Home » Eclipse Projects » Standard Widget Toolkit (SWT) » why the text diplayed on screen is not the text.getText()??
why the text diplayed on screen is not the text.getText()?? [message #441990] Fri, 27 August 2004 04:37 Go to next message
Originally posted by: wxbpp.hotmail.com
import java.util.StringTokenizer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Group;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class TestText {
private Shell shell;
public TestText(Shell aShell) {
shell = aShell;
shell.setText("test");
shell.setLayout(new GridLayout(1,true));
shell.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
shell.setVisible(false);
public void start(){
showLogContent("start");
private void showLogContent(String str){
createContent(str);
createButtons();
shell.setSize(400,250);
shell.setVisible(true);
private void createContent(String str){
Label label = null;
Text text = null;
label = new Label(shell,SWT.NONE | SWT.WRAP);
label.setText("No: ");
text = new Text(shell,SWT.BORDER);
text.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
text.setEditable(true);
text.setText(str);// why the text diplayed on screen is not the
text.getText()
text.update();
System.out.println("input parameter is "+str+" source is
"+text.getText());
private void createButtons(){
Button preBtn = new Button(shell,SWT.PUSH);
preBtn.setText("test");
preBtn.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
preBtn.addSelectionListener(new SelectionListener(){
public void widgetSelected(SelectionEvent e) {
showLogContent("runtime");
public void widgetDefaultSelected(SelectionEvent e) {
Display display = new Display();
Shell shell = new Shell(display);
TestText win = new TestText(shell);
win.start();
while (! shell.isDisposed()) {
if (! display.readAndDispatch()) display.sleep();
display.dispose();
Re: why the text diplayed on screen is not the text.getText()?? [message #441997 is a reply to message #441990] Fri, 27 August 2004 08:22 Go to previous message
Originally posted by: friederich.kupzog.de
the problem is that any time you call showLogContent you create new
widgets. After 10 calls your shell has 10 labels, 10 text widgets and 10
buttons. You should call shell.pack() to see them, but i do not think
that is what you intend to to.
The solution (as shown below) is to create the content only once. YOu
can keep a reference to the text widget as class member variable and set
the text using this reference anytime you whish. a text.update() is not
neccessary.
Hope that helped
Friederich
private Text text; // you need to safe a reference to the text field
shell = aShell;
createContent(); // create the widgets only once!
createButtons();
text.setText(str);
private void createContent(){
Label label = new Label(shell,SWT.NONE | SWT.WRAP);
win.start();
display.dispose();
Friederich Kupzog
Elektronik & Software
Neusser Str. 5-7
50670 Köln
Tel 0241 160696-1
Fax 0221 726670
www.kupzog.de/fkmk
Previous Topic:how to make composite resizable
Next Topic:Image-Buttons on PocketPC
Current Time: Sat Jul 19 03:00:41 EDT 2025
Powered by FUDForum. Page generated in 0.41961 seconds
