Home » Eclipse Projects » Rich Client Platform (RCP) » Key Binding conflicts
Key Binding conflicts [message #442393] Mon, 16 January 2006 07:05 Go to next message
Originally posted by: yassine.bensaid_.caramail.com
I am trying to add key bindings to my application using the code (in the
plugin.xml file):
<extension point="org.eclipse.ui.contexts">
<context
name="App.context"
description="App context"
id="App.context">
<!-- parentId="org.eclipse.ui.windows"-->
</context>
</extension>
<extension point="org.eclipse.ui.commands">
<category
name="App.category"
id="App.category">
</category>
<command
name="Delete item"
description="Deletes item from the list"
categoryId="App.category"
id="App.delete">
</command>
</extension>
<extension point="org.eclipse.ui.bindings">
<scheme
name="%keyConfiguration.app.name"
description="%keyConfiguration.app.description"
id="ae.sphere.arena.appAcceleratorConfiguration">
</scheme>
<key
commandId="Mapping.delete"
contextId="Mapping.context"
sequence="Ctrl+DEL"
schemeId="org.eclipse.ui.appAcceleratorConfiguration" />
</extension>
I also insert the "definitionId" field within the corresponding action, as
well as registering the context in the editor. The result is that I get no
key binding or whatsoever.
If I use the defaultAcceleratorConfiguration (in schemeId), it works fine
as long as I do not use "standard" key sequences (such as "DEL" for
deleting or "Ctrl+P" for printing). However using "standard" key sequences
gives again nothing; I think it is due to a conflict and that "DEL" must
be already used in the defaultAcceleratorConfiguration cancelling (in the
eclipse fashion) both actions. That's where my <scheme>...</scheme> code
(in the bindings extension) usage came from.... but it's not working.
Can you please suggest anything so I can use "standard" key sequences in
my application?
Re: Key Binding conflicts [message #442414 is a reply to message #442393] Mon, 16 January 2006 11:49 Go to previous messageGo to next message
> my application?
Read "http://www.magma.ca/~pollockd/despumate/bindingsHowTo.html" and check
back here if you still have problems.
cheers,
d.
Re: Key Binding conflicts [message #442415 is a reply to message #442393] Mon, 16 January 2006 12:13 Go to previous messageGo to next message
Originally posted by: tomasz.luchowski.com
Read this article:
Among other things, it explains how to disable "standard" key configuration
so that you can plug-in your own and don't have conflicts if you try to
define something that already exists.
Tomasz
"Yassine Bensaid" <yassine.bensaid_@caramail.com> wrote in message
news:08e0ba0c495bb441f1fbc910cf54429a$1@www.eclipse.org...
>plugin.xml file):
> <context
> name="App.context"
> id="App.context">
> </context>
> </extension>
> <extension point="org.eclipse.ui.commands"> <category
> name="App.category"
> id="App.category">
> </category> <command
> name="Delete item"
> id="App.delete">
> </command>
> </extension>
> <scheme
> </scheme>
> <key
> sequence="Ctrl+DEL"
> </extension>
> my application?
Re: Key Binding conflicts (need help desperately!!!) [message #443786 is a reply to message #442414] Sat, 04 February 2006 08:57 Go to previous messageGo to next message
since I posted this mail, I've been reading books, related problems on
the news group and the link provided over and over
(http://www.magma.ca/~pollockd/despumate/bindingsHowTo.html). I think I
am by now an expert in what is not going to work for key bindings.
(sorry for this introduction...). Please help.
I will expose my problem again: I am using plugin.xml for all
configurations, and I am trying to bind the delete key "DEL" to delete
an item from a list. The action is already there; to say it all: if I
use bindings that are not already used (say "Ctrl+DEL"), it works fine
(I'm using org.eclipse.ui.bindings; org.eclipse.ui.commands;
org.eclipse.ui.contexts; put the definitionId in the action and add the
code site.getKeyBindingService().setScopes(new
String[]{"myPlugin.context"}) in the editor).
Now, I have learned from my readings, that
org.eclipse.ui.defaultAcceleratorConfiguration defines the command
org.eclipse.ui.edit.delete and therefore already reserves the sequence
"DEL". So: I either have to use another sequence if I want to use the
default accelerator (which I did, and is working but it is sadly not of
interest to me) OR use our own accelerator (using <scheme>...</scheme>)
which I also did BUT it is not working for some reason. YES, I did add
the line org.eclipse.ui/KEY_CONFIGURATION_ID=my.Accelerator.ID to
plugin_customization.ini (to avoid confusion I put it in both
development plugin and built plugin), but still not working. I used
debugging (with ".options" file) and it is showing me that (using my own
accelerator):
- with DEL: it is recognized as org.eclipse.ui.edit.delete and it is
not handled
- with M2+DEL: it "sees" the key sequence (ALT+DEL) but nothing else
(WorkbenchKeyboard.press(potentialKeyStrokes = [ALT+DEL])).
I tried adding a line the ".options" file to see if the accelerator
is activated, but apparently, the added line does not mean anything to it.
Please help.
Thank you in advance,
faithfully yours,
Yassine Bensaid
PS: I also tried to trick eclipse by putting another key sequence to
org.eclipse.ui.edit.delete and then use DEL for myself, but it doesn't
like the idea.
> cheers,
> d.
Re: Key Binding conflicts (need help desperately!!!) [message #443852 is a reply to message #443786] Sun, 05 February 2006 00:31 Go to previous message
I created a very new plugin on a new application (based on the email
rcp example provided in eclipse) and tested with the method of
plugin_customization.ini file, and it's working! (I don't know how I
didn't think about that earlier). Now I guess, the problem I have is
related to conflicts within plugins of the same application (since I am
using key bindings in different plugins).
Any suggestions and advices would be appreciated
Previous Topic:RCP Training
Next Topic:How to report error with product's export?
Current Time: Sat Aug 30 22:50:01 EDT 2025
Powered by FUDForum. Page generated in 0.04344 seconds
