Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT Problems on Linux
| SWT Problems on Linux [message #441701] |
Fri, 20 August 2004 12:31  |
I'm new to SWT and am having a couple of minor problems. I'm writing a
pretty simple app with menu, tab folder, and a couple of tables in one of
the tabs.
The app works perfectly on Windows, but when I run it under Linux, I have
two problems: first, my menu doesn't show up until I resize the shell.
Second, setting the initial widths of the table columns seems to have no
effect.
On this second issue, I wrote a custom "layout manager" (TableLayout) to
control the widths of the columns, but when I trace through it I notice
that even after creating the columns and setting the widths, getWidth()
still returns 0. This occurs before my layout manager is even created, so
I don't think it's the problem.
Here's the code that sets up the GUI (some objects declared in advance):
display = new Display();
Display.setAppName("JuMP3");
// Create and set up shell
shell = new Shell(display);
shell.setText("JuMP3");
shell.setSize(600, 450);
shell.addDisposeListener(new DisposeListener() {
public void widgetDisposed(DisposeEvent e) {
quit();
// Create menu bar
menu = new Menu(shell, SWT.BAR);
shell.setMenuBar(menu);
// Create file menu
MenuItem fileMenuItem = new MenuItem(menu, SWT.CASCADE);
fileMenuItem.setText("&File");
Menu fileMenu = new Menu(shell, SWT.DROP_DOWN);
fileMenuItem.setMenu(fileMenu);
new MenuItem(fileMenu, SWT.SEPARATOR);
MenuItem fileExitMenuItem = new MenuItem(fileMenu, SWT.PUSH);
fileExitMenuItem.setText("E&xit");
fileExitMenuItem.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event e) {
quit();
// Create help menu
MenuItem helpMenuItem = new MenuItem(menu, SWT.CASCADE);
helpMenuItem.setText("&Help");
Menu helpMenu = new Menu(shell, SWT.DROP_DOWN);
helpMenuItem.setMenu(helpMenu);
MenuItem helpAboutMenuItem = new MenuItem(helpMenu, SWT.PUSH);
helpAboutMenuItem.setText("&About...");
// Create layout
FormLayout layout = new FormLayout();
layout.marginHeight = 5;
layout.marginWidth = 5;
shell.setLayout(layout);
// Create tab folder
TabFolder tabFolder = new TabFolder(shell, SWT.NONE);
FormData ld = new FormData();
ld.top = new FormAttachment(0);
ld.bottom = new FormAttachment(100);
ld.left = new FormAttachment(0);
ld.right = new FormAttachment(100);
tabFolder.setLayoutData(ld);
TabItem spTab = new TabItem(tabFolder, SWT.NONE);
spTab.setText("Servers/Players");
Composite spTabControl = new Composite(tabFolder, SWT.NONE);
spTab.setControl(spTabControl);
spTabControl.setLayout(layout);
TabItem plTab = new TabItem(tabFolder, SWT.NONE);
plTab.setText("Playlists");
Composite plTabControl = new Composite(tabFolder, SWT.NONE);
plTab.setControl(plTabControl);
plTabControl.setLayout(layout);
// Create label
Label svrLabel = new Label(spTabControl, SWT.NONE);
svrLabel.setText("Servers:");
// Create servers table
svrTable = new Table(spTabControl, SWT.FULL_SELECTION | SWT.BORDER);
svrTable.setHeaderVisible(true);
svrTable.setLinesVisible(true);
ld.top = new FormAttachment(svrLabel, 5, SWT.BOTTOM);
ld.bottom = new FormAttachment(plrLabel, -5, SWT.TOP);
svrTable.setLayoutData(ld);
// Create table columns
TableColumn svrTableHosts = new TableColumn(svrTable, SWT.NONE);
svrTableHosts.setText("Name");
svrTableHosts.setWidth(300);
// ----> getWidth() still zero at this point <----
TableColumn svrTableLocs = new TableColumn(svrTable, SWT.NONE);
svrTableLocs.setText("Location");
// Open window
shell.layout();
shell.open();
I'm sure I'm not doing something right :-) Any pointers would be
appreciated - thanks!
Mike
| Re: SWT Problems on Linux [message #441752 is a reply to message #441701] |
Mon, 23 August 2004 14:05   |
Please open a bug report with this info and add which version and platform
(motif or gtk) of swt are you running.
Silenio
Mike Simpson wrote:
> the tabs.
> effect.
> quit();
> // Create menu bar
> // Create file menu
> quit();
> // Create help menu
> // Create layout
> // Create label
> // Open window
> shell.layout();
> shell.open();
> Mike
| Re: SWT Problems on Linux [message #443360 is a reply to message #441701] |
Thu, 23 September 2004 10:09  |
Mike Simpson wrote:
[snip]
[snip]
I have exactly the same problem. I'm runninng Eclipse v3.0 on SuSE 9.1. It
seem to have the problem with JFace window menus and not staight SWT. I
may be wrong.
Current Time: Thu Nov 13 12:15:09 EST 2025
Powered by FUDForum. Page generated in 0.04902 seconds
