| GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #44209] |
Thu, 29 November 2007 05:46  |
Hi all,
working with Nebula latest release, I have a problem with editable cells
on a GridTableViewer, with collapsed GridColumnGroup.
Let's assume I have 3 GridColumn (col1,col2,col3).
The one in the middle has : col2.setSummary(false);
The table shows the right values, GridColumngroup Expanded and Collapsed ;
meaning that the LabelProvider works well GridColumnGroup.
When GridColumnGroup expanded, a click on any cell of any column allows to
edit the right value.
When Collapsed, a click on col3 give the opportunity to edit hidden col2.
The methods of the CellModifier are given wrong "property" argument by the
GridTableViewer.
In fact, this problem happens when clicking at a position a hidden column
was located when the GridColumnGroup was expanded.
To sum up :
| group << |
|col1|col2| col3 |
| group >> |
|col1| col3 |
| |XXXXXYYY|
When clicking on XXXXX, you edit col2
When clicking on YYY, you edit col3
The problem comes with the CellModifier. Has anyone else the same problem ?
Any idea to solve this ?
Philippe
| Re: GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #44240 is a reply to message #44209] |
Thu, 29 November 2007 06:12   |
It seems that the algorithm to find the correct column to edit is not
working. I suppose the problem is found in
GridViewerRow#getColumnIndex(Point) where we try to correct index.
I think we never tested this at least I haven't so it is fairly likely
that it's not working as expected. Another problem in this area could be
tabbing support.
Ravaine would you mind to creating a snippet (we can run without
modifications) to reproduce the problem and file a bugzilla. I'll take
at it look then.
Tom
Ravaine Philippe schrieb:
> Hi all,
> ; meaning that the LabelProvider works well GridColumnGroup.
> to edit the right value.
> the GridTableViewer.
> column was located when the GridColumnGroup was expanded.
> To sum up :
> | group << |
> |col1|col2| col3 |
> | group >> |
> |col1| col3 |
> | |XXXXXYYY|
> Cheers,
> Philippe
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
| Re: GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #44389 is a reply to message #44299] |
Thu, 29 November 2007 18:08  |
Bug fixed :)
And I agree with Tom - great bug report! Thanks.
-Chris
Tom Schindl wrote:
> Thank you for the great snippet Philippe. This makes fixing bugs fun :-)
> Tom
>> Hi Tom,
>> As you were assuming, another problem in the area is tabbing support.
>> I just created a snippet and attach it to the new bug I reported : Bug
>> 211466
>> Hope you'll get time to have a look at it.
>> Cheers,
>> Philippe Ravaine
| Re: GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #586760 is a reply to message #44209] |
tabbing support.
at it look then.
Tom
> Hi all,
> To sum up :
> | group << |
> |col1|col2| col3 |
> | group >> |
> |col1| col3 |
> | |XXXXXYYY|
> Cheers,
> Philippe
| Re: GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #586781 is a reply to message #44269] |
Thu, 29 November 2007 12:36  |
Tom
> Hi Tom,
> 211466
> Cheers,
> Philippe Ravaine
| Re: GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #586838 is a reply to message #44299] |
Bug fixed :)
-Chris
> Tom
>> Hi Tom,
>> 211466
>> Cheers,
>> Philippe Ravaine
FUDForum. Page generated in 0.27156 seconds
