Home » Modeling » Epsilon » Calling EOL from Java
Calling EOL from Java [message #442964] Fri, 31 July 2009 09:52 Go to next message
Hi all,
I'm currently playing with running Epsilon (specifically an EOL file) from
Java, using the org.eclipse.epsilon.examples.standalone examples provided
by Epsilon as a starting point, and I've just come into a little stumbling
point.
I find that when I call a specific EOL operation (as per the example in
org.eclipse.epsilon.examples.standalone.eol), it successfully executes
only when the EOL operation definition does not make calls to other EOL
operations. A code snippet is below:
-- overriden method of EpsilonStandaloneExample in
protected Object execute(IEolExecutableModule module) throws
EolRuntimeException {
// get third operation defined in the EOL file, and execute it
EolOperation operation = module.getDeclaredOperations().get(3);
operation.execute(null, parameters, module.getContext());
Am I doing something wrong or I need to somehow explicitly load all used
operations first?
Any pointers would be greatly appreciated.
Best,
Edd
Re: Calling EOL from Java [message #443168 is a reply to message #442964] Fri, 31 July 2009 10:08 Go to previous messageGo to next message
Hi Edd,
You should call the prepare() method of the module before executing the
operation (module.execute() does this by default):
module.prepare();
Dimitris
Edward Turner wrote:
> Hi all,
> from Java, using the org.eclipse.epsilon.examples.standalone examples
> provided by Epsilon as a starting point, and I've just come into a
> little stumbling point.
> operations first?
> Best,
> Edd
Re: Calling EOL from Java [message #443458 is a reply to message #443168] Fri, 31 July 2009 10:48 Go to previous message
> Hi Edd,
Hia Dimitris, thanks for your swift reply!
> module.prepare();
Great -- yes that was the solution.
Just a note, this didn't work straight off because
org.eclipse.epsilon.examples.standalone.EpsilonStandaloneExa mple defines
the variable,
protected IEolExecutableModule module;
.. and the interface, IEolExecutableModule does not require definition of
the prepare() method. Instead of adding this method to the interface, I
just changed the example so that module is defined (in
org.eclipse.epsilon.examples.standalone.EpsilonStandaloneExa mple) as:
protected EolModule module;
And so then, calling prepare() is fine.
Anyway -- many thanks for your help.
> Cheers,
> Dimitris
Edd
Re: Calling EOL from Java [message #572071 is a reply to message #442964] Fri, 31 July 2009 10:08 Go to previous message
Hi Edd,
module.prepare();
Dimitris
> Hi all,
> operations first?
> Best,
> Edd
Re: Calling EOL from Java [message #572099 is a reply to message #443168] Fri, 31 July 2009 10:48 Go to previous message
> Hi Edd,
> module.prepare();
the variable,
> Cheers,
> Dimitris
Edd
Previous Topic:Calling EOL from Java
Next Topic:Problem running ETL using Epsilon/ANT
Current Time: Wed Jul 23 22:54:11 EDT 2025
Powered by FUDForum. Page generated in 0.06512 seconds
