Home » Eclipse Projects » Mylyn » keyboard shortcut questions
keyboard shortcut questions [message #44027] Tue, 26 February 2008 17:55 Go to next message
Originally posted by: marc_e.ye.olde.spam.buster.cablespeed.com
Greetings all. Is there a single place that lists all mylyn's built-in
shortcuts?
Also, let's say I have an issue open in the issue editor and it's
activated. i have 5 or so files open. what's the fastest way to get to the
issue context tab in the issue editor? is there a "quick context" or
keyboard shortcut to open that sucker up right away?
thanks.
lazily....
Marc
Re: keyboard shortcut questions [message #44058 is a reply to message #44027] Tue, 26 February 2008 19:44 Go to previous messageGo to next message
> shortcuts?
You can open standard Keys preference page and filter the list using
for example "task" or "mylyn" keywords.
Page is at Window / Preferences / General / Keys
You can use Quick Context view or switch to the task editor using
Ctrl-F6 and then use standard tab navigation - Ctrl-PgUp/PgDown to jump
between editor tabs. Though it seem like there is a bug and
Ctrl-PgUp/PgDown don't work all the time. If you think it is a critical
issue, please submit a bug report about that.
> is there a "quick context" or keyboard shortcut to open that sucker up right away?
Yes, you can open Quick Context view from the Navigate / Quick Context
View or using Ctrl-Alt-Shift-Right shortcut or use Ctrl-3, "quick context".
regards,
Eugene
Re: keyboard shortcut questions [message #44088 is a reply to message #44058] Tue, 26 February 2008 20:08 Go to previous message
perfect. thanks Eugene.
"Eugene Kuleshov" <eu@md.pp.ru> wrote in message
news:fq2bpp$6lb$1@build.eclipse.org...
>> shortcuts?
> You can open standard Keys preference page and filter the list using for
>> the issue context tab in the issue editor?
> You can use Quick Context view or switch to the task editor using Ctrl-F6
> and then use standard tab navigation - Ctrl-PgUp/PgDown to jump between
> editor tabs. Though it seem like there is a bug and Ctrl-PgUp/PgDown don't
> work all the time. If you think it is a critical issue, please submit a
>> right away?
> context".
> regards,
> Eugene
Re: keyboard shortcut questions [message #588050 is a reply to message #44027] Tue, 26 February 2008 19:44 Go to previous message
> shortcuts?
regards,
Eugene
Re: keyboard shortcut questions [message #588059 is a reply to message #44058] Tue, 26 February 2008 20:08 Go to previous message
>> shortcuts?
>> right away?
> context".
> regards,
> Eugene
Previous Topic:Add all files / classes in one Package to context
Next Topic:JIRA Connector: Error when connection via HTTPS
Current Time: Fri Jul 18 22:08:24 EDT 2025
Powered by FUDForum. Page generated in 0.04704 seconds
