| Big Problem !!!! [message #437876] |
Thu, 06 October 2005 08:05  |
Originally posted by: gkurien.icope.com
hi,
when i open a view using 'window.getActivePage().showView("viewID");'
and then i try to resize the window i get an error
Unhandled event loop exception
Reason:
org.eclipse.ui.internal.layout.TrimLayoutData
how do i correct this ?
Thanxs in advance.
| Re: Big Problem !!!! [message #437884 is a reply to message #437880] |
Thu, 06 October 2005 14:02  |
You have set non GridData (TrimLayoutData) to GridLayout in your view
- this was possible before 3.1 eclipse
If view is from eclipse (any eclipse view) then it is bug in eclipse
Genu George wrote:
> hi,
> i have View in the plugin.xml file.. i have a perspective but i have not
> written any piece of code in the createInitialLayout(IPageLayout ) except
> for layout.setEditorAreaVisible( false); i use dialog box to create
> dynamically a ViewPart by calling the show(viewId ) . if i resize the
> workbench before calling the show() method , i dont get any problem with
> the layout ..i mean if there are other viewPart present and i resize , all
> the views in it get resized accordingly but once i open a view using the
> show method , the view opens properly and also get displayed well but if i
> resize the workbench this time i get the error ...i dont know if thats
> good enough explaination . this is the log file i get .
> !SESSION 2005-10-06 19:20:22.458
> eclipse.buildId=unknown
> java.version=1.5.0_04
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Framework arguments: -product XLS_Work.product -pdelaunch
> Command-line arguments: -product XLS_Work.product -data
> D:\MyFolder\E-WorkSpace\runtime-workspace -dev
file:D:/MyFolder/E-WorkSpace/DAO-WS/.metadata/.plugins/org.e clipse.pde.core/DAO_RCP/dev.properties
> -pdelaunch -os win32 -ws win32 -arch x86
> !ENTRY org.eclipse.ui 4 4 2005-10-06 19:20:42.336
> !MESSAGE Unhandled event loop exception
> !ENTRY org.eclipse.ui 4 0 2005-10-06 19:20:42.346
> !MESSAGE org.eclipse.ui.internal.layout.TrimLayoutData
> !STACK 0
> java.lang.ClassCastException:
> org.eclipse.ui.internal.layout.TrimLayoutData at
> org.eclipse.swt.layout.GridLayout.layout(GridLayout.java:197 ) at
> org.eclipse.swt.layout.GridLayout.layout(GridLayout.java:186 ) at
> org.eclipse.swt.widgets.Composite.updateLayout(Composite.jav a:869) at
> org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:124 8) at
> org.eclipse.swt.widgets.Canvas.WM_SIZE(Canvas.java:253) at
> org.eclipse.swt.widgets.Decorations.WM_SIZE(Decorations.java :1761) at
> org.eclipse.swt.widgets.Control.windowProc(Control.java:3107 ) at
> org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1582) at
> org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 ) at
> org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method) at
> org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1651 ) at
> org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:410) at
> org.eclipse.swt.widgets.Control.windowProc(Control.java:3123 ) at
> org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method) at
> org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56) at
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2711) at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699) at
> org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663) at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
> at xLS_Work.intro.Application.run(Application.java:18)
> at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
> at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
> at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
> at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
> at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
> at org.eclipse.core.launcher.Main.run(Main.java:973)
> at org.eclipse.core.launcher.Main.main(Main.java:948)
FUDForum. Page generated in 0.09826 seconds
