Home » Modeling » Epsilon » [EGL] [newbie] Multiple input models problem
[EGL] [newbie] Multiple input models problem [message #432405] Thu, 30 July 2009 12:41 Go to next message
Hi all,
I'm trying to use two different (two meta-model) input models in EGL
template run configuration but it seems that it accepts only the first
one. For instance, if I define models as ModelX and ModelY, ModelY is not
recognized by engine and vice versa.
I tried models with their own related codes, one by one and both models
are flawless separately. On the other hand, running two input model
displays an error message for the second model: "Type 'ModelYSubType' not
found".
Any help is much appreciated...
Re: [EGL] [newbie] Multiple input models problem [message #432790 is a reply to message #432405] Thu, 30 July 2009 13:15 Go to previous messageGo to next message
Orcun wrote:
> Hi all,
> not recognized by engine and vice versa.
Just to clarify, do you have 2 models: 1 is an instance of MetamodelX
and 1 is an instance of MetamodelY?
> not found".
What results do you get when running the following simple template with
2 input models, one called ModelX and the other called ModelY?
[%=ModelX!AClassFromMetamodelX.all%]
[%=ModelY!AClassFromMetamodelY.all%]
Be sure to replace AClassFromMetamodelX (AClassFromMetamodelY) with the
name of an EClass from the the metamodel of ModelX (ModelY).
Louis.
Louis Rose
Research Student
Department of Computer Science,
University of York,
Heslington, York, YO10 5DD, United Kingdom.
+44 1904 434762
Twitter: @louismrose
Re: [EGL] [newbie] Multiple input models problem [message #440584 is a reply to message #432790] Fri, 31 July 2009 04:40 Go to previous messageGo to next message
[%=DomainModel!Component.all%]
<delimiter>
[%=FeatureModel!Feature.all%]
[org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1875a82 (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@2ca90c (name: Component)
(instanceClassName: null) (abstract: false, interface: false)),
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@14742ee (eClass:
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@17b3295 (eClass:
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1360218 (eClass:
(instanceClassName: null) (abstract: false, interface: false))]
<delimiter>
[org.eclipse.emf.ecore.impl.DynamicEObjectImpl@c03da9 (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@6288ed (name: Feature)
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1103411 (eClass:
Re: [EGL] [newbie] Multiple input models problem [message #441280 is a reply to message #440584] Fri, 31 July 2009 06:10 Go to previous messageGo to next message
> <delimiter>
> <delimiter>
Great, so this looks like you have 4 Components in your domain model and
2 Features in your feature model.
Be sure to prefix all uses of a metaclass name with the name of the
model. So, always use (for example):
rather than:
Component
Does this answer your original question, or do you still have errors
when running your EGL script?
Louis.
Re: [EGL] [newbie] Multiple input models problem [message #442963 is a reply to message #441280] Fri, 31 July 2009 09:45 Go to previous message
Louis,
Explicit usage solved my problem, thank you for your swift reply...
Re: [EGL] [newbie] Multiple input models problem [message #571793 is a reply to message #432405] Thu, 30 July 2009 13:15 Go to previous message
Orcun wrote:
> Hi all,
> not found".
Louis.
Louis Rose
Research Student
University of York,
+44 1904 434762
Re: [EGL] [newbie] Multiple input models problem [message #571922 is a reply to message #432790] Fri, 31 July 2009 04:40 Go to previous message
<delimiter>
<delimiter>
Re: [EGL] [newbie] Multiple input models problem [message #571943 is a reply to message #440584] Fri, 31 July 2009 06:10 Go to previous message
> <delimiter>
> <delimiter>
rather than:
Component
Louis.
Re: [EGL] [newbie] Multiple input models problem [message #572010 is a reply to message #441280] Fri, 31 July 2009 09:45 Go to previous message
Louis,
Previous Topic:[ETL][Newbie] how to execute ETL script
Next Topic:Calling EOL from Java
Current Time: Fri Jul 18 23:56:29 EDT 2025
Powered by FUDForum. Page generated in 0.05055 seconds
