Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to capture MouseEvents on a TableColumn
How to capture MouseEvents on a TableColumn [message #437604] Tue, 08 June 2004 14:03 Go to next message
Does anyone know how MouseEvents can be observed on a TableColumn?
For sure, SelectionListeners can be added to a TableColumn, but that does
not do the trick, since right-click events are not captured. Adding a
MouseListener to the underlying Table control is no good either, since it
does not issue any events on the table header/columns.
The lack of this basic feature (like presenting a context menu for a column,
for instance) is quite a show stopper in my application. Therefore, any help
is greatly appreciated!
Cheers
Erik
Re: How to capture MouseEvents on a TableColumn [message #437640 is a reply to message #437604] Tue, 08 June 2004 20:06 Go to previous messageGo to next message
I haven't tried it, but try to just use addListener().
TableColumn.addListener(SWT.MouseDown, new Listener() {
public void handleEvent(Event event) {
Then in handleEvent(), you could check if it's right or left mouse click
and process it accordingly.
Michael
Re: How to capture MouseEvents on a TableColumn [message #437643 is a reply to message #437640] Wed, 09 June 2004 02:33 Go to previous messageGo to next message
Michael,
thanks for your suggestion. I did try your approach as well, however with no
effect. No events reach the handleEvent-method at all, which confuses me.
Enlighten me please, anyone?!?
I think the underlying "problem" (regarding my original ?: how to capture
mouse events on a TC) might be that headers of Table objects are
"unreachable", since Eclipse relies heavily on the OS for this. But then
again, it is possible to add a SelectionListener to a TableColumn, so why
should it be impossible to add a MouseListener?!?
Any help on this topic is very welcome.
Erik
"Michael Xia" <yun@rti.com> skrev i meddelandet
news:ca5ka1$nog$1@eclipse.org...
> Michael
Re: How to capture MouseEvents on a TableColumn [message #437655 is a reply to message #437604] Wed, 09 June 2004 10:07 Go to previous messageGo to next message
This is a known issue, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=17871 .
Grant
"Erik Lundstrom" <erik.lundstrom@solme.se> wrote in message
news:ca4uhr$td4$1@eclipse.org...
column,
help
> Cheers
> Erik
Re: How to capture MouseEvents on a TableColumn [message #437719 is a reply to message #437655] Wed, 09 June 2004 11:18 Go to previous messageGo to next message
Thanks Grant.
Has anyone perhaps developed a workaround for this, or custom 'emulated'
table + table column widgets that does not rely on the OS?
Erik.
"Grant Gayed" <grant_gayed@ca.ibm.com> skrev i meddelandet
news:ca753b$bhr$1@eclipse.org...
> Grant
does
it
> column,
> help
> > Cheers
> > Erik
Re: How to capture MouseEvents on a TableColumn [message #437840 is a reply to message #437643] Thu, 10 June 2004 16:30 Go to previous messageGo to next message
Note that you can't rely on being able to use a SelectionListener either
on a TableColumn; it doesn't work on Mac OS X, for instance. Be sure to
provide another way to get at the functions you'd use this for.
-- brion vibber (brion @ pobox.com)
Re: How to capture MouseEvents on a TableColumn [message #559659 is a reply to message #437840] Fri, 17 September 2010 10:20 Go to previous messageGo to next message
Hi Eric
I am sailing in same boat as you were. Were you able to capture mouse events on a Table Column. I have urgent client requirement to popup a dialog of right click on TableColumn.
SelectionListener works fine for left mouse click on tableColumn.
I tried to addListener, but It doesn't get rightclick mouse event.
Any help / suggestion regarding this would be greatly appreciated.
Jatin Vasa
Re: How to capture MouseEvents on a TableColumn [message #1230934 is a reply to message #559659] Mon, 13 January 2014 07:07 Go to previous messageGo to next message
I have the same problem.
Has anybody found a solution / fix for this?
Thanks!
Re: How to capture MouseEvents on a TableColumn [message #1231766 is a reply to message #1230934] Wed, 15 January 2014 05:50 Go to previous message
Actually, I found this snippet that show how to do this:
Cool
Previous Topic:How can I integrate a native application ( like putty.exe ) with SWT shell ?
Next Topic:Xulrunner 25 with Eclipse
Current Time: Fri Jul 25 08:36:46 EDT 2025
Powered by FUDForum. Page generated in 0.06642 seconds
