Home » Eclipse Projects » Rich Client Platform (RCP) » how to add IWorkbenchWindowActionDelegate programmatically ?
how to add IWorkbenchWindowActionDelegate programmatically ? [message #437626] Fri, 30 September 2005 07:22 Go to next message
Originally posted by: gkurien.icope.com
hi,
i have a IWorkbenchWindowActionDelegate that i dont intend to use thru the
plugin.xml file..
know i want to know how to add my IWorkbenchWindowActionDelegate to the
menu ?
there is one more thing i want to know ,
if i get a file instance from my menu which extends Action ..then how do i
pass the file to my required View ?
atleast is there any way to pass a file instance from a menuItem to the
required View ....pls help me on this ..i have been stuck on this problem
for some time now...
Re: how to add IWorkbenchWindowActionDelegate programmatically ? [message #437697 is a reply to message #437626] Sun, 02 October 2005 16:05 Go to previous messageGo to next message
You can add get the view by
MyPlugin.getDefault().getWorkbench().getActiveWorkbenchWindo w().getActivePage().findView(VIEW_ID);
and then send the view a message with the file.
Stefan
> hi,
> the plugin.xml file..
> menu ?
> i pass the file to my required View ?
> problem for some time now...
Re: how to add IWorkbenchWindowActionDelegate programmatically ? [message #437701 is a reply to message #437697] Mon, 03 October 2005 00:22 Go to previous messageGo to next message
thanx but i still dint get how to add a IWorkbenchWindowActionDelegate
programmatically to a menuManager ?
Re: how to add IWorkbenchWindowActionDelegate programmatically ? [message #437801 is a reply to message #437701] Wed, 05 October 2005 01:47 Go to previous message
Originally posted by: welldamn.gmail.com
For the actions you've defined that are going to be added to the menuManager, simply instantiate with a new object you've created, e.g:
Action action = new YourNewObject();
"YourNewObject" will extend Action and implement IWorkbenchWindowActionDelegate.
Previous Topic:Feature basics..
Next Topic:make eclipse more verbose?
Current Time: Tue Sep 16 18:40:25 EDT 2025
Powered by FUDForum. Page generated in 0.03519 seconds
