Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Layouts vs. setLocation()
Layouts vs. setLocation() [message #438721] Wed, 30 June 2004 22:07 Go to next message
Hi!
I have a Shell with several Composites as children. The Shell does not use
a layout; intead, all the Composites are positioned using setLocation().
On each Composite, however, I want to use a Layout Manager to layout all
the widgets on the Composite.
I found that when I do this, the children of the Composites will not
appear. I can only use a Layout Manager on the Composites if I also use
one on the Shell. If I position the Shell's children using setLocation(),
I must also position the Composites' children using setLocation(). Is this
behaviour expected? If so, why?
Thanks!
Ryan
Re: Layouts vs. setLocation() [message #438741 is a reply to message #438721] Thu, 01 July 2004 08:16 Go to previous messageGo to next message
Originally posted by: am560571.wcupa.edu
With my limited usage of SWT I found Composites do wierd things...I also
found that using SashForms is much easier...You can set the sash width to
make the resize bar bigger of smaller..and negative numbers with make it
so the user can't use it and the more negative the closer the Widgets will
be to each other. Also you get setWieghts/getWieghts method which are
good to do when/if you want to make an ini file.
later,
whatsgoingon
Ryan wrote:
> Hi!
> Thanks!
> Ryan
Re: Layouts vs. setLocation() [message #439062 is a reply to message #438721] Mon, 05 July 2004 16:42 Go to previous messageGo to next message
Need code. How about a stand alone snippet?
"Ryan" <a@b.com> wrote in message news:cbvrl9$neg$1@eclipse.org...
> Hi!
> Thanks!
> Ryan
Re: Layouts vs. setLocation() [message #439197 is a reply to message #439062] Tue, 06 July 2004 23:38 Go to previous messageGo to next message
Hi Steve,
Below is a stand alone snippet to illustrate. If the snippet is run as,
the label can be displayed. However, if the line marked with /*** 1 ***/
is removed, then the label can not be seen. However, I believe that the
label should still be seen even if that line is removed because the
composite has a FillLayout on it.
Thanks for your help!
Ryan
P.S. I'm running SWT 2.1. I'm not sure if this happens in 3.0.
package pokemon;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
public class Snippet {
static Display display;
static Shell shell;
display = new Display();
shell = new Shell(display);
shell.setSize(200, 110);
Composite comp = new Composite(shell, SWT.BORDER);
comp.setSize(100,50);
comp.setLocation(5,5);
comp.setLayout(new FillLayout());
Label l = new Label(comp, SWT.NONE);
l.setBackground(display.getSystemColor(SWT.COLOR_YELLOW));
l.setBounds(2,2,20,20); /*** 1 ***/
shell.open ();
shell.forceFocus();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
> > Hi!
> > Thanks!
> > Ryan
Re: Layouts vs. setLocation() [message #439212 is a reply to message #439197] Wed, 07 July 2004 11:18 Go to previous messageGo to next message
Ok, I ran your code and looked at what you are doing. Layout in SWT is only
triggered when a composite is resized or you call layout(). In your
snippet, you install the layout after you set the size. I hacked your code
to do it after and commented out the unnecessary /*** 1 ***/ line. Hope
this helps.
static Shell shell;
// comp.setSize(100,50);
// l.setBounds(2,2,20,20); /*** 1 ***/
comp.setSize(100, 50);
shell.open();
shell.forceFocus();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
"Ryan" <a@b.com> wrote in message news:ccfr7a$ea7$1@eclipse.org...
> Hi Steve,
> Ryan
> package pokemon;
> import org.eclipse.swt.widgets.Display;
> static Shell shell;
> public static void main(String[] args) {
> shell.open ();
> shell.forceFocus();
> display.dispose ();
> > > Hi!
use
setLocation().
all
use
setLocation(),
this
> > > Thanks!
> > > Ryan
Re: Layouts vs. setLocation() [message #439215 is a reply to message #439197] Wed, 07 July 2004 11:24 Go to previous messageGo to next message
The label's default size is zero. That's why it doesn't show up. If you
set a label text and pack() the Label, it will show up (even if you
don't pack() the containing Composite). If you want to position it with
the Composite's layout, you need to pack() the entire Composite. You can
still set the Composite's bounds _afterwards_ to whatever you need for
your absolute positioning.
Stefan Zeiger http://www.szeiger.de http://www.novocode.com
My SWT controls: http://www.novocode.com/swt
Re: Layouts vs. setLocation() [message #439221 is a reply to message #439212] Wed, 07 July 2004 12:21 Go to previous message
Ah, I see now. Thanks, Steve!
> this helps.
> static Shell shell;
> shell.open();
> shell.forceFocus();
> display.sleep();
> display.dispose();
> > Hi Steve,
> > Ryan
> > package pokemon;
> > static Shell shell;
> > shell.open ();
> > shell.forceFocus();
> > display.dispose ();
> > > > Hi!
> use
> setLocation().
> all
> use
> setLocation(),
> this
> > > > Thanks!
> > > > Ryan
Previous Topic:Tableviewer, Content-, Labelprovider - Question
Next Topic:Tooltips for the swt table column header
Current Time: Fri Sep 19 10:01:55 EDT 2025
Powered by FUDForum. Page generated in 0.18987 seconds
