Home » Archived » M2M (model-to-model transformation) » [ATL] Modifying Metamodels in EMF Registry ...
[ATL] Modifying Metamodels in EMF Registry ... [message #389800] Wed, 29 July 2009 20:46 Go to next message
Hi eclipse.modeling.m2m.
I am conducting a transformation where I have made some changes to the
metamodel of the source model. I made these changes directly in the
metamodel editor of the source. However, there changes do not seem to be
registered in ATL. The metamodel I am using in my ATL transformation
(uri:http:///fmp.ecore), in the EMF Registry does not appear to have any
these changes reflected. Is there a way to import and then edit a
metamodel stored in the EMF Registry? The uri for the metamodel I am
using is listed (uri:http:///fmp.ecore) but I am not sure where there is
stored or how it got into the registry.
Any thoughts or ideas are appreciated.
Re: [ATL] Modifying Metamodels in EMF Registry ... [message #440605 is a reply to message #389800] Fri, 31 July 2009 04:47 Go to previous messageGo to next message
--------------000204090207060606040006
Do you use the context menu action "Register metamodel" to register your
metamodel or is it a metamodel provided by one of your Eclipse plugin?
Freddy.
J Rusk a
Re: [ATL] Modifying Metamodels in EMF Registry ... [message #443725 is a reply to message #440605] Fri, 31 July 2009 11:27 Go to previous messageGo to next message
It is a metamodel provided by an Eclipse plugin - but I would like to
extract it from the EMF Registry to view it - and then possibly modify it
slightly. Is this possible?
Freddy Allilaire wrote:
> Regards,
> Freddy.
Re: [ATL] Modifying Metamodels in EMF Registry ... [message #468429 is a reply to message #443725] Wed, 05 August 2009 09:46 Go to previous message
Dear J Rusk,
I faced the same problem while using qvto uml2rdb example.
I could get and extract the *.ecore files for the xxxxxx.jar file, located
under xxx/eclipse/plugin directory, related to uml2rdb example.
then i created EMF project for *.ecore and *.genmodel files
then I update the *.ecore file
then generate the models
then export the models as plugins
then put them againg under eclipse/plugin directory
if you need more info I am available
regards
omran
Previous Topic:QVTO- creating PSM RDBMS view/index from UML PIM
Next Topic:[ATL] question on ATL and Ant Tasks
Current Time: Mon Jul 21 22:34:45 EDT 2025
Powered by FUDForum. Page generated in 0.04302 seconds
