE495C79F4D00E" msg="Plugin loader:
Config file for plugin: org.eclipse.hyades.perfmon.agents_4.0.0 not valid"
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A6CCBAF1237E4C25842D0039128D9721" msg="Finished
processing plugin: org.eclipse.hyades.perfmon.agents_4.0.0" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A8C003CF359C434691DB99CD2BC07DC0" msg="Start processing
plugin: org.eclipse.hyades.test.core_4.1.0" severity="10" version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A5C7D8D6EF7642FD8DA51C7F41FE8B4F" msg="This plugin is
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AF9775330C69441C92A621BA906A1879" msg="Plugin loader:
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AF8FB4B2352F4A1FA9506B9EB5280264" msg="Recovery: since
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AFD64AA174754AB6A6071FA4B3106302" msg="Plugin
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AB22EA12D71F4EE996E7C3FA6F87678C" msg="This plugin is
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AF4745CAE6A44DF29DA0FA3336765109" msg="Plugin loader:
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AD4B8D72CD9F48FBA86959004BC62B25" msg="Recovery: since
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A9209AE7914A4B30A0E80A18BEF951FC" msg="Plugin
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A23D04BF737449929D4D0505550CD952" msg="Plugin loader:
Config file for plugin: org.eclipse.hyades.test.core_4.1.0 loaded
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AA08D1CF529A4C60AE97EDE446E3ABBD" msg="Finished
processing plugin: org.eclipse.hyades.test.core_4.1.0" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AFD62AA9DB604771A7E2C8C2907336E0" msg="Start processing
plugin: org.eclipse.hyades.test.tools.core_4.1.0" severity="10"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="AE74E3F647E447F99D86434E74F59109" msg="This plugin is
dependent on org.eclipse.hyades.test.core" severity="10" version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
globalInstanceId="A309B20775FD45EE87C8DCADFDE4FE88" msg="Plugin loader:
Plugin: org.eclipse.hyades.test.core not found" severity="30"
version="1.0.1">
processId="996"
</situation>
</CommonBaseEvent>
Re: Need help in Agent Contrller Configuration [message #43928 is a reply to message #43889] Wed, 30 November 2005 10:03 Go to previous messageGo to next message
Hi Vinay,
The log file indicates that there is an error in the pluginconfig.xml file
of your org.eclipse.tptp.platform.collection.framework_4.0.0 file. Here's
the error message:
Severe error while parsing
..0\config\pluginconfig.xml line=4 column=58 message=Expected whitespace
This would explain why the JAR files were not found (since the plugin is
never loaded and the classpath entries that are included in its
pluginconfig.xml file are never added to your classpath). Please follow the
steps below:
- Stop the Agent Controller
- Rename servicelog.log to servicelog.log.old
- Open the pluginconfig.xml file of the plugin mentioned above
- Fix the error in the xml file as indicated by the error message (i.e. line
4 column58 expected whitespace)
- Restart the Agent Controller
There will be a new servicelog.log file generated. Import this file into
your workbench (File > Import > Log File > Add > Common Base Event XML log
> Switch to the details page > Specify the path to the log file > OK).
Observe if there are any severe errors reported (severe messages are
indicated by a red icon).
Here's what I have in my pluginconfig.xml file of my plugin:
<PluginConfiguration requires="org.eclipse.hyades.execution,
org.eclipse.hyades.logging.core">
<AgentControllerEnvironment configuration="default">
<Variable name="JBOSS_HOME" position="replace" value="null"/>
<Variable name="JONAS_HOME" position="replace" value="null"/>
<Variable name="CLASSPATH" position="prepend"
value=" %PLUGINS_HOME%\org.eclipse.tptp.platform.collection.framewor k_4.1.0\h
cframe.jar"/>
<Variable name="CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK "
position="append"
cframe.jar"/>
</AgentControllerEnvironment>
<Application configuration="default" executable="PerfmonAgent"
location="%RASERVER_HOME%\bin" path="%RASERVER_HOME%\bin\PerfmonAgent.exe">
<Variable name="CLASSPATH" position="append"
value="%CLASSPATH_ORG_ECLIPSE_HYADES_LOGGING_CORE%"/>
value="%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%"/>
value="%CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK% "/>
</Application>
<Agent configuration="default" name="Java Profiling Agent" client="DYNAMIC"
dataChannelSize="64M" type="Profiler"/>
<Option name="Thread Analysis Agent" type="Profiler" value="hcthread"/>
<Option type="version"
name="org.eclipse.tptp.platform.collection.framework" value="4.1.0"/>
</PluginConfiguration>
The error that you are experiencing is likely caused by the inputs that you
have provided to setConfig.bat (most likely a bad input for the JBoss
server).
Hope this helps.
news:6346361e472fff60cc0f1fb02c5df7d1$1@www.eclipse.org...
> Hi Ali,
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> while parsing
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> processId="996"
> </situation>
> </CommonBaseEvent>
Re: Need help in Agent Contrller Configuration [message #44234 is a reply to message #43928] Thu, 01 December 2005 05:18 Go to previous messageGo to next message
Thanks Ali,
Its working now, it just went wrong in giving path of the JBOSS App Server
during the configuration of SetConfig.bat.
Hey i have one query
1.Can i test my own Swing Application by using Automatic GUI Recorder. Can
this AGR Capture my actions.
If so can u pls provide me the relative stuff. I dont find this kind of
example in "An Introduction to Using TPTP's Automated GUI Recorder"
Document.
Thanks and Regards,
Vinay
Re: Need help in Agent Contrller Configuration [message #44388 is a reply to message #44234] Thu, 01 December 2005 19:17 Go to previous message
Unfortunately you can't test standalone swing applications with AGR.
RCP and standalone SWT applications are targeted next (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=114159). Swing applications
will not be containable in 4.2 because of a lack of resources.
news:6d7cf9750f66ec8f9218861c3497139c$1@www.eclipse.org...
> Thanks Ali,
> Document.
> Thanks and Regards,
> Vinay
Previous Topic:Stand Alone program to test
Next Topic:TPTP 4.1 release available
Current Time: Sun Jul 27 11:25:15 EDT 2025
Powered by FUDForum. Page generated in 0.05089 seconds
