How to show an non-rectangular window in task bar [message #442656] |
Thu, 09 September 2004 21:20  |
Originally posted by: lwj.hz.cn
When I tried to create an non-rectangular window with a statement like
"Shell shell = new Shell(display, SWT.NO_TRIM)", although it works but
didn't show in the windows' task bar. How can I make it possible?
Re: How to show an non-rectangular window in task bar [message #442700 is a reply to message #442670] |
Sat, 11 September 2004 23:11   |
Thanks for your post. Maybe I can describe the problem with the sample
codes listed below.
The only thing I want is that This application should show in the windows
task bar just like other application windows.
Anyone can help me?
* Created on 2004-9-10
package snippets;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.MouseAdapter;
import org.eclipse.swt.events.MouseEvent;
import org.eclipse.swt.graphics.Region;
import org.eclipse.swt.widgets.Shell;
* @author lvweijian
public class TestNoneRectangleWindow {
TestNoneRectangleWindow window = new TestNoneRectangleWindow();
window.open();
public void open() {
final Display display = new Display();
final Shell shell = new Shell(display, SWT.NO_TRIM);
shell.setText("SWT Application");
Region region = new Region();
region.add(new int[]{100,0,200,150,0,150});
shell.setRegion(region);
shell.setBackground(display.getSystemColor(SWT.COLOR_INFO_BA CKGROUND));
shell.addMouseListener(new MouseAdapter() {
public void mouseDoubleClick(MouseEvent e) {
shell.close();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
Steve Northover wrote:
> Did you call shell.open() or shell.setVisible()? Did you call
> Shell.setText()? If your the parent of your shell is another shell, it
> won't show up.
> "lvweijian" <lwj@hz.cn> wrote in message news:chqval$icv$1@eclipse.org...
Re: How to show an non-rectangular window in task bar [message #442803 is a reply to message #442700] |
Mon, 13 September 2004 13:05  |
WORKSFORME.
I see an item in the task bar called 'SWT Application'. Are you running
3.0?
"lwj" <lvweijian@hz.cn> wrote in message news:ci0epn$dei$1@eclipse.org...
> codes listed below.
> Anyone can help me?
> package snippets;
> import org.eclipse.swt.widgets.Display;
> * @author lvweijian
> public static void main(String[] args) {
> window.open();
> shell.close();
> shell.open();
> > won't show up.
FUDForum. Page generated in 0.03753 seconds
