SWT & JNLP [message #442253] |
Tue, 31 August 2004 03:28  |
Evening,
I'm having a problem that seems to be unique to SWT and Windows
platform (I have no linux so I can't test it there). I used the
following tutorial:
http://www-106.ibm.com/developerworks/opensource/library/os- jws/
It's for deploying SWT remotely using JNLP. I get the same behavior with
any SWT application that I deploy using JNLP. It leaves a rogue
javaw.exe behind. I have to go in to my process explorer and kill the
process manually every time. I've checked with Sun's jnlp examples on
their site and javaw.exe closes every time :/. I've checked the code of
their jnlp launched apps and I don't see anything special about closing
an app.
Has anybody else observed this behavior?
This should work for both Windows and Linux systems. It's the
implementation of the link above.
http://www.4xdamage.com/public/fileviewer/index.html
The Java Webstart Demos are at:
http://java.sun.com/products/javawebstart/demos.html
I'd appreciate any help I can get.
Sincerely,
Vic Hanson
Re: SWT & JNLP [message #442293 is a reply to message #442256] |
Tue, 31 August 2004 11:44  |
That made all the difference in the world. Amazing that I would forget
something so simple. As for the Threads, I suspected that may have been
the problem as the current interface I designed uses a background thread
to run along side the UI and display.asynchExec. However, I tested this
with an older interface (that doesn't use Thread creation) I did and I
had the same problem. Placing the System.exit(0) at the end of each
after I dispose of the display cleanly shuts down my rogue javaw.exe.
Thanks very much, Simone.
Simone Gianni wrote:
> But as an habit i put a System.exit(0); when i want my application to
> exit, not trusting the simple exit from the main method. With a
> System.exit() call you force the JVM to exit gracefully, but still force
> all the live Threads to die, while a running Thread would keep the JVM
> live also after the main method returns. Maybe this makes a difference?
FUDForum. Page generated in 0.04552 seconds
