Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Vertical Scrolling on an Unknown Height
Vertical Scrolling on an Unknown Height [message #440128] |
Fri, 23 July 2004 14:30  |
Originally posted by: cowking.telus.NOSPAM.net
I've searched for a decent solution on this and have attempted many
things. I've found several code snipets describing how to use scroll bars,
but none of them seem to account for everything I need to do. Perhaps
someone here will be able to assist me.
I am attempting to create a stand-alone SWT program. In it, I dynamically
generate screens (such as reports taken from data within a database).
Therefore, I never know how long the screen will be. It's quite possible
that even maximized the screen will need to carry on further. Naturally,
the solution to this problem is a vertical scrollbar. But such a simple
solution has proven quite difficult for me to implement.
Here is a snipet of the code I am using now:
//Create a display and a shell
Display display = new Display();
final Shell shell = new Shell(display, SWT.SHELL_TRIM | SWT.V_SCROLL);
final Composite composite = new Composite(shell, SWT.NORMAL);
Rectangle shellRect = shell.getClientArea();
composite.setSize(shellRect.width, shellRect.height);
final ScrollBar vBar = shell.getVerticalBar();
vBar.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event e) {
Point location = composite.getLocation();
location.y = -vBar.getSelection();
composite.setLocation(location);
shell.addListener(SWT.Resize, new Listener() {
Point size = composite.getSize();
Rectangle rect = shell.getClientArea();
vBar.setMaximum(size.y);
vBar.setThumb(Math.min(size.y, rect.height));
int vPage = size.y - rect.height;
int vSelection = vBar.getSelection();
if (vSelection >= vPage) {
if (vPage <= 0) vSelection = 0;
location.y = -vSelection;
//TODO Uncomment when you've got the scroll bar working
// shell.setMaximized(true);
//TODO Create a database connection and get the current months data
//Create the Report Screen/Main Screen
createReportScreen(composite);
//Start the program
shell.open();
//Wait until the program finishes before disposing the display
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
What happens, is that I get a composite on screen that has a scrollbar.
However, when I attempt to scroll down to data off the current page, it
shows me nothing. Just the background shell. Also, if I resize the shell,
the composite resizes properly... But again, if any data is off the screen
(or takes up more space than the composite has) it cannot be scrolled down.
I know I'm missing something small. So if anyone is kind enough to use
their time for this, I'd appreciate it very much.
Thanks!
Kevin
PS - Using FormLayout to place my widgets, if that makes any difference.
Re: Vertical Scrolling on an Unknown Height [message #440131 is a reply to message #440128] |
Fri, 23 July 2004 16:17   |
Instead of 'adding' scrollbars to a Composite I use a ScrolledComposite.
ScrolledComposite scComp =
new ScrolledComposite(parent, SWT.H_SCROLL | SWT.V_SCROLL);
Composite comp = new Composite(scComp, SWT.NONE);
scComp.setContent(comp);
Then you can add widgets to comp and set the layout on comp, etc. Using
ScrolledComposite takes care of a lot of the work for it.
The scroll bars are only present when needed - vertical and horizontal in
the example above.
I hope this helps.
Greg
Kevbo wrote:
> public static void main(String[] args) {
> //Start the program
> shell.open();
> display.dispose();
> Thanks!
> Kevin
Re: Vertical Scrolling on an Unknown Height [message #440218 is a reply to message #440131] |
Mon, 26 July 2004 13:21   |
Originally posted by: Kevin.clark.accessbc.com.nospam
Thanks for your comments Greg. I have attempted to use scrolled composite,
but get the same problems. When I run my program I just get the blank
screen I was getting before... All that is displayed is an empty shell
with not scroll bars and no widgets. No scrolled composite or composite
seems to get drawn. It's got to be something small..
Here's the revised code with your suggestions:
final Shell shell = new Shell(display);
ScrolledComposite sComp = new ScrolledComposite(shell, SWT.V_SCROLL);
Composite composite = new Composite(sComp, SWT.NONE);
sComp.setContent(composite);
//Create a new layout for this screen using FormLayout
FormLayout layout = new FormLayout();
layout.marginWidth = 5; //Amount of space from sides
layout.marginHeight = 5; //Amount of space from top and bottom
composite.setLayout(layout);
//I CREATE AND DRAW MY WIDGETS IN HERE USING composite AS THEIR PARENT
//Start the program
shell.open();
display.dispose();
Thanks for your help,
Kevin
> the example above.
