Home » Eclipse Projects » Rich Client Platform (RCP) » Antoher "unable to open editor, unknown ID" problem
Antoher "unable to open editor, unknown ID" problem [message #441892] |
Sat, 07 January 2006 15:38  |
Originally posted by: psentosa.yahoo.com
Hi...
sorry for posting an old problem again, but I coulnd't find any working solution for my problem in the threads... so please give me some advice if you have..
I'm trying to develop a GUI based on RCP. Right know I'd like to create an editor, which pops up, when an item of the tree viewer is selected by choosing a menu entry.
But I can't get the editor working, cause I got the PartInitException: Unable to open editor, unknown editor ID.
The steps I've made so far are as follows:
- creating the editor class, which is subclass of EditorPart (TestEditor)
- creating the editor input class, which implements IEditorInput (TestEditorInput)
- specify the action class(TestAction), to supply the menu entry on the GUI, which also calls the function
page.openEditor(input,TestEditor.ID)
This ID is defined in the editor class as follows:
public static String ID = "test.editor.testEditor"
and also defined in the plugin.xml for an editor extension.
Below I paste the failure report I got, when I tried to choose the menu
Can someone please help me? I'm quite desperate..:-(
Thank you very much in advance
Paul
org.eclipse.ui.PartInitException: Unable to open editor, unknown editor ID: test.testEditor
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:630)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2381)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2316)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2308)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2294)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2289)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2274)
at test.action.TestAction.run(TestAction.java:93)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:492 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:530)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:480)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:392)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:914)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3285)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2905)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1762)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1726)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:397)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at test.core.TestApplication.run(TestApplication.java:19)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:109)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
View in EZ forum: http://www.eclipsezone.com/eclipse/forums/m91979789.html
Re: Antoher "unable to open editor, unknown ID" problem [message #441893 is a reply to message #441892] |
Sat, 07 January 2006 15:48   |
Paul, did you create the testEditorActionBarContributor which implements
IActionBarContributor - because you need to.
Paul Sentosa wrote:
> Hi...
> Regards
> Paul
Re: Antoher "unable to open editor, unknown ID" problem [message #441897 is a reply to message #441892] |
Sat, 07 January 2006 20:31   |
you define ID 'test.editor.testEditor', and try open ID test.testEditor
(i think)
Paul Sentosa wrote:
> Hi...
> you have..
> choosing a menu entry. But I can't get the editor working, cause I got the
> PartInitException: Unable to open editor, unknown editor ID. The steps
> I've made so far are as follows: - creating the editor class, which is
> subclass of EditorPart (TestEditor) - creating the editor input class,
> which implements IEditorInput (TestEditorInput) - specify the action
> the function
> Regards
> Paul
> at
> at
> at
> at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2294) at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69) at
> at
> at test.action.TestAction.run(TestAction.java:93) at
> org.eclipse.jface.action.Action.runWithEvent(Action.java:492 ) at
> at
(ActionContributionItem.java:480)
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66) at
> org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:914) at
> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3285) at
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2905) at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1762) at
> org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1726) at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143) at
> test.core.TestApplication.run(TestApplication.java:19) at
> at
> at
> at
> at
> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
> at
> at java.lang.reflect.Method.invoke(Method.java:585) at
> org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 ) at
> org.eclipse.core.launcher.Main.basicRun(Main.java:282) at
> org.eclipse.core.launcher.Main.run(Main.java:977) at
Re: Antoher "unable to open editor, unknown ID" problem [message #441915 is a reply to message #441909] |
Sun, 08 January 2006 09:49   |
Paul,
your error
test.testEditor
tell that you try open unknown editor ID - you have defined another ID
or your definition (editors extension point) is invalid
check double your extension point
Paul Sentosa wrote:
> Hi...
> the example of HYPERBOLA is exactly the example from the book I meant
> before...and I followed the steps as stated in it, but I couldn't get it
> working..unfortunately the book didn't mention anything about such case..
> From the error report I got, I tried to follow up the first line, which
> is:
> <b>PartInitException</b>:Unable to open editor, unknown editor ID:
> net.sf.bibxmleditor.ui.modifyEditor at
> From the class EditorManager line 630 are following codes to see:
> IEditorRegistry reg = getEditorRegistry();
> EditorDescriptor desc = (EditorDescriptor)
> <b>reg.findEditor(editorId);</b> <b>if (desc == null)</b> {
> throw new PartInitException(
NLS.bind(WorkbenchMessages.EditorManager_unknownEditorIDMess age,editorId
> I suppose that the EditorRegistry couldn' find the editor. Do you have any
> idea, what this could mean, and how I can solve this problem? Thanks in
> advance
> ps
> View in EZ forum: http://www.eclipsezone.com/eclipse/forums/m91979921.html
Current Time: Thu Sep 18 05:12:16 EDT 2025
Powered by FUDForum. Page generated in 0.07029 seconds