> I hope this helps.
> Greg
> Kevbo wrote:
> > Hi,
> > //Start the program
> > shell.open();
> > display.dispose();
> > Thanks!
> > Kevin
Re: Vertical Scrolling on an Unknown Height [message #440277 is a reply to message #440218] |
Tue, 27 July 2004 16:53   |
It looks correct.
I just wonder if the problem has to do with using the new Shell you get to
pass to the ScrolledComposite constructor...
Not sure if this Shell is what you need - seems like it should work, but I
haven't tried this method.
I have used this mechanism inside of a createPartControl method for a view
and I used the Composite parent that got passed in so I know that it is
the Composite that is the Composite for this particular view.
Sorry I don't have any more information about this...
> //Start the program
> shell.open();
> display.dispose();
> Kevin
> > the example above.
> > I hope this helps.
> > Greg
> > Kevbo wrote:
> > > Hi,
bars,
> > > //Start the program
> > > shell.open();
> > > display.dispose();
screen
down.
> > > Thanks!
> > > Kevin
Re: Vertical Scrolling on an Unknown Height [message #440290 is a reply to message #440277] |
Wed, 28 July 2004 12:10   |
Greg,
Thank you for your time and efforts. I suppose I'll just keep hacking at
it and continue searching for good code snippets.
You mentioned the Shell... Since this is a stand-alone program, I don't
get a createPartControl method to implement. The creation of a Display and
Shell is just the way you get the ball rolling for a stand-alone program.
The Shell has the same characteristics of a Composite object (Shell
extends Decorations extends Canvas extends Composite). Therefore, it
should be capable of being used as a Composite.
However with that said, I am certainly not ruling out the chance that the
Shell creation could be causing some of these problems.
Again, thanks for helping. I've learned a lot despite the fact that it
still doesn't work!
Kevin
Greg wrote:
> It looks correct.
> > //Start the program
> > shell.open();
> > display.dispose();
> > Kevin
> > > the example above.
> > > I hope this helps.
> > > Greg
> > > Kevbo wrote:
> > > > Hi,
> bars,
dynamically
possible
Naturally,
SWT.V_SCROLL);
> > > > //Start the program
> > > > shell.open();
> > > > display.dispose();
shell,
> screen
> down.
> > > > Thanks!
> > > > Kevin
difference.
Re: Vertical Scrolling on an Unknown Height [message #440823 is a reply to message #440128] |
Fri, 06 August 2004 19:02   |
I have resolved this problem. I'm posting the solution here for archival
purposes, since I'm pretty sure the topic has died.
It's best to use ScrolledComposite, instead of what I was originally
trying to do (access the scroll bars on the shell). You need to set the
size of the ScrolledComposite to the size of the client area on the Shell.
But set the composite that you draw onto to it's default size. Then add a
resize listener to the ScrolledComposite so that it changes sizes with the
Shell. See the code snippet below for a better understanding.
Kevin
//Create scroll bars
final ScrolledComposite sComp = new ScrolledComposite(shell,
SWT.V_SCROLL);
//Create the composite to draw widgets onto and put the scroll bars on
//it
final Composite composite = new Composite(sComp, SWT.NONE);
//**************DRAW WIDGETS****************
//Set the size and configure the scrollbars
Point size = composite.computeSize(rect.width, SWT.DEFAULT);
composite.setSize(size);
sComp.setSize(rect.width, rect.height);
//Start the program
shell.open();
display.dispose();
Kevbo wrote:
> //Start the program
> shell.open();
> display.dispose();
> Thanks!
> Kevin
Re: Vertical Scrolling on an Unknown Height [message #440969 is a reply to message #440823] |
Mon, 09 August 2004 11:10  |
Thanks for posting your solution.
"Kevbo" <Kevin.clark@accessbc.com.nospam> wrote in message
news:cf12mk$7op$1@eclipse.org...
> Kevin
> SWT.V_SCROLL);
> //it
> //Start the program
> shell.open();
> display.dispose();
> Kevbo wrote:
> > Hi,
bars,
dynamically
> > //Start the program
> > shell.open();
> > display.dispose();
shell,
screen
down.
> > Thanks!
> > Kevin
Current Time: Mon Aug 11 21:49:56 EDT 2025
Powered by FUDForum. Page generated in 0.08538 seconds
